Hello ARM community.
Sorry for the long wait. But here’s another update for you all.
Some highlights:
- Most of our kernels got updated
- QEMU got updated to 7.0.0 and with that had a big package split
- And LibreOffice released a new point release with 7.3.3
- Code updated to 1.67.0
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Wed May 11 08:23:49 CEST 2022)
- arm-testing community aarch64: 257 new and 243 removed package(s)
- arm-testing core aarch64: 34 new and 34 removed package(s)
- arm-testing extra aarch64: 267 new and 205 removed package(s)
- arm-testing kde-unstable aarch64: 19 new and 18 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-05-01 2022-05-11
callaudiod-hybris 0.1.0-2 0.1.4-1
code 1.66.2-1 1.67.0-1
electron 18.2.0-1 18.2.1-1
electron12 12.2.2-2 12.2.3-1
electron13 13.6.8-1 13.6.9-1
electron14 14.2.8-1 14.2.9-1
electron15 15.5.3-1 15.5.4-1
electron16 16.2.4-1 16.2.5-1
electron17 17.4.2-1 17.4.3-1
element-desktop 1.10.11-1 1.10.12-2
element-web 1.10.11-1 1.10.12-2
gnome-control-center-mobile 42.1-4 42.1-5
kodi 19.4-1 19.4-2
kodi-dev 19.4-1 19.4-2
kodi-eventclients 19.4-1 19.4-2
kodi-rpi 19.4-1 19.4.1-2
kodi-rpi-dev 19.4-1 19.4.1-2
kodi-rpi-eventclients 19.4-1 19.4.1-2
kodi-rpi-tools-texturepacker 19.4-1 19.4.1-2
kodi-tools-texturepacker 19.4-1 19.4-2
ofono-hybris 1.29-1 1.29+git3-1
phoc 0.13.1+22+g8d3f7a0-1 0.13.1+25+ga362cd7-2
phoc-hybris 645.81f76ea-4 0.10.0+1+droidian0-1
phosh0.17.0+138+gd900b66d-20.17.0+140+ge00bc029-1
phosh-hybris 0.14.1+23+g8fc370d-10.17.0+113+gad03627e-1
pika-backup0.4.0+beta.5+1+gcb65d8c-1 0.4.0.rc.1-1
android-headers-30 - 11.0.0-1
libhybris-glvnd - 1569.03c5ec6-1
:: Different sync package(s) in repository community aarch64
aardvark-dns 1.0.2-1 1.0.3-1
acme.sh 3.0.3-1 3.0.4-1
aeolus 0.9.9-1 0.10.4-1
ansible 5.7.0-1 5.7.1-1
ansible-lint 6.0.2-5 6.1.0-1
avr-gcc 11.3.0-1 12.1.0-1
avrdude 1:6.4-1 1:7.0-1
aws-cli 1.22.87-1 1.23.10-1
babel-cli 7.17.6-1 7.17.10-1
babel-core 7.17.9-1 7.17.10-1
babeld 1.11-1 1.12-1
baresip 2.0.2-1 2.3.0-1
bash-language-server 2.0.0-5 2.1.0-1
batctl 2022.0-1 2022.1-1
blanket 0.6.0-1 0.6.0-2
blockdiag 2.0.1-6 3.0.0-1
broot 1.11.1-2 1.12.0-1
buildah 1.25.1-2 1.26.1-1
buildkit 0.10.2-1 0.10.3-1
caddy 2.4.6-1 2.5.1-1
calibre 5.42.0-1 5.42.0-2
cargo-expand 1.0.18-1 1.0.19-1
cargo-udeps 0.1.27-1 0.1.28-1
chafa 1.10.2-1 1.10.3-1
charm 0.12.0-1 0.12.1-1
chezmoi 2.15.2-1 2.15.4-1
clash 1.10.0-2 1.10.6-1
cloud-guest-utils 0.32-1 0.32-2
cloud-image-utils 0.32-1 0.32-2
cloud-utils 0.32-1 0.32-2
cni-plugins 1.1.1-1 1.1.1-2
