I was using Xfce4 and let him working downloading something from browser, when I go back there was a black screen without mouse and I couldn’t access. I used the button of shutdown in the computer, then iniciate again. Now everytime I did a login Xfce4 goes all black screen.
What logs should I post?
You could perhaps try ALT-CTRL-F2 and see if you can login. if so try startxfce4?
or before that look at .xsesaion-errors file.
Xfce uses LightDM by default. Why are you using SDDM?
FYI, your topic title and post are very hard to understand. Perhaps it would be better to post in your native language in our #languages section.
I am using SDDM since I installed Manjaro. A lot of years ago. Never happened this.
I already changed tty and used startx, same problem: black screen.
Give and you shall receive: The more information you provide, the better chance someone can help.
Please see:
and the .xsession-errors file had?
you would have to log in as someone else to do that tho. Perhaps as root user.
I didn’t find a .xsession-errors in my home folder
.local/share/xorg/xorg.o.log perhaps.
Xorg.0.log:
[ 481.646]
X.Org X Server 1.21.1.5
[ 481.646] Current Operating System: Linux sergio-pc 6.1.0-1-MANJARO #1 SMP PREEMPT_DYNAMIC Mon Dec 12 10:32:57 UTC 2022 x86_64
[ 481.646] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=defa5915-ec5f-40a8-99a1-fbc0b9574b00 ro bootsplash.bootfile=bootsplash-themes/manjaro-elegant/bootsplash apparmor=1 security=apparmor udev.log-priority=3 systemd.unified_cgroup_hierarchy=false mitigations=off
[ 481.646]
[ 481.647] Current version of pixman: 0.42.2
[ 481.647] Before reporting problems, check http://wiki.x.org
[ 481.647] Markers: (--) probed, (**) from config file, (==) default setting,
[ 481.647] (==) Log file: "/home/sergio/.local/share/xorg/Xorg.0.log", Time: Sun Dec 18 21:18:19 2022
[ 481.647] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 481.647] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 481.647] (==) No Layout section. Using the first Screen section.
[ 481.647] (==) No screen section available. Using defaults.
[ 481.647] (**) |-->Screen "Default Screen Section" (0)
[ 481.647] (**) | |-->Monitor "<default monitor>"
[ 481.647] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 481.647] (**) | |-->Device "Intel Graphics"
[ 481.647] (==) No monitor specified for screen "Default Screen Section".
[ 481.647] (==) Automatically adding devices
[ 481.647] (==) Automatically enabling devices
[ 481.647] (==) Automatically adding GPU devices
[ 481.647] (==) Automatically binding GPU devices
[ 481.647] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 481.647] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 481.647] Entry deleted from font path.
[ 481.647] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF,
/usr/share/fonts/Type1,
/usr/share/fonts/100dpi,
/usr/share/fonts/75dpi
[ 481.647] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 481.647] (II) The server relies on udev to provide the list of input devices.
[ 481.647] (II) Module ABI versions:
[ 481.647] X.Org ANSI C Emulation: 0.4
[ 481.647] X.Org Video Driver: 25.2
[ 481.647] X.Org XInput driver : 24.4
[ 481.647] X.Org Server Extension : 10.0
[ 481.648] (++) using VT number 3
[ 481.648] (--) controlling tty is VT number 3, auto-enabling KeepTty
[ 481.649] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_35
[ 481.650] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 481.650] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 481.650] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[ 481.651] (--) PCI:*(0@0:2:0) 8086:0162:1849:0162 rev 9, Mem @ 0xf7800000/4194304, 0xe0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[ 481.651] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 481.651] (II) LoadModule: "glx"
[ 481.651] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 481.653] (II) Module glx: vendor="X.Org Foundation"
[ 481.653] compiled for 1.21.1.5, module version = 1.0.0
[ 481.653] ABI class: X.Org Server Extension, version 10.0
[ 481.653] (II) LoadModule: "modesetting"
[ 481.653] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 481.653] (II) Module modesetting: vendor="X.Org Foundation"
[ 481.653] compiled for 1.21.1.5, module version = 1.21.1
[ 481.653] Module class: X.Org Video Driver
[ 481.653] ABI class: X.Org Video Driver, version 25.2
[ 481.653] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 481.653] (II) modeset(0): using drv /dev/dri/card0
[ 481.653] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 481.653] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 481.653] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 481.653] (==) modeset(0): RGB weight 888
