Hello, I’ve had an issue ever since my update to 5.10.36-2 where I can’t seem to access phpmyadmin or any of my local virtual hosts. I’m a web developer and I really need this working but don’t know what is wrong. I’ve checked the logs in /var/log/httpd/error_log
and they are empty.
I just found the command sudo systemctl --failed
which shows that httpd.service and shadow.service failed:
UNIT LOAD ACTIVE SUB DESCRIPTION >
● httpd.service loaded failed failed Apache Web Server >
● shadow.service loaded failed failed Verify integrity of password and group fi>
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
2 loaded units listed.
So I’m assuming that is the issue, but I don’t know why it failed? How do I fix that?
I usually access phpmyadmin at http://localhost/phpmyadmin/index.php
, I usually start httpd and mysqld using sudo systemctl start httpd && sudo systemctl start mysqld
But now I can’t access any of the .local sites or the phpmyadmin local interface.
What should I do? What information do you need from me / please let me know what commands to run in order to access that information.
Here is my system info (as requested in “how to provide good information” post):
Kernel: 5.10.36-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=bde2794b-a610-4679-a8c0-8d0ab02bd7b1 rw loglevel=3 quiet
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1
dm: LightDM 1.30.0, SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: X99 Taichi serial: <filter>
UEFI: American Megatrends v: P1.40 date: 08/04/2016
RAM: total: 15.56 GiB used: 9.71 GiB (62.4%)
RAM Report:
missing: Required tool dmidecode not installed. Check --recommends
Info: 6-Core model: Intel Core i7-5820K bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 3F (63) stepping: 2 microcode: 44 cache: L2: 15 MiB
bogomips: 79211
Speed: 1200 MHz min/max: 1200/3600 MHz Core speeds (MHz): 1: 1200 2: 1200
3: 1201 4: 1202 5: 1200 6: 1200 7: 1200 8: 1200 9: 1202 10: 1204 11: 1202
12: 1200
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cqm cqm_llc cqm_occup_llc cx16
cx8 dca de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_ppin
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
Type: l1tf
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Micro-Star MSI
driver: nvidia v: 460.80 alternate: nouveau,nvidia_drm bus-ID: 03:00.0
chip-ID: 10de:1b81 class-ID: 0300
Display: x11 server: X.org 1.20.11 compositor: kwin_x11 driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 460.80
direct render: Yes
Device-1: Intel C610/X99 series HD Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8d20
class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 10de:10f0
class-ID: 0403
Device-3: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3:3 chip-ID: 0d8c:0005
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.10.36-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: yes
Device-1: Intel Ethernet I218-V vendor: ASRock driver: e1000e v: kernel
port: f020 bus-ID: 00:19.0 chip-ID: 8086:15a1 class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
port: d000 bus-ID: 05:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel Wireless 3160 driver: iwlwifi v: kernel port: d000
bus-ID: 06:00.0 chip-ID: 8086:08b3 class-ID: 0280
IF: wlp6s0 state: down mac: <filter>
bus-ID: 3-11:7 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 4.77 TiB used: 386.45 GiB (7.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 1B2QEXE7 temp: 36.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA200 size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: ABB0 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT240M500SSD1
size: 223.57 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: MU05 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Samsung
model: Portable SSD T5 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B rotation: SSD serial: <filter> scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Centon model: DS Sport
size: 7.47 GiB block-size: physical: 512 B logical: 512 B serial: <filter>
rev: 8.07 scheme: MBR
ID-1: / raw-size: 393.67 GiB size: 386.49 GiB (98.18%)
used: 340.68 GiB (88.1%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
label: N/A uuid: bde2794b-a610-4679-a8c0-8d0ab02bd7b1
ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%)
used: 24.9 MiB (26.2%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 624C-C644
ID-3: /run/media/user/BackupFiles raw-size: 150 GiB
size: 146.65 GiB (97.76%) used: 45.75 GiB (31.2%) fs: ext4 dev: /dev/sdc3
maj-min: 8:35 label: BackupFiles uuid: cc322d9e-917a-45c1-a070-00897a3c2ad7
ID-1: swap-1 type: file size: 16 GiB used: 225 MiB (1.4%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: ntfs label: Recovery
uuid: 46284CA0284C90BB
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1.43 TiB fs: ntfs label: N/A
uuid: 7C144DD3144D9156
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 577 MiB fs: ntfs label: N/A
uuid: AE72676172672D71
ID-5: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: <superuser required>
ID-6: /dev/sdb1 maj-min: 8:17 size: 223.57 GiB fs: ntfs label: ssd_old
uuid: 21BAA8624978024C
ID-7: /dev/sdc1 maj-min: 8:33 size: 1024 MiB fs: vfat label: N/A
uuid: 07BC-6BC7
ID-8: /dev/sdc2 maj-min: 8:34 size: 780.51 GiB fs: ext4
label: ManjaroExternal uuid: a5fbe1fb-8f13-4708-afab-d39186e57cdd
ID-9: /dev/sdd1 maj-min: 8:49 size: 2.68 GiB fs: iso9660
label: MANJARO_KDE_2105 uuid: 2021-05-19-14-17-55-00
ID-10: /dev/sdd2 maj-min: 8:50 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 9C47-5257
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Hub ports: 6 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:800a class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel 8 channel internal hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8002 class-ID: 0900