coffeescript 2.6.1-1 2.7.0-1
coin-or-cbc 2.10.7-3 2.10.8-1
coin-or-cgl 0.60.5-1 0.60.6-1
containerd 1.6.3-1 1.6.4-1
containers-common 1:0.47.4-4 1:0.48.0-1
criu 3.16.1-4 3.17-1
ctop 0.7.7-1 0.7.7-2
distrobuilder 2.0-1 2.1-1
docker 1:20.10.14-1 1:20.10.15-1
docker-scan 0.17.0-1 0.17.0-2
doctl 1.74.0-1 1.75.0-1
dovecot 2.3.18-2 2.3.19-1
dovecot-fts-elastic 1.1.0-1 1.1.0-2
dovecot-fts-xapian 1.5.5-1 1.5.5-2
feeluown 3.8.4-1 3.8.5-1
fx 23.0.1-1 24.0.0-1
fzf 0.30.0-1 0.30.0-2
gcompris-qt 2.4-1 2.4-2
gdal 3.4.0-5 3.4.0-6
gerbera 1.10.0-2 1.11.0-1
gfold 3.0.0-1 4.0.0-1
gimagereader-common 3.4.0-3 3.4.0-4
gimagereader-gtk 3.4.0-3 3.4.0-4
gimagereader-qt 3.4.0-3 3.4.0-4
gimp-plugin-gmic 3.1.0-1 3.1.1-1
git-lfs 3.1.4-1 3.1.4-2
github-cli 2.9.0-2 2.10.1-1
gnuradio 3.10.2.0-2 3.10.2.0-4
gnuradio-companion 3.10.2.0-2 3.10.2.0-4
go-md2man 2.0.2-1 2.0.2-2
go-tools 4:0.1.10-1 4:0.1.10-2
grobi 0.6.0-2 0.6.0-3
ibus-table 1.16.0-1 1.16.3-1
icewm 2.9.6-1 2.9.7-1
inadyn 2.9.1-3 2.9.1-4
jupyter-nbclient 0.6.2-1 0.6.3-1
just 1.1.2-1 1.1.3-1
krename 5.0.1-3 5.0.1-4
krita-plugin-gmic 3.0.2.2-2 3.0.2.2-3
libavif 0.9.3-1 0.10.1-1
liblxqt 1.1.0-2 1.1.0-3
libqtxdg 3.9.0-1 3.9.1-1
libre 2.2.2-1 2.3.0-1
librem 2.0.1-1 2.3.0-1
librepo 1.14.2-1 1.14.3-1
libvirt 1:8.2.0-7 1:8.3.0-1
libvirt-storage-gluster 1:8.2.0-7 1:8.3.0-1
libvirt-storage-iscsi-direct 1:8.2.0-7 1:8.3.0-1
libxdp 1.2.3-7 1.2.3-8
libyuv r2266+eb6e7bb6-1.1 r2322+3aebf69d-1.1
lsp-plugins 1.2.0-2 1.2.1-1
lsp-plugins-docs 1.2.0-2 1.2.1-1
lxd 5.0.0-2 5.1-2
lxqt-session 1.1.0-1 1.1.1-1
lzlib 1.13-1 1.13-2
matrix-appservice-irc 0.34.0-1 0.34.0-2
matterbridge 1.25.0-3 1.25.1-1
maturin 0.12.14-1 0.12.15-1
mediastreamer 5.1.28-1 5.1.29-1
meilisearch 0.26.1-1 0.27.0-1
microsoft-gsl 3.1.0-1 4.0.0-1
mkosi 10-2 12-1
mvt 1.4.10-1 1.5.4-1
netavark 1.0.2-1 1.0.3-2
nextcloud-app-bookmarks 1:10.3.1-1 1:10.3.1-2
nextcloud-app-calendar 1:3.2.2-1 1:3.3.0-1
nextcloud-client 2:3.4.4-2 2:3.5.0-1
nextcloud-client-cloudproviders 2:3.4.4-2 2:3.5.0-1
nicotine+ 3.2.2-1 3.2.2-2
nodejs-yaml 1.10.2-1 2.0.0-1
nomad 1.2.6-1.1 1.2.6-3
operator-sdk 1.18.1-2 1.20.0-1
osbuild 55-1 55-2
papirus-icon-theme 20220302-1 20220508-1
pigeonhole 0.5.18-1 0.5.19-1
podman 4.0.3-2 4.1.0-1
podman-compose 1.0.3-1 1.0.3-2
podman-dnsname 1.3.1-1 1.3.1-2
podman-docker 4.0.3-2 4.1.0-1
podofo 0.9.7-1 0.9.8-1
procs 0.12.1-1 0.12.2-1
pyright 1.1.244-1 1.1.245-1
python-aiobotocore 2.1.0-1 2.2.0-1
python-ansible-compat 2.0.2-1 2.0.3-1
python-astroid 2.11.4-1 2.11.5-1
python-boolean.py 3.8-5 4.0-1