[ 481.653] (==) modeset(0): Default visual is TrueColor
[ 481.653] (II) Loading sub module "glamoregl"
[ 481.653] (II) LoadModule: "glamoregl"
[ 481.653] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 481.656] (II) Module glamoregl: vendor="X.Org Foundation"
[ 481.656] compiled for 1.21.1.5, module version = 1.0.1
[ 481.656] ABI class: X.Org ANSI C Emulation, version 0.4
[ 481.680] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) HD Graphics 4000 (IVB GT2)
[ 481.680] (II) modeset(0): glamor initialized
[ 481.680] (==) modeset(0): VariableRefresh: disabled
[ 481.680] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 481.694] (II) modeset(0): Output VGA-1 has no monitor section
[ 481.720] (II) modeset(0): Output HDMI-1 has no monitor section
[ 481.798] (II) modeset(0): Output DP-1 has no monitor section
[ 481.811] (II) modeset(0): EDID for output VGA-1
[ 481.811] (II) modeset(0): Manufacturer: AOC Model: 2243 Serial#: 16843009
[ 481.811] (II) modeset(0): Year: 2010 Week: 0
[ 481.811] (II) modeset(0): EDID Version: 1.3
[ 481.811] (II) modeset(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
[ 481.811] (II) modeset(0): Sync: Separate
[ 481.811] (II) modeset(0): Max Image Size [cm]: horiz.: 48 vert.: 27
[ 481.811] (II) modeset(0): Gamma: 2.20
[ 481.811] (II) modeset(0): DPMS capabilities: Off; RGB/Color Display
[ 481.811] (II) modeset(0): First detailed timing is preferred mode
[ 481.811] (II) modeset(0): redX: 0.648 redY: 0.339 greenX: 0.282 greenY: 0.603
[ 481.811] (II) modeset(0): blueX: 0.143 blueY: 0.070 whiteX: 0.313 whiteY: 0.329
[ 481.811] (II) modeset(0): Supported established timings:
[ 481.811] (II) modeset(0): 720x400@70Hz
[ 481.811] (II) modeset(0): 640x480@60Hz
[ 481.811] (II) modeset(0): 640x480@67Hz
[ 481.811] (II) modeset(0): 640x480@72Hz
[ 481.811] (II) modeset(0): 640x480@75Hz
[ 481.811] (II) modeset(0): 800x600@56Hz
[ 481.811] (II) modeset(0): 800x600@60Hz
[ 481.811] (II) modeset(0): 800x600@72Hz
[ 481.811] (II) modeset(0): 800x600@75Hz
[ 481.811] (II) modeset(0): 832x624@75Hz
[ 481.811] (II) modeset(0): 1024x768@60Hz
[ 481.811] (II) modeset(0): 1024x768@70Hz
[ 481.811] (II) modeset(0): 1024x768@75Hz
[ 481.811] (II) modeset(0): 1280x1024@75Hz
[ 481.811] (II) modeset(0): Manufacturer's mask: 0
[ 481.811] (II) modeset(0): Supported standard timings:
[ 481.811] (II) modeset(0): #0: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 481.811] (II) modeset(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 481.811] (II) modeset(0): #2: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 481.811] (II) modeset(0): #3: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 481.811] (II) modeset(0): #4: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 481.811] (II) modeset(0): Supported detailed timing:
[ 481.811] (II) modeset(0): clock: 148.5 MHz Image Size: 477 x 268 mm
[ 481.811] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 481.811] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 481.811] (II) modeset(0): Ranges: V min: 55 V max: 75 Hz, H min: 30 H max: 83 kHz, PixClock max 215 MHz
[ 481.811] (II) modeset(0): Monitor name: 2243W
[ 481.811] (II) modeset(0): Serial No:
[ 481.811] (II) modeset(0): EDID (in hex):
[ 481.811] (II) modeset(0): 00ffffffffffff0005e3432201010101
[ 481.811] (II) modeset(0): 0014010368301b782a3585a656489a24
[ 481.811] (II) modeset(0): 125054bfef00814081809500b300d1c0
[ 481.811] (II) modeset(0): 010101010101023a801871382d40582c
[ 481.811] (II) modeset(0): 4500dd0c1100001e000000fd00374b1e
[ 481.811] (II) modeset(0): 5315000a202020202020000000fc0032
[ 481.811] (II) modeset(0): 323433570a20202020202020000000ff
[ 481.811] (II) modeset(0): 000a202020202020202020202020005c
[ 481.811] (II) modeset(0): Printing probed modes for output VGA-1
[ 481.811] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 481.811] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 481.811] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 481.811] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 481.811] (II) modeset(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 481.811] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 481.811] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 481.811] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 481.811] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 481.811] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 481.811] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 481.811] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 481.812] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 481.812] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 481.812] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 481.812] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 481.812] (II) modeset(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 481.812] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 481.812] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 481.838] (II) modeset(0): EDID for output HDMI-1
