Desktop environment does not start on load. I have to run startx
I am very new to Manjaro and new to linux on the whole. I have recently installed Manjaro through the Architect installer and selected i3 for my desktop environment. I installed Manjaro as a minimum install so I am running bare-bones. The installation went fine with no errors. I rebooted and am just left with a flashing cursor icon and nothing else. I can get to the desktop by pressing ctrl+alt+f2 to spawn a login prompt and then enter “startx”. I have rebooted a number of times and it is always the same except the ones when it shown an error saying “Failed to start light display manager”. It only shown this the one though and I was still able to get access to the desktop via startx.
During the installation of manjaro i selected the “Automatic free drivers” option for display drivers. My card is an Radeon RX 6800 and I am running kernel 5.11. Manjaro version 20.2.1
If you require any further information please let me know and also how I can provide it.
Thanks
Please provide some more information. Could you post the output of these commands:
systemctl status lightdm.service
cat ~/.xinitrc
cat /etc/mkinitcpio.conf
If you’ve got inxi installed, the output of:
inxi -Fazy
would be nice. Please post everything as code (mark the text and use </> switch)…
Thank you for the reply. Hope I formatted the output correctly!
lightdm output
lightdm.service - Light Display Manager
     Loaded: loaded (/usr/lib/systemd/system/lightdm.service; enabled; vendor preset: disabled)
     Active: failed (Result: exit-code) since Sun 2021-03-21 18:14:30 GMT; 3min 14s ago
       Docs: man:lightdm(1)
    Process: 880 ExecStart=/usr/bin/lightdm (code=exited, status=1/FAILURE)
   Main PID: 880 (code=exited, status=1/FAILURE)
Mar 21 18:14:30 mikebox systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 5.
Mar 21 18:14:30 mikebox systemd[1]: Stopped Light Display Manager.
Mar 21 18:14:30 mikebox systemd[1]: lightdm.service: Start request repeated too quickly.
Mar 21 18:14:30 mikebox systemd[1]: lightdm.service: Failed with result 'exit-code'.
Mar 21 18:14:30 mikebox systemd[1]: Failed to start Light Display Manager.
xinitrc output
#!/bin/bash
# ~/.xinitrc
# Executed by startx (run your window manager from here)
userresources=$HOME/.Xresources
usermodmap=$HOME/.Xmodmap
sysresources=/etc/X11/xinit/.Xresources
sysmodmap=/etc/X11/xinit/.Xmodmap
DEFAULT_SESSION='i3 --shmlog-size 0'
# merge in defaults and keymaps
if [ -f $sysresources ]; then
    xrdb -merge $sysresources
fi
if [ -f $sysmodmap ]; then
    xmodmap $sysmodmap
fi
if [ -f "$userresources" ]; then
    xrdb -merge "$userresources"
fi
if [ -f "$usermodmap" ]; then
    xmodmap "$usermodmap"
fi
# start some nice programs
if [ -d /etc/X11/xinit/xinitrc.d ] ; then
    for f in /etc/X11/xinit/xinitrc.d/?*.sh ; do
        [ -x "$f" ] && . "$f"
    done
    unset f
fi
get_session(){
	local dbus_args=(--sh-syntax --exit-with-session)
	case $1 in
		awesome) dbus_args+=(awesome) ;;
		bspwm) dbus_args+=(bspwm-session) ;;
		budgie) dbus_args+=(budgie-desktop) ;;
		cinnamon) dbus_args+=(cinnamon-session) ;;
		deepin) dbus_args+=(startdde) ;;
		enlightenment) dbus_args+=(enlightenment_start) ;;
		fluxbox) dbus_args+=(startfluxbox) ;;
		gnome) dbus_args+=(gnome-session) ;;
		i3|i3wm) dbus_args+=(i3 --shmlog-size 0) ;;
		jwm) dbus_args+=(jwm) ;;
		kde) dbus_args+=(startplasma-x11) ;;
		lxde) dbus_args+=(startlxde) ;;
		lxqt) dbus_args+=(lxqt-session) ;;
		mate) dbus_args+=(mate-session) ;;
		xfce) dbus_args+=(xfce4-session) ;;
		openbox) dbus_args+=(openbox-session) ;;
		*) dbus_args+=($DEFAULT_SESSION) ;;
	esac
	echo "dbus-launch ${dbus_args[*]}"
exec $(get_session "$1")
mkinicpio output
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run.  Advanced users may wish to specify all system modules
# in this array.  For instance:
#     MODULES=(piix ide_disk reiserfs)
MODULES=()
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image.  This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way.  This is useful for config files.