python-botocore 1.24.32-1 1.25.10-1
python-canonicaljson 1.6.0-1 1.6.1-1
python-engineio 4.3.1-1 4.3.2-1
python-flask-compress 1.11-1 1.12-1
python-gdal 3.4.0-5 3.4.0-6
python-json5 0.9.6-3 0.9.8-1
python-jupyter_client 7.3.0-1 7.3.1-1
python-kajiki 0.9.0-1 0.9.1-1
python-kubernetes 23.3.0-1 23.6.0-1
python-license-expression 21.6.14-4 21.6.14-5
python-markdown 3.3.6-3 3.3.7-1
python-matplotlib 3.5.1-2 3.5.2-1
python-minio 7.1.7-1 7.1.8-1
python-moto 3.1.7-1 3.1.8-1
python-pbr 5.8.1-1 5.9.0-1
python-pdfminer 20220319-1 20220506-1
python-pint 0.19-1 0.19.1-1
python-pre-commit 2.18.1-1 2.19.0-1
python-pyroute2 0.5.19-5 0.6.9-1
python-pytest-localserver 0.5.1-3 0.6.0-1
python-qiniu 7.6.0-1 7.7.0-1
python-rich 12.3.0-1 12.4.1-1
python-socketio 5.5.2-1 5.6.0-1
python-tldextract 3.2.1-1 3.3.0-1
python-tox 3.24.5-1 3.25.0-1
python-websockets 10.2-1 10.3-1
python-yara 4.1.0-3 4.2.0-1
python-zope-security 5.1.1-5 5.2-1
qcad 3.27.3.0-1 3.27.4.0-1
qt5-quickcontrols-nemo 5.6.5-2 5.6.6-1
r 4.2.0-2 4.2.0-3
repo 2.24.1-1 2.25-1
rkward 0.7.3-1 0.7.3-2
rnote 0.4.0-1 0.5.1-1
rocksdb 7.0.4-1 7.2.2-1
ruby-msgpack 1.4.5-1 1.5.1-1
ruby-nokogiri 1.13.4-1 1.13.6-1
ruby-stringio 3.0.1-2 3.0.2-1
runc 1.1.1-1 1.1.1-2
rust-analyzer 20220502-1 20220509-1
scribus 1.5.8-4 1.5.8-6
seqdiag 2.0.0-6 3.0.0-1
skopeo 1.7.0-1 1.8.0-1
smokeping 2.8.2-1 2.8.2-2
snapper 0.10.1-1 0.10.2-1
spirv-headers 1:1.3.204.1-1 1:1.3.211.0-1
spirv-llvm-translator13.0.0.r24+gf1372c87-113.0.0.r27+gd7a03044-1
sqlfluff 0.13.0-1 0.13.1-1
staticcheck 2022.1.1-1 2022.1.1-2
step-ca 0.19.0-1 0.19.0-2
streamlink 3.1.1-1 4.0.1-1
stunnel 5.63-1 5.64-1
syncthing 1.20.0-1 1.20.1-1
syncthing-relaysrv 1.20.0-1 1.20.1-1
ttc-iosevka 15.2.0-1 15.3.0-1
ttc-iosevka-aile 15.2.0-1 15.3.0-1
ttc-iosevka-curly 15.2.0-1 15.3.0-1
ttc-iosevka-curly-slab 15.2.0-1 15.3.0-1
ttc-iosevka-etoile 15.2.0-1 15.3.0-1
ttc-iosevka-slab 15.2.0-1 15.3.0-1
ttc-iosevka-ss01 15.2.0-1 15.3.0-1
ttc-iosevka-ss02 15.2.0-1 15.3.0-1
ttc-iosevka-ss03 15.2.0-1 15.3.0-1
ttc-iosevka-ss04 15.2.0-1 15.3.0-1
ttc-iosevka-ss05 15.2.0-1 15.3.0-1
ttc-iosevka-ss06 15.2.0-1 15.3.0-1
ttc-iosevka-ss07 15.2.0-1 15.3.0-1
ttc-iosevka-ss08 15.2.0-1 15.3.0-1
ttc-iosevka-ss09 15.2.0-1 15.3.0-1
ttc-iosevka-ss10 15.2.0-1 15.3.0-1
ttc-iosevka-ss11 15.2.0-1 15.3.0-1
ttc-iosevka-ss12 15.2.0-1 15.3.0-1
ttc-iosevka-ss13 15.2.0-1 15.3.0-1
ttc-iosevka-ss14 15.2.0-1 15.3.0-1
ttc-iosevka-ss15 15.2.0-1 15.3.0-1
ttc-iosevka-ss16 15.2.0-1 15.3.0-1
ttc-iosevka-ss17 15.2.0-1 15.3.0-1
ttc-iosevka-ss18 15.2.0-1 15.3.0-1
