After update blue screen
it should be disabled i have never enabled it and everything worked before this
update
Edit: I checked and it was disabled
I’m very much out of my depth here - perhaps reinstall grub
(again from within chroot)
I have never experienced anything like it as a fallout from a simple update.
There is a howto or wiki or root tip or whatever it is called here on this forum.
Probably the easiest is to install install-grub within chroot (should work). Then use that to (hopefully) automatically fix GRUB issues.
can you explain that a bit more detailed, i am trying to pacman -Syu grub and then grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck tho my current efi folder is that normal
It would be:
pacman -S install-grub
then
install-grub
as far as I know. I’ll check on this as I don’t have that package or its man page on my system yet.
ok so now when i try to install /grub i get this>
WARNING: EFI directory not found! Grub couldn’t be installed.
Are you in chroot when you do this?
cat /etc/fstab
ls -al /boot
ls -al /boot/efi
Yes I was in chroot. I will be in a meeting for the next hour or so. I will try afterwards and if nothing works I suppose i will have to reinstall the os
That is always an option - if you can’t figure out what went wrong and we, from a distance, with our questions, can’t either.
There is also snapshots (timeshift …) which would enable you to just go back to when it was working and have a go again …
Wild guess. Could .pacnew files be causing an issue…?
idk how that would work since the update installed fine but maybe idk
results of cat /etc/fstab
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=432A-4DB1                            /boot/efi      vfat    umask=0077 0 2
UUID=51546615-7685-41a9-8157-1da13074770b /              ext4    defaults,noatime 0 1
UUID=d16bd066-002c-42d8-a784-057b66d73f4f swap           swap    defaults,noatime 0 0
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
/dev/disk/by-uuid/dc4d844f-b794-4916-abb1-e984f60cea90 /home/symeonkasidis/SteamDrive auto nosuid,nodev,nofail,x-gvfs-show,x-gvfs-name=SteamDrive 0 0
results of ls -al /boot
ls -al /boot
total 312944
drwxr-xr-x  5 root root      4096 Mar  5 16:57 .
drwxr-xr-x 18 root root      4096 Dec  3 08:46 ..
-rw-r--r--  1 root root    153600 Feb 12 01:25 amd-ucode.img
drwxr-xr-x  3 root root      4096 Jan  1  1970 efi
drwxr-xr-x  7 root root      4096 Mar  5 17:41 grub
-rw-------  1 root root 130099250 Mar  5 16:57 initramfs-6.13-x86_64-fallback.img
-rw-------  1 root root  44614304 Mar  5 16:57 initramfs-6.13-x86_64.img
-rw-------  1 root root  78062807 Mar  5 16:57 initramfs-6.6-x86_64-fallback.img
-rw-------  1 root root  40544961 Mar  5 16:57 initramfs-6.6-x86_64.img
-rw-r--r--  1 root root        21 Mar  4 14:20 linux613-x86_64.kver
-rw-r--r--  1 root root        21 Feb 27 14:05 linux66-x86_64.kver
drwxr-xr-x  2 root root      4096 Feb  5 23:46 memtest86+
-rw-r--r--  1 root root  13877760 Mar  5 15:10 vmlinuz-6.13-x86_64
-rw-r--r--  1 root root  13029888 Mar  5 15:10 vmlinuz-6.6-x86_64
results of ls -al /boot/efi
total 12
drwxr-xr-x 3 root root 4096 Jan  1  1970 .
drwxr-xr-x 5 root root 4096 Mar  5 16:57 ..
drwxr-xr-x 5 root root 4096 Mar  5 16:29 EFI
i dont see an easy way to fix you can mark this as closed i will have to salvage what i can and install the os again
mkay
noted -
won’t try to advise on possible fixes anymore.
except:
(you already know)
save the contents of /home/$user
and perhaps any system configurations in /etc/*
not having to start from scratch has some value