FILES=()
# HOOKS
# This is the most important setting in this file.  The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added.  Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
##   This setup specifies all modules in the MODULES setting above.
##   No raid, lvm2, or encrypted root is needed.
#    HOOKS=(base)
##   This setup will autodetect all modules for your system and should
##   work as a sane default
#    HOOKS=(base udev autodetect block filesystems)
##   This setup will generate a 'full' image which supports most systems.
##   No autodetection is done.
#    HOOKS=(base udev block filesystems)
##   This setup assembles a pata mdadm array with an encrypted root FS.
##   Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
#    HOOKS=(base udev block mdadm encrypt filesystems)
##   This setup loads an lvm2 volume group on a usb device.
#    HOOKS=(base udev block lvm2 filesystems)
##   NOTE: If you have /usr on a separate partition, you MUST include the
#    usr, fsck and shutdown hooks.
HOOKS=(base udev autodetect modconf block filesystems keyboard fsck)
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
#COMPRESSION="zstd"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
inxi output
  Kernel: 5.11.6-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
  root=UUID=fe444101-9e46-477a-84d5-56af313c9fc1 rw quiet udev.log_priority=3
  Console: tty 2 DM: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH (MS-7C95) v: 1.0
  serial: <filter> UEFI: American Megatrends LLC. v: 2.71 date: 02/26/2021
  Info: 8-Core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
  family: 19 (25) model-id: 21 (33) stepping: N/A microcode: A201009 cache:
  L2: 4 MiB
  bogomips: 121636
  Speed: 3592 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
  1: 3592 2: 2206 3: 2575 4: 2875 5: 2874 6: 2927 7: 2470 8: 2842 9: 2875
  10: 2875 11: 2474 12: 2554 13: 2873 14: 2876 15: 3597 16: 2875
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  STIBP: always-on, RSB filling
  Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: XFX Limited
  driver: amdgpu v: kernel bus-ID: 2d:00.0 chip-ID: 1002:73bf class-ID: 0300
  Display: server: X.org 1.20.10 driver: loaded: ati,radeon
  unloaded: modesetting alternate: fbdev,vesa tty: 286x60
  Message: Advanced graphics data unavailable in console. Try -G --display
  Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 2d:00.1
  chip-ID: 1002:ab28 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487
  class-ID: 0403
  Sound Server-1: ALSA v: k5.11.6-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 14.2 running: no
  Device-1: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
  v: kernel port: e000 bus-ID: 05:00.0 chip-ID: 10ec:818b class-ID: 0280
  IF: wlp5s0 state: down mac: <filter>
  vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus-ID: 2a:00.0
  IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.73 TiB used: 36.85 GiB (1.3%)
  model: WDS500G2B0C-00PXH0 size: 465.76 GiB block-size: physical: 512 B
  logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
  rev: 211070WD temp: 32.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Western Digital
  rev: 211210WD temp: 33.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
  rotation: 7200 rpm serial: <filter> rev: 0001 scheme: GPT
  ID-1: / raw-size: 465.26 GiB size: 456.96 GiB (98.22%)
  used: 36.85 GiB (8.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:3
  used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
  ID-1: swap-1 type: file size: 31.35 GiB used: 0 KiB (0.0%) priority: -2
  file: /swapfile
  System Temperatures: cpu: 32.9 C mobo: N/A gpu: amdgpu temp: 46.0 C
  mem: 46.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
  Processes: 283 Uptime: 4m wakeups: 0 Memory: 31.35 GiB
  used: 747.4 MiB (2.3%) Init: systemd v: 247 tool: systemctl Compilers:
  gcc: 10.2.0 Packages: pacman: 770 lib: 217 Shell: Bash (login) v: 5.1.0
  running-in: tty 2 inxi: 3.3.03
Personally I’m neither running xorg nor lightdm, and I’ve got different gpu’s, so I’m anything but an expert for your issue.