ugrep 3.7.9-2 3.7.11-1
upterm 0.7.5-3 0.8.2-1
v2ray-domain-list-community 20220501162639-1 20220509150921-1
v2ray-geoip 202204280105-1 202205050051-1
vc-intrinsics 0.3.0-1 0.4.1-1
verilator 4.220-1 4.222-1
vit 2.1.0-2 2.2.0-1
vscode-css-languageserver 1.66.1-1 1.67.0-1
vscode-html-languageserver 1.66.1-1 1.67.0-1
vscode-json-languageserver 1.66.1-1 1.67.0-1
vultr-cli 2.13.0-1 2.14.0-1
webp-pixbuf-loader 0.0.4-1 0.0.4-2
when 1.1.40-3 1.1.41-1
wireshark-cli 3.6.4-1 3.6.5-1
wireshark-qt 3.6.4-1 3.6.5-1
xdp-tools 1.2.3-7 1.2.3-8
xmms20.8DrO_o.7391.dedc33d7-7 0.9.1-1
xpad 5.7.0-1 5.7.0-2
xsimd 8.0.5-1 8.1.0-1
yara 4.1.3-1 4.2.1-1
you-get 0.4.1555-2 0.4.1602-1
ayatana-ido - 0.9.1-2
cl-flexi-streams - 1.0.19.r4.g74a1027-1
cl-trivial-gray-streams - r70.g2b3823e-1
firecracker - 1.1.0-1
firecracker-docs - 1.1.0-1
gitlab-exporter - 0.1.0-1
libayatana-appindicator - 0.5.91-2
libayatana-indicator - 0.9.1-2
polybar - 3.6.3-2
python-versioningit - 1.1.1-2
qtxdg-tools - 3.9.1-1
quicklisp - 20150128-1
:: Different overlay package(s) in repository core aarch64
linux 5.17.5-4 5.17.6-1
linux-clockworkpi-a06 5.17.5-1 5.17.6-1
linux-clockworkpi-a06-headers 5.17.5-1 5.17.6-1
linux-headers 5.17.5-4 5.17.6-1
linux-lts 5.15.37-1 5.15.38-1
linux-lts-headers 5.15.37-1 5.15.38-1
linux-pinephone 5.17.5-1 5.17.6-2
linux-pinephone-headers 5.17.5-1 5.17.6-2
linux-pinephonepro 5.17.5-1 5.17.6-2
linux-pinephonepro-headers 5.17.5-1 5.17.6-2
linux-rc 5.18.rc5-1 5.18.rc6-1
linux-rc-headers 5.18.rc5-1 5.18.rc6-1
linux-rpi4 5.15.36-1 5.15.38-1
linux-rpi4-headers 5.15.36-1 5.15.38-1
linux-rpi4-mainline 5.17.5-1 5.17.6-1
linux-rpi4-mainline-headers 5.17.5-1 5.17.6-1
linux-rpi4-rc 5.18.rc5-1 5.18.rc6-1
linux-rpi4-rc-headers 5.18.rc5-1 5.18.rc6-1
manjaro-keyring 20220509-1 20220509-2
raspberrypi-bootloader 20220419-1 20220509-1
raspberrypi-bootloader-x 20220419-1 20220509-1
uboot-opi3-lts 2022.04-1 2022.04-3
uboot-pinebookpro-bsp 1.24.126-1 1.24.126-2
uboot-station-p2 2022.01.rc4-1 2022.01.rc4-2
:: Different sync package(s) in repository core aarch64
gnupg 2.2.35-1 2.2.35-2
hwdata 0.358-1 0.359-1
lemon 3.38.3-1 3.38.4-1
libunistring 0.9.10-3 1.0-1
linux-api-headers 5.16.8-1 5.17.5-2
sqlite 3.38.3-1 3.38.4-1
sqlite-analyzer 3.38.3-1 3.38.4-1
sqlite-doc 3.38.3-1 3.38.4-1
sqlite-tcl 3.38.3-1 3.38.4-1
xfsprogs 5.15.0-2 5.16.0-1
:: Different overlay package(s) in repository extra aarch64
mesa-git22.2.0_devel.153080.53fe6f10846-122.2.0_devel.153441.56070d33225-1
pyside2-es2 5.15.3-1 5.15.3-3
python-es2-pyqt5 5.15.6-6.1 5.15.6-7.1