[ 481.838] (II) modeset(0): Manufacturer: PHL Model: 5035 Serial#: 16843009
[ 481.838] (II) modeset(0): Year: 2014 Week: 0
[ 481.838] (II) modeset(0): EDID Version: 1.3
[ 481.838] (II) modeset(0): Digital Display Input
[ 481.838] (II) modeset(0): Max Image Size [cm]: horiz.: 64 vert.: 36
[ 481.838] (II) modeset(0): Gamma: 2.20
[ 481.838] (II) modeset(0): No DPMS capabilities specified
[ 481.838] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 481.838] (II) modeset(0): First detailed timing is preferred mode
[ 481.838] (II) modeset(0): redX: 0.630 redY: 0.328 greenX: 0.327 greenY: 0.632
[ 481.838] (II) modeset(0): blueX: 0.145 blueY: 0.034 whiteX: 0.280 whiteY: 0.290
[ 481.838] (II) modeset(0): Supported established timings:
[ 481.838] (II) modeset(0): 640x480@60Hz
[ 481.838] (II) modeset(0): 800x600@60Hz
[ 481.838] (II) modeset(0): 1024x768@60Hz
[ 481.838] (II) modeset(0): Manufacturer's mask: 0
[ 481.838] (II) modeset(0): Supported standard timings:
[ 481.838] (II) modeset(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 481.838] (II) modeset(0): Supported detailed timing:
[ 481.838] (II) modeset(0): clock: 148.5 MHz Image Size: 640 x 360 mm
[ 481.838] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 481.838] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 481.838] (II) modeset(0): clock: 84.8 MHz Image Size: 640 x 360 mm
[ 481.838] (II) modeset(0): h_active: 1360 h_sync: 1432 h_sync_end 1568 h_blank_end 1776 h_border: 0
[ 481.838] (II) modeset(0): v_active: 768 v_sync: 771 v_sync_end 776 v_blanking: 798 v_border: 0
[ 481.838] (II) modeset(0): Monitor name: Philips TV
[ 481.838] (II) modeset(0): Ranges: V min: 56 V max: 76 Hz, H min: 30 H max: 83 kHz, PixClock max 175 MHz
[ 481.838] (II) modeset(0): h_active: 1920 h_sync: 2448 h_sync_end 2492 h_blank_end 2640 h_border: 0
[ 481.838] (II) modeset(0): clock: 74.2 MHz Image Size: 640 x 360 mm
[ 481.838] (II) modeset(0): h_active: 1920 h_sync: 2558 h_sync_end 2602 h_blank_end 2750 h_border: 0
[ 481.838] (II) modeset(0): v_active: 540 v_sync: 542 v_sync_end 547 v_blanking: 562 v_border: 0
[ 481.838] (II) modeset(0): Number of EDID sections to follow: 1
[ 481.838] (II) modeset(0): EDID (in hex):
[ 481.838] (II) modeset(0): 00ffffffffffff00410c355001010101
[ 481.838] (II) modeset(0): 00180103804024780a4f3da15453a125
[ 481.838] (II) modeset(0): 08474a21080081800101010101010101
[ 481.838] (II) modeset(0): 010101010101023a801871382d40582c
[ 481.838] (II) modeset(0): 450080682100001e1b2150a051001e30
[ 481.838] (II) modeset(0): 48883500806821000018000000fc0050
[ 481.838] (II) modeset(0): 68696c6970732054560a2020000000fd
[ 481.838] (II) modeset(0): 00384c1e5311000a20202020202001c1
[ 481.838] (II) modeset(0): 020329714e9f10202122140513041102
[ 481.838] (II) modeset(0): 15060126090703150750830100006a03
[ 481.838] (II) modeset(0): 0c001000b832200000023a80d072382d
[ 481.838] (II) modeset(0): 40102c458080682100001e011d803e73
[ 481.838] (II) modeset(0): 382d407e2c458080682100001e011d80
[ 481.838] (II) modeset(0): d0721c1620102c258080682100009e00
[ 481.838] (II) modeset(0): 00000000000000000000000000000000
[ 481.838] (II) modeset(0): 000000000000000000000000000000d7
[ 481.838] (--) modeset(0): HDMI max TMDS frequency 250000KHz
[ 481.838] (II) modeset(0): Printing probed modes for output HDMI-1
[ 481.838] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 481.838] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 481.838] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 481.838] (II) modeset(0): Modeline "1920x1080i"x60.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 481.838] (II) modeset(0): Modeline "1920x1080i"x50.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 481.838] (II) modeset(0): Modeline "1920x1080"x30.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[ 481.838] (II) modeset(0): Modeline "1920x1080"x25.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[ 481.838] (II) modeset(0): Modeline "1920x1080"x24.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 481.838] (II) modeset(0): Modeline "1920x1080i"x59.9 74.18 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[ 481.838] (II) modeset(0): Modeline "1920x1080"x30.0 74.18 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