From what I can tell, your ~/.xinitrc seems to be ok.
Adding amdgpu radeon to your kernel modules might help…
Not sure what to do with the lightdm.service error message…
I’m sure there are some folks here who have more profound ideas.
Thanks for taking the time anyway, much appreciated
More information from the lightdm log x-0.log file showing a screens not found error:
[+0.00s] DEBUG: Logging to /var/log/lightdm/lightdm.log
X.Org X Server 1.20.10
Build Operating System: Linux Manjaro Linux
Current Operating System: Linux mikebox 5.11.6-1-MANJARO #1 SMP PREEMPT Thu Mar 11 19:05:51 UTC 2021 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=fe444101-9e46-477a-84d5-56af313c9fc1 rw quiet udev.log_priority=3
Build Date: 16 December 2020  10:33:32PM
Current version of pixman: 0.40.0
        Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Sun Mar 21 18:14:30 2021
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
Do u have ‘lightdm-gtk-greeter’ installed?
No it doesnt look like I do, should I have?
More info from xorg.0.log shows more errors
[     4.315]
[     4.315] Build Operating System: Linux Manjaro Linux
[     4.315] Current Operating System: Linux mikebox 5.11.6-1-MANJARO #1 SMP PREEMPT Thu Mar 11 19:05:51 UTC 2021 x86_64
[     4.315] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=fe444101-9e46-477a-84d5-56af313c9fc1 rw quiet udev.log_priority=3
[     4.315] Build Date: 16 December 2020  10:33:32PM
[     4.315]
[     4.315] Current version of pixman: 0.40.0
[     4.315]    Before reporting problems, check http://wiki.x.org
[     4.315] Markers: (--) probed, (**) from config file, (==) default setting,
[     4.315] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Mar 21 18:14:30 2021
[     4.315] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     4.315] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     4.315] (==) No Layout section.  Using the first Screen section.
[     4.315] (==) No screen section available. Using defaults.
[     4.315] (**) |-->Screen "Default Screen Section" (0)
[     4.315] (**) |   |-->Monitor "<default monitor>"
[     4.315] (==) No monitor specified for screen "Default Screen Section".
[     4.315] (==) Automatically adding devices
[     4.315] (==) Automatically enabling devices
[     4.315] (==) Automatically adding GPU devices
[     4.315] (==) Automatically binding GPU devices
[     4.315] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     4.315] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     4.315]    Entry deleted from font path.
[     4.315] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     4.315] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     4.315] (==) FontPath set to:
        /usr/share/fonts/misc,
        /usr/share/fonts/TTF,
        /usr/share/fonts/OTF
[     4.315] (==) ModulePath set to "/usr/lib/xorg/modules"
[     4.315] (II) The server relies on udev to provide the list of input devices.