qt5-es2-base 5.15.3+kde+r137-2 5.15.3+kde+r145-1
qt5-es2-wayland 5.15.3+kde+r41-1 5.15.3+kde+r44-1
qt5-es2-xcb-private-headers 5.15.3+kde+r137-2 5.15.3+kde+r145-1
:: Different sync package(s) in repository extra aarch64
archboot-arm 2022.05-22 2022.05-44
calligra 3.2.1-32 3.2.1-33
clamav 0.104.2-1 0.105.0-1
dav1d 0.9.2-1 1.0.0-1
dav1d-doc 0.9.2-1 1.0.0-1
ffmpeg 2:5.0-6 2:5.0-7
ffmpeg4.4 4.4.1-4 4.4.1-5
gd 2.3.3-3 2.3.3-4
gimp 2.10.30-2 2.10.30-3
git 2.36.0-1 2.36.1-1
glibmm-2.68 2.72.0-1 2.72.1-1
glibmm-2.68-docs 2.72.0-1 2.72.1-1
gnome-shell 1:42.0-1 1:42.1-1
gnome-shell-extensions 42.0-1 42.1-1
gnu-efi 3.0.14-3 3.0.14-4
gspell 1.10.0-1 1.10.0-2
imagemagick 7.1.0.32-1 7.1.0.33-1
imagemagick-doc 7.1.0.32-1 7.1.0.33-1
inkscape 1.1.2-2 1.1.2-3
ipp-usb 0.9.20-2 0.9.21-1
jdk-openjdk 18.0.1.u10-1 18.0.1.1.u2-1
jre-openjdk 18.0.1.u10-1 18.0.1.1.u2-1
jre-openjdk-headless 18.0.1.u10-1 18.0.1.1.u2-1
kexec-tools 2.0.23-1 2.0.24-1
kimageformats 5.93.0-1 5.93.0-2
kitinerary 22.04.0-1 22.04.0-2
libappimage 1.0.4-1 1.0.4-2
libnice 0.1.18-2 0.1.19-1
libnotify 0.7.11-1 0.7.11-2
libreoffice-fresh 7.3.2-2 7.3.3-2
libreoffice-fresh-af 7.3.2-1 7.3.3-1
libreoffice-fresh-am 7.3.2-1 7.3.3-1
libreoffice-fresh-ar 7.3.2-1 7.3.3-1
libreoffice-fresh-as 7.3.2-1 7.3.3-1
libreoffice-fresh-ast 7.3.2-1 7.3.3-1
libreoffice-fresh-be 7.3.2-1 7.3.3-1
libreoffice-fresh-bg 7.3.2-1 7.3.3-1
libreoffice-fresh-bn 7.3.2-1 7.3.3-1
libreoffice-fresh-bn-in 7.3.2-1 7.3.3-1
libreoffice-fresh-bo 7.3.2-1 7.3.3-1
libreoffice-fresh-br 7.3.2-1 7.3.3-1
libreoffice-fresh-brx 7.3.2-1 7.3.3-1
libreoffice-fresh-bs 7.3.2-1 7.3.3-1
libreoffice-fresh-ca 7.3.2-1 7.3.3-1
libreoffice-fresh-ca-valencia 7.3.2-1 7.3.3-1
libreoffice-fresh-ckb 7.3.2-1 7.3.3-1
libreoffice-fresh-cs 7.3.2-1 7.3.3-1
libreoffice-fresh-cy 7.3.2-1 7.3.3-1
libreoffice-fresh-da 7.3.2-1 7.3.3-1
libreoffice-fresh-de 7.3.2-1 7.3.3-1
libreoffice-fresh-dgo 7.3.2-1 7.3.3-1
libreoffice-fresh-dsb 7.3.2-1 7.3.3-1
libreoffice-fresh-dz 7.3.2-1 7.3.3-1
libreoffice-fresh-el 7.3.2-1 7.3.3-1
libreoffice-fresh-en-gb 7.3.2-1 7.3.3-1
libreoffice-fresh-en-za 7.3.2-1 7.3.3-1
libreoffice-fresh-eo 7.3.2-1 7.3.3-1
libreoffice-fresh-es 7.3.2-1 7.3.3-1
libreoffice-fresh-et 7.3.2-1 7.3.3-1
libreoffice-fresh-eu 7.3.2-1 7.3.3-1
libreoffice-fresh-fa 7.3.2-1 7.3.3-1
libreoffice-fresh-fi 7.3.2-1 7.3.3-1
libreoffice-fresh-fr 7.3.2-1 7.3.3-1
libreoffice-fresh-fur 7.3.2-1 7.3.3-1
libreoffice-fresh-fy 7.3.2-1 7.3.3-1
libreoffice-fresh-ga 7.3.2-1 7.3.3-1
libreoffice-fresh-gd 7.3.2-1 7.3.3-1
libreoffice-fresh-gl 7.3.2-1 7.3.3-1