[ 481.838] (II) modeset(0): Modeline "1920x1080"x24.0 74.18 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 481.838] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 481.838] (II) modeset(0): Modeline "1360x768"x59.8 84.75 1360 1432 1568 1776 768 771 776 798 -hsync -vsync (47.7 kHz e)
[ 481.838] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 481.838] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 481.838] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 481.838] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 481.838] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 481.838] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 481.838] (II) modeset(0): Modeline "720x576i"x50.0 13.50 720 732 795 864 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 481.838] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 481.838] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 481.838] (II) modeset(0): Modeline "720x480i"x60.0 13.51 720 739 801 858 480 488 494 525 interlace -hsync -vsync (15.8 kHz e)
[ 481.838] (II) modeset(0): Modeline "720x480i"x59.9 13.50 720 739 801 858 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 481.838] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 481.838] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 481.916] (II) modeset(0): EDID for output DP-1
[ 481.916] (II) modeset(0): Output VGA-1 connected
[ 481.916] (II) modeset(0): Output HDMI-1 connected
[ 481.916] (II) modeset(0): Output DP-1 disconnected
[ 481.916] (II) modeset(0): Using spanning desktop for initial modes
[ 481.916] (II) modeset(0): Output VGA-1 using initial mode 1920x1080 +0+0
[ 481.916] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +1920+0
[ 481.916] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 481.916] (==) modeset(0): DPI set to (96, 96)
[ 481.916] (II) Loading sub module "fb"
[ 481.916] (II) LoadModule: "fb"
[ 481.916] (II) Module "fb" already built-in
[ 482.119] (==) modeset(0): Backing store enabled
[ 482.119] (==) modeset(0): Silken mouse enabled
[ 482.234] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 482.234] (==) modeset(0): DPMS enabled
[ 482.234] (II) modeset(0): [DRI2] Setup complete
[ 482.234] (II) modeset(0): [DRI2] DRI driver: crocus
[ 482.234] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 482.234] (II) Initializing extension Generic Event Extension
[ 482.234] (II) Initializing extension SHAPE
[ 482.234] (II) Initializing extension MIT-SHM
[ 482.234] (II) Initializing extension XInputExtension
[ 482.235] (II) Initializing extension XTEST
[ 482.235] (II) Initializing extension BIG-REQUESTS
[ 482.235] (II) Initializing extension SYNC
[ 482.235] (II) Initializing extension XKEYBOARD
[ 482.235] (II) Initializing extension XC-MISC
[ 482.235] (II) Initializing extension SECURITY
[ 482.235] (II) Initializing extension XFIXES
[ 482.236] (II) Initializing extension RENDER
[ 482.236] (II) Initializing extension RANDR
[ 482.236] (II) Initializing extension COMPOSITE
[ 482.236] (II) Initializing extension DAMAGE
[ 482.236] (II) Initializing extension MIT-SCREEN-SAVER
[ 482.236] (II) Initializing extension DOUBLE-BUFFER
[ 482.237] (II) Initializing extension RECORD
[ 482.237] (II) Initializing extension DPMS
[ 482.237] (II) Initializing extension Present
[ 482.237] (II) Initializing extension DRI3
[ 482.237] (II) Initializing extension X-Resource
[ 482.237] (II) Initializing extension XVideo
[ 482.237] (II) Initializing extension XVideo-MotionCompensation
[ 482.237] (II) Initializing extension GLX
[ 482.244] (II) AIGLX: Loaded and initialized crocus
[ 482.244] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 482.244] (II) Initializing extension XFree86-VidModeExtension
[ 482.244] (II) Initializing extension XFree86-DGA
[ 482.244] (II) Initializing extension XFree86-DRI
[ 482.244] (II) Initializing extension DRI2
[ 482.244] (II) modeset(0): Damage tracking initialized
[ 482.244] (II) modeset(0): Setting screen physical size to 1016 x 285
[ 482.438] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 482.438] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 482.438] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 482.438] (**) Power Button: Applying InputClass "system-keyboard"
[ 482.438] (II) LoadModule: "libinput"
[ 482.439] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 482.440] (II) Module libinput: vendor="X.Org Foundation"
