Basically after the big update. pamac will not show chaotic-aur. The apps i installed from chaotic-aur before are now listed in pamac from the AUR source. And tells me I have updates because its ignoring chaotic-aur repo, so its confused.
Pamac always showed the chaotic-aur when updates. also 4kvideodownloader is in the ignore section. Until the update it always was ignored. Now its not.
Looks like the issue isnt with update. After a lot of searching, looks like the custom repo I use “chaotic-aur” did some automatic task that accidentaly wiped half it’s packages.