libreoffice-fresh-gu 7.3.2-1 7.3.3-1
libreoffice-fresh-gug 7.3.2-1 7.3.3-1
libreoffice-fresh-he 7.3.2-1 7.3.3-1
libreoffice-fresh-hi 7.3.2-1 7.3.3-1
libreoffice-fresh-hr 7.3.2-1 7.3.3-1
libreoffice-fresh-hsb 7.3.2-1 7.3.3-1
libreoffice-fresh-hu 7.3.2-1 7.3.3-1
libreoffice-fresh-id 7.3.2-1 7.3.3-1
libreoffice-fresh-is 7.3.2-1 7.3.3-1
libreoffice-fresh-it 7.3.2-1 7.3.3-1
libreoffice-fresh-ja 7.3.2-1 7.3.3-1
libreoffice-fresh-ka 7.3.2-1 7.3.3-1
libreoffice-fresh-kab 7.3.2-1 7.3.3-1
libreoffice-fresh-kk 7.3.2-1 7.3.3-1
libreoffice-fresh-km 7.3.2-1 7.3.3-1
libreoffice-fresh-kmr-latn 7.3.2-1 7.3.3-1
libreoffice-fresh-kn 7.3.2-1 7.3.3-1
libreoffice-fresh-ko 7.3.2-1 7.3.3-1
libreoffice-fresh-kok 7.3.2-1 7.3.3-1
libreoffice-fresh-ks 7.3.2-1 7.3.3-1
libreoffice-fresh-lb 7.3.2-1 7.3.3-1
libreoffice-fresh-lo 7.3.2-1 7.3.3-1
libreoffice-fresh-lt 7.3.2-1 7.3.3-1
libreoffice-fresh-lv 7.3.2-1 7.3.3-1
libreoffice-fresh-mai 7.3.2-1 7.3.3-1
libreoffice-fresh-mk 7.3.2-1 7.3.3-1
libreoffice-fresh-ml 7.3.2-1 7.3.3-1
libreoffice-fresh-mn 7.3.2-1 7.3.3-1
libreoffice-fresh-mni 7.3.2-1 7.3.3-1
libreoffice-fresh-mr 7.3.2-1 7.3.3-1
libreoffice-fresh-my 7.3.2-1 7.3.3-1
libreoffice-fresh-nb 7.3.2-1 7.3.3-1
libreoffice-fresh-ne 7.3.2-1 7.3.3-1
libreoffice-fresh-nl 7.3.2-1 7.3.3-1
libreoffice-fresh-nn 7.3.2-1 7.3.3-1
libreoffice-fresh-nr 7.3.2-1 7.3.3-1
libreoffice-fresh-nso 7.3.2-1 7.3.3-1
libreoffice-fresh-oc 7.3.2-1 7.3.3-1
libreoffice-fresh-om 7.3.2-1 7.3.3-1
libreoffice-fresh-or 7.3.2-1 7.3.3-1
libreoffice-fresh-pa-in 7.3.2-1 7.3.3-1
libreoffice-fresh-pl 7.3.2-1 7.3.3-1
libreoffice-fresh-pt 7.3.2-1 7.3.3-1
libreoffice-fresh-pt-br 7.3.2-1 7.3.3-1
libreoffice-fresh-ro 7.3.2-1 7.3.3-1
libreoffice-fresh-ru 7.3.2-1 7.3.3-1
libreoffice-fresh-rw 7.3.2-1 7.3.3-1
libreoffice-fresh-sa-in 7.3.2-1 7.3.3-1
libreoffice-fresh-sat 7.3.2-1 7.3.3-1
libreoffice-fresh-sd 7.3.2-1 7.3.3-1
libreoffice-fresh-sdk 7.3.2-2 7.3.3-2
libreoffice-fresh-si 7.3.2-1 7.3.3-1
libreoffice-fresh-sid 7.3.2-1 7.3.3-1
libreoffice-fresh-sk 7.3.2-1 7.3.3-1
libreoffice-fresh-sl 7.3.2-1 7.3.3-1
libreoffice-fresh-sq 7.3.2-1 7.3.3-1
libreoffice-fresh-sr 7.3.2-1 7.3.3-1
libreoffice-fresh-sr-latn 7.3.2-1 7.3.3-1
libreoffice-fresh-ss 7.3.2-1 7.3.3-1
libreoffice-fresh-st 7.3.2-1 7.3.3-1
libreoffice-fresh-sv 7.3.2-1 7.3.3-1
libreoffice-fresh-sw-tz 7.3.2-1 7.3.3-1
libreoffice-fresh-szl 7.3.2-1 7.3.3-1
libreoffice-fresh-ta 7.3.2-1 7.3.3-1
libreoffice-fresh-te 7.3.2-1 7.3.3-1
libreoffice-fresh-tg 7.3.2-1 7.3.3-1
libreoffice-fresh-th 7.3.2-1 7.3.3-1
