After i updated everything now compiling a kernel takes like 6+ hours, it only uses one thread, i got 12 threads available, the previous version used all cores when compiling and only took 1 hour.
What’s wrong, where do i need to look to fix this?
Hello there
When you run the make command, you can add a -jX
parameter, where X is how many threads you want to use. So you can run:
make -j12
If you want to use all 12 (may want to leave a couple open to be used)
Source: The Linux bible
yes i know that’s in terminal, i use pamac to install the kernel anywhere i need to check to fix it?
create ~/.config/pacman/makepkg.conf
and set key MAKEFLAGS
in this file
man makepkg.conf
You could have said that to begin with. What custom kernel are you compiling and why?
https://wiki.archlinux.org/title/Makepkg#Improving_compile_times
This is what I use:
MAKEFLAGS="-j$(($(nproc)+1))"
That will use all available threads and queue the next job for when a thread becomes available. That way, no threads become idle looking for the next job.
Thank you, i found it and now it’s cooking again