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 15 rev: 2.0
Device-1: 3-1:2 info: Microsoft Xbox360 Controller type: <vendor specific>
driver: xpad interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 045e:028e class-ID: ff00 serial: <filter>
Device-2: 3-3:3 info: C-Media Blue Snowball type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0005 class-ID: 0300
serial: <filter>
Device-3: 3-4:4 info: Logitech G502 Proteus Spectrum Optical Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
serial: <filter>
Device-4: 3-8:5 info: Corsair H100i v2 type: <vendor specific> driver: N/A
interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 50mA chip-ID: 1b1c:0c09
class-ID: 0000 serial: <filter>
Device-5: 3-9:6 info: CENTON DS Sport type: Mass Storage driver: usb-storage
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 111d:0000
class-ID: 0806 serial: <filter>
Hub-6: 3-10:10 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2813 class-ID: 0900
Device-1: 3-11:7 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 3-13:8 info: Microdia USB DEVICE type: Keyboard,Mouse
power: 100mA chip-ID: 0c45:8073 class-ID: 0301
Hub-7: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-8: 4-6:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 2109:0813 class-ID: 0900
Hub-9: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-10: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Device-1: 6-1:2 info: Samsung Portable SSD T5 type: Mass Storage driver: uas
interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 896mA chip-ID: 04e8:61f5
System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 43 C
Processes: 413 Uptime: 4h 50m wakeups: 0 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: apt: 0
pacman: 2098 lib: 556 Shell: Zsh v: 5.8 running-in: lxterminal inxi: 3.3.04
Here is journalctl --catalog --priority=3 --boot=-1
results:
-- Journal begins at Wed 2020-06-17 17:11:26 EDT, ends at Wed 2021-06-09 12:42:>
Jun 08 07:17:57 user-pc kernel:
Jun 08 07:17:58 user-pc systemd-modules-load[300]: Failed to find module 'zfs'
Jun 08 07:18:14 user-pc kernel: hid-generic 0003:0D8C:0005.0001: No inputs regi>
Jun 08 07:18:14 user-pc kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 h>
Jun 08 07:18:14 user-pc kernel: EDAC sbridge: Couldn't find mci handler
Jun 08 07:18:14 user-pc kernel: EDAC sbridge: Failed to register device with er>
Jun 08 07:18:14 user-pc kernel: Bluetooth: hci0: unexpected event for opcode 0x>
Jun 08 07:18:14 user-pc kernel: sd 10:0:0:0: [sdd] No Caching mode page found
Jun 08 07:18:14 user-pc kernel: sd 10:0:0:0: [sdd] Assuming drive cache: write >
Jun 08 07:18:15 user-pc kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 h>
lines 1-23...skipping...
Jun 08 07:18:15 user-pc kernel: EDAC sbridge: Couldn't find mci handler
lines 1-24...skipping...
Jun 08 07:18:15 user-pc kernel: EDAC sbridge: Failed to register device with er>
lines 1-27...skipping...
lines 1-28...skipping...
lines 1-31...skipping...
lines 1-32...skipping...
lines 1-36...skipping...
lines 1-39...skipping...
lines 1-40...skipping...
lines 1-41
lines 1-40
lines 1-39
lines 1-38...skipping...
-- Journal begins at Wed 2020-06-17 17:11:26 EDT, ends at Wed 2021-06-09 12:42:28 EDT. --
Jun 08 07:18:14 user-pc kernel: hid-generic 0003:0D8C:0005.0001: No inputs registered, leaving
Jun 08 07:18:14 user-pc kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
Jun 08 07:18:14 user-pc kernel: EDAC sbridge: Failed to register device with error -19.
Jun 08 07:18:14 user-pc kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
Jun 08 07:18:14 user-pc kernel: sd 10:0:0:0: [sdd] Assuming drive cache: write through
Jun 08 07:18:15 user-pc kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
Jun 08 07:18:15 user-pc kernel: EDAC sbridge: Failed to register device with error -19.
Jun 08 07:22:50 user-pc kwin_x11[1111]: kwin_core: Compositing is not possible
Jun 08 08:03:01 user-pc ssh-agent[1078]: error: process_sign_request2: parse: invalid format
Jun 08 08:03:09 user-pc ssh-agent[1078]: error: process_sign_request2: parse: invalid format
Jun 08 08:06:32 user-pc ssh-agent[1078]: error: process_sign_request2: parse: invalid format
Jun 08 08:23:13 user-pc ssh-agent[1078]: error: process_sign_request2: parse: invalid format
Jun 08 08:23:25 user-pc ssh-agent[1078]: error: process_sign_request2: parse: invalid format
Jun 08 08:53:18 user-pc ssh-agent[1078]: error: process_sign_request2: parse: invalid format
Jun 08 08:53:31 user-pc ssh-agent[1078]: error: process_sign_request2: parse: invalid format
Jun 08 08:56:41 user-pc ssh-agent[1078]: error: process_sign_request2: parse: invalid format
Jun 08 09:51:01 user-pc ssh-agent[1078]: error: process_sign_request2: parse: invalid format
Jun 08 09:51:11 user-pc ssh-agent[1078]: error: process_sign_request2: parse: invalid format
Jun 08 09:56:06 user-pc ssh-agent[1078]: error: process_sign_request2: parse: invalid format
Jun 08 09:56:07 user-pc ssh-agent[1078]: error: process_sign_request2: parse: invalid format
Jun 08 09:58:29 user-pc ssh-agent[1078]: error: process_sign_request2: parse: invalid format
Jun 08 09:59:43 user-pc ssh-agent[1078]: error: process_sign_request2: parse: invalid format
Jun 08 10:01:14 user-pc ssh-agent[1078]: error: process_sign_request2: parse: invalid format
Jun 08 15:43:27 user-pc systemd-coredump[70513]: Failed to connect to coredump service: Connection refused
Jun 08 15:43:28 user-pc systemd-coredump[70591]: Failed to connect to coredump service: Connection refused
Jun 08 15:43:29 user-pc pulseaudio[1212]: Error opening PCM device front:0: No such file or directory
Jun 08 15:43:29 user-pc pulseaudio[1212]: Error opening PCM device hw:2: No such file or directory