libreoffice-fresh-tn 7.3.2-1 7.3.3-1
libreoffice-fresh-tr 7.3.2-1 7.3.3-1
libreoffice-fresh-ts 7.3.2-1 7.3.3-1
libreoffice-fresh-tt 7.3.2-1 7.3.3-1
libreoffice-fresh-ug 7.3.2-1 7.3.3-1
libreoffice-fresh-uk 7.3.2-1 7.3.3-1
libreoffice-fresh-uz 7.3.2-1 7.3.3-1
libreoffice-fresh-ve 7.3.2-1 7.3.3-1
libreoffice-fresh-vec 7.3.2-1 7.3.3-1
libreoffice-fresh-vi 7.3.2-1 7.3.3-1
libreoffice-fresh-xh 7.3.2-1 7.3.3-1
libreoffice-fresh-zh-cn 7.3.2-1 7.3.3-1
libreoffice-fresh-zh-tw 7.3.2-1 7.3.3-1
libreoffice-fresh-zu 7.3.2-1 7.3.3-1
libreoffice-still 7.2.6-2 7.2.6-3
libreoffice-still-sdk 7.2.6-2 7.2.6-3
libunrar 1:6.1.6-1 1:6.1.7-1
libva-mesa-driver 22.0.2-1 22.0.3-1
libxcb 1.14-1 1.15-1
mercurial 6.1.1-1 6.1.2-1
mesa 22.0.2-1 22.0.3-1
mesa-amber 21.3.8-4 21.3.8-5
mesa-vdpau 22.0.2-1 22.0.3-1
mpd 0.23.6-2 0.23.7-1
mutter 42.0-2 42.1-1
mutter-docs 42.0-2 42.1-1
opencl-mesa 22.0.2-1 22.0.3-1
openconnect 1:8.20-2 1:9.01-1
openjdk-src 18.0.1.u10-1 18.0.1.1.u2-1
ostree 2022.2-1 2022.3-1
perl-template-toolkit 3.010-1 3.100-1
pgbouncer 1.16.1-1 1.17.0-1
plasma-wayland-protocols 1.6.0-1 1.7.0-1
poppler 22.03.0-1 22.05.0-1
poppler-glib 22.03.0-1 22.05.0-1
poppler-qt5 22.03.0-1 22.05.0-1
poppler-qt6 22.03.0-1 22.05.0-1
protobuf 3.20.1-1 3.20.1-2
python-asgiref 3.5.0-1 3.5.1-1
python-protobuf 3.20.1-1 3.20.1-2
python-setuptools 1:59.5.0-1 1:59.8.0-1
qemu 6.2.0-4 -
qemu-arch-extra 6.2.0-4 -
qemu-block-gluster 6.2.0-4 7.0.0-9
qemu-block-iscsi 6.2.0-4 7.0.0-9
qemu-guest-agent 6.2.0-4 7.0.0-9
qemu-headless 6.2.0-4 -
qemu-headless-arch-extra 6.2.0-4 -
qtcreator 7.0.1-1 7.0.1-2
samba 4.16.1-2 4.16.1-3
smbclient 4.16.1-2 4.16.1-3
spglib 1.16.3-1 1.16.5-1
visualvm 2.1-1 2.1.3-1
vpnc 1:0.5.3.r501.r196-1 1:0.5.3.r506.r204-1
vulkan-broadcom 22.0.2-1 22.0.3-1
vulkan-mesa-layers 22.0.2-1 22.0.3-1
vulkan-panfrost 22.0.2-1 22.0.3-1
vulkan-radeon 22.0.2-1 22.0.3-1
vulkan-swrast 22.0.2-1 22.0.3-1
wireplumber 0.4.9-1 0.4.10-2
wireplumber-docs 0.4.9-1 0.4.10-2
xcb-proto 1.14.1-5 1.15-1
xdg-desktop-portal 1.14.3-1 1.14.4-1
qemu-audio-alsa - 7.0.0-9
qemu-audio-dbus - 7.0.0-9
qemu-audio-jack - 7.0.0-9
qemu-audio-oss - 7.0.0-9
qemu-audio-pa - 7.0.0-9
qemu-audio-sdl - 7.0.0-9
qemu-audio-spice - 7.0.0-9
qemu-base - 7.0.0-9
qemu-block-curl - 7.0.0-9
qemu-block-dmg - 7.0.0-9
qemu-block-nfs - 7.0.0-9
qemu-block-ssh - 7.0.0-9
qemu-chardev-baum - 7.0.0-9
qemu-chardev-spice - 7.0.0-9
qemu-common - 7.0.0-9
qemu-desktop - 7.0.0-9
qemu-docs - 7.0.0-9
qemu-emulators-full - 7.0.0-9
qemu-full - 7.0.0-9
qemu-hw-display-qxl - 7.0.0-9