[     4.315] (II) Module ABI versions:
[     4.315]    X.Org ANSI C Emulation: 0.4
[     4.315]    X.Org Video Driver: 24.1
[     4.315]    X.Org XInput driver : 24.1
[     4.315]    X.Org Server Extension : 10.0
[     4.315] (++) using VT number 7
[     4.315] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     4.317] (--) PCI:*(45@0:0:0) 1002:73bf:1eae:6705 rev 195, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xfcc00000/1048576, I/O @ 0x0000f000/256, BIOS @ 0x????????/131072
[     4.317] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     4.317] (II) LoadModule: "glx"
[     4.317] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     4.317] (II) Module glx: vendor="X.Org Foundation"
[     4.317]    compiled for 1.20.10, module version = 1.0.0
[     4.317]    ABI class: X.Org Server Extension, version 10.0
[     4.317] (==) Matched ati as autoconfigured driver 0
[     4.317] (==) Matched modesetting as autoconfigured driver 1
[     4.317] (==) Matched fbdev as autoconfigured driver 2
[     4.317] (==) Matched vesa as autoconfigured driver 3
[     4.317] (==) Assigned the driver to the xf86ConfigLayout
[     4.317] (II) LoadModule: "ati"
[     4.318] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[     4.318] (II) Module ati: vendor="X.Org Foundation"
[     4.318]    compiled for 1.20.8, module version = 19.1.0
[     4.318]    Module class: X.Org Video Driver
[     4.318]    ABI class: X.Org Video Driver, version 24.1
[     4.318] (II) LoadModule: "radeon"
[     4.318] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[     4.318] (II) Module radeon: vendor="X.Org Foundation"
[     4.318] (II) LoadModule: "modesetting"
[     4.318] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     4.318] (II) Module modesetting: vendor="X.Org Foundation"
[     4.318]    compiled for 1.20.10, module version = 1.20.10
[     4.318] (II) LoadModule: "fbdev"
[     4.318] (WW) Warning, couldn't open module fbdev
[     4.318] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     4.318] (II) LoadModule: "vesa"
[     4.318] (WW) Warning, couldn't open module vesa
[     4.318] (EE) Failed to load module "vesa" (module does not exist, 0)
[     4.318] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
        ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
        ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
        ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
        ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
        ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
        ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
        ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
        ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
        ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
        ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
        ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
        ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
        ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
        ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
        ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
        ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
        ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
        ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
        ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
        ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
        ATI Radeon 9800PRO, ATI Radeon 9800XT,
        ATI Radeon Mobility 9600/9700 (M10/M11),
        ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
        ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
        ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
        ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
        ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
        ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
        ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
        ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
        ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
        ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
        ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
        ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
        ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
        ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
        ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
        ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
        ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
        ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
        ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
        ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
        ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
        ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
        ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
        ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
        ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
        ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
        ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
        ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
        ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
        ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
        ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
        ATI FireGL V3350, ATI Mobility Radeon X1450,
        ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
        ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
        ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
        ATI FireGL V3400, ATI Mobility FireGL V5250,
        ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
        ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
        ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
        ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
        ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
        ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
        ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
        ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
        ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
        ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
        ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
        ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
        AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
        ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
        ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
        ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
        ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
        ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
        ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
        ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
        ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
        ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
        ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
        ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
        ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
        ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
        ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
        ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
        ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
        ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
        ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
        ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
        ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
        ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
        ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
        ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
        ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
        ATI FireGL V3600, ATI Radeon HD 2600 LE,
        ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
        ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
        ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
        ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
        ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
        ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
        ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
        ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
        ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
        ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
        ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
        AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
        AMD Radeon HD 6300 Series Graphics,
        AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
        ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
        AMD Firestream 9350, ATI Radeon HD 5800 Series,
        ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
        ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
        ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
        ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
        REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
        ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
        AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
        AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
        ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
        MULLINS, KAVERI, HAWAII
[     4.319] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     4.319] (EE) open /dev/dri/card0: No such file or directory
[     4.319] (WW) Falling back to old probe method for modesetting
[     4.319] (EE) Screen 0 deleted because of no matching config section.
[     4.319] (II) UnloadModule: "modesetting"
[     4.319] (EE) Device(s) detected, but none match those in the config file.
[     4.319] (EE)
Fatal server error:
[     4.319] (EE) no screens found(EE)
[     4.319] (EE)
 for help.
[     4.319] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[     4.319] (EE)
[     4.319] (EE) Server terminated with error (1). Closing log file.
I had this problem and fixed it by adding “amdgpu radeon” to the modules section of /etc/mkinitcpio.conf and regenerating the image.
How do I go about regenerating the image? Thanks
Well, the way I did it was by installing a new kernel.
You could follow the instructions on the Manjaro Wiki where it talks about installing kernels with mhwd (I can’t insert links apparently) and reinstall your 5.11 kernel. It will regenerate the image in the process of installing your new kernel.
You were spot on the money. Thanks for your help, much appreciated!
Awesome! Glad it worked for you.
Thanks! Had the same issue and your help fixed my system too :smile:
:laughing: Awesome!
You run sudo mkinitcpio -P
The reason it worked after an kernel update is that above command is automatically run to generate the new images.
