So, after recent update I lost sound on my Manjaro and I don’t know how but my second OS (OpenSUSE) lost sound as well, and they have the same errors and I suppose, Manjaro cause it.
Output of inxi -A:
Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
Sound Server: ALSA v: k5.9.11-3-MANJARO
Output of aplay -l:
**** List of PLAYBACK Hardware Devices ****
Output of sudo dmesg | grep snd:
[ 16.774116] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 17.118954] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 17.288296] snd_hda_intel 0000:00:1f.3: CORB reset timeout#1, CORBRP = 0
[ 17.289850] snd_hda_intel 0000:00:1f.3: no codecs found!
[ 91.784532] snd_hda_intel 0000:00:1f.3: CORB reset timeout#1, CORBRP = 0
Output of sudo lspci -vvv:
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
DeviceName: Onboard - Sound
Subsystem: Lenovo Device 313d
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 128
Region 0: Memory at a2310000 (64-bit, non-prefetchable) [size=16K]
Region 4: Memory at a2000000 (64-bit, non-prefetchable) [size=1M]
Capabilities: [50] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=55mA PME(D0-,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [80] Vendor Specific Information: Len=14 <?>
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee002f8 Data: 0000
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_skl, snd_sof_pci
When I run pulseaudio:
W: [pulseaudio] main.c: This program is not intended to be run as root (unless --system is specified).
E: [pulseaudio] module-alsa-card.c: Failed to find a working profile.
E: [pulseaudio] module.c: Failed to load module "module-alsa-card" (argument: "device_id="0" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1""): initialization failed.
E: [pulseaudio] module-jackdbus-detect.c: Unable to contact D-Bus session bus: org.freedesktop.DBus.Error.NotSupported: Using X11 for dbus-daemon autolaunch was disabled at compile time, set your DBUS_SESSION_BUS_ADDRESS instead
E: [pulseaudio] module.c: Failed to load module "module-jackdbus-detect" (argument: "channels=2"): initialization failed.
W: [pulseaudio] authkey.c: Failed to open cookie file '/root/.config/pulse/cookie': No such file or directory
W: [pulseaudio] authkey.c: Failed to load authentication key '/root/.config/pulse/cookie': No such file or directory
W: [pulseaudio] authkey.c: Failed to open cookie file '/root/.pulse-cookie': No such file or directory
W: [pulseaudio] authkey.c: Failed to load authentication key '/root/.pulse-cookie': No such file or directory
W: [pulseaudio] server-lookup.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Using X11 for dbus-daemon autolaunch was disabled at compile time, set your DBUS_SESSION_BUS_ADDRESS instead
W: [pulseaudio] main.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Using X11 for dbus-daemon autolaunch was disabled at compile time, set your DBUS_SESSION_BUS_ADDRESS instead