qemu-hw-display-virtio-gpu - 7.0.0-9
qemu-hw-display-virtio-gpu-gl - 7.0.0-9
qemu-hw-display-virtio-gpu-pci - 7.0.0-9
qemu-hw-display-virtio-gpu-pci-gl - 7.0.0-9
qemu-hw-display-virtio-vga - 7.0.0-9
qemu-hw-display-virtio-vga-gl - 7.0.0-9
qemu-hw-s390x-virtio-gpu-ccw - 7.0.0-9
qemu-hw-usb-host - 7.0.0-9
qemu-hw-usb-redirect - 7.0.0-9
qemu-hw-usb-smartcard - 7.0.0-9
qemu-img - 7.0.0-9
qemu-pr-helper - 7.0.0-9
qemu-system-aarch64 - 7.0.0-9
qemu-system-alpha - 7.0.0-9
qemu-system-arm - 7.0.0-9
qemu-system-avr - 7.0.0-9
qemu-system-cris - 7.0.0-9
qemu-system-hppa - 7.0.0-9
qemu-system-m68k - 7.0.0-9
qemu-system-microblaze - 7.0.0-9
qemu-system-mips - 7.0.0-9
qemu-system-nios2 - 7.0.0-9
qemu-system-or1k - 7.0.0-9
qemu-system-ppc - 7.0.0-9
qemu-system-riscv - 7.0.0-9
qemu-system-rx - 7.0.0-9
qemu-system-s390x - 7.0.0-9
qemu-system-sh4 - 7.0.0-9
qemu-system-sparc - 7.0.0-9
qemu-system-tricore - 7.0.0-9
qemu-system-x86 - 7.0.0-9
qemu-system-xtensa - 7.0.0-9
qemu-tests - 7.0.0-9
qemu-tools - 7.0.0-9
qemu-ui-curses - 7.0.0-9
qemu-ui-dbus - 7.0.0-9
qemu-ui-egl-headless - 7.0.0-9
qemu-ui-gtk - 7.0.0-9
qemu-ui-opengl - 7.0.0-9
qemu-ui-sdl - 7.0.0-9
qemu-ui-spice-app - 7.0.0-9
qemu-ui-spice-core - 7.0.0-9
qemu-user - 7.0.0-9
qemu-vhost-user-gpu - 7.0.0-9
qemu-virtiofsd - 7.0.0-9
qtcreator-devel - 7.0.1-2
:: Different overlay package(s) in repository kde-unstable aarch64
artikulate22.04.0.r1415.gb4ed154-122.04.0.r1417.gd6f8df1-1
breeze5.24.4.r2388.g8b13e977-15.24.5.r2392.ga907a4aa-1
disman5.24.3.r1814.gdfb62eb-15.24.5.r1841.g11bd631-1
dolphin22.04.0.r6946.g506cdf329-122.04.0.r6953.g47014b26b-1
drkonqi5.24.5.r777.g1fffaf6d-15.24.5.r778.gaf218d23-1
kdeplasma-addons5.24.5.r8752.g60d165577-15.24.5.r8784.g41c8267ad-1
kdisplay5.24.3.r1467.g3a9c6c8-15.24.5.r1487.g5b8ef1b-1
kiriki22.04.0.r449.g44b1ddd-122.04.0.r450.ga635e3d-1
kjumpingcube22.04.0.r822.g39d81f0-122.04.0.r823.g17122ff-1
kpublictransport22.04.0.r2007.gc4a44c70-122.04.0.r2008.g6de7af9a-1
krdc22.04.0.r1587.g62a952e-122.04.0.r1588.g71c0581-1
ksystemstats5.24.5.r221.g9512e31-15.24.5.r223.g43dc782-1
kwalletmanager22.04.0.r1268.g00e59e3-122.04.0.r1269.g93197cb-1
kwinft5.24.3.r20449.gfe54aa914-15.24.5.r20594.gf9b2f9b3f-1
libksysguard5.24.5.r2385.g4ddf2fa-15.24.5.r2390.g587fff4-1
plasma-desktop5.24.5.r9233.g198c28fe1-15.24.5.r9236.g549ec82fd-1
plasma-pa5.24.5.r1047.gc1de219-15.24.5.r1048.gabf787c-1
wrapland5.24.3.r1748.g5ba9db79-15.24.5.r1750.gb2d64a3-1
plasma-remotecontrollers - r84.g4ada532-2
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