[ 482.440] compiled for 1.21.1.3, module version = 1.2.1
[ 482.440] Module class: X.Org XInput Driver
[ 482.440] ABI class: X.Org XInput driver, version 24.4
[ 482.440] (II) Using input driver 'libinput' for 'Power Button'
[ 482.441] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 27 paused 0
[ 482.441] (**) Power Button: always reports core events
[ 482.441] (**) Option "Device" "/dev/input/event1"
[ 482.442] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 482.443] (II) event1 - Power Button: device is a keyboard
[ 482.443] (II) event1 - Power Button: device removed
[ 482.443] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 482.443] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 482.443] (**) Option "xkb_model" "pc105"
[ 482.443] (**) Option "xkb_layout" "us"
[ 482.443] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 482.444] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[ 482.444] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 482.444] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 482.444] (**) Video Bus: Applying InputClass "system-keyboard"
[ 482.444] (II) Using input driver 'libinput' for 'Video Bus'
[ 482.444] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 30 paused 0
[ 482.444] (**) Video Bus: always reports core events
[ 482.444] (**) Option "Device" "/dev/input/event6"
[ 482.445] (II) event6 - Video Bus: is tagged by udev as: Keyboard
[ 482.445] (II) event6 - Video Bus: device is a keyboard
[ 482.445] (II) event6 - Video Bus: device removed
[ 482.445] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6/event6"
[ 482.445] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 482.445] (**) Option "xkb_model" "pc105"
[ 482.445] (**) Option "xkb_layout" "us"
[ 482.446] (II) event6 - Video Bus: is tagged by udev as: Keyboard
[ 482.446] (II) event6 - Video Bus: device is a keyboard
[ 482.446] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 482.446] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 482.446] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 482.446] (**) Power Button: Applying InputClass "system-keyboard"
[ 482.446] (II) Using input driver 'libinput' for 'Power Button'
[ 482.447] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 31 paused 0
[ 482.447] (**) Power Button: always reports core events
[ 482.447] (**) Option "Device" "/dev/input/event0"
[ 482.448] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 482.448] (II) event0 - Power Button: device is a keyboard
[ 482.448] (II) event0 - Power Button: device removed
[ 482.448] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 482.448] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 482.448] (**) Option "xkb_model" "pc105"
[ 482.448] (**) Option "xkb_layout" "us"
[ 482.449] (II) event0 - Power Button: device is a keyboard
[ 482.449] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event10)
[ 482.449] (II) No input driver specified, ignoring this device.
[ 482.449] (II) This device may have been added with another device file.
[ 482.449] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event11)
[ 482.450] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event12)
[ 482.450] (II) No input driver specified, ignoring this device.
[ 482.450] (II) This device may have been added with another device file.
[ 482.450] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event7)
[ 482.450] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event8)
[ 482.451] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event9)
[ 482.451] (II) No input driver specified, ignoring this device.
[ 482.451] (II) This device may have been added with another device file.
[ 482.451] (II) config/udev: Adding input device MIIIW MIIIW USB Receiver Mouse (/dev/input/event2)
[ 482.451] (**) MIIIW MIIIW USB Receiver Mouse: Applying InputClass "evdev pointer catchall"
[ 482.451] (**) MIIIW MIIIW USB Receiver Mouse: Applying InputClass "libinput pointer catchall"
[ 482.451] (**) MIIIW MIIIW USB Receiver Mouse: Applying InputClass "My Mouse"
[ 482.451] (II) Using input driver 'libinput' for 'MIIIW MIIIW USB Receiver Mouse'
[ 482.452] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 32 paused 0
[ 482.452] (**) MIIIW MIIIW USB Receiver Mouse: always reports core events
[ 482.452] (**) Option "Device" "/dev/input/event2"
[ 482.453] (II) event2 - MIIIW MIIIW USB Receiver Mouse: is tagged by udev as: Mouse
[ 482.453] (II) event2 - MIIIW MIIIW USB Receiver Mouse: device is a pointer
[ 482.453] (II) event2 - MIIIW MIIIW USB Receiver Mouse: device removed
[ 482.453] (**) Option "AccelSpeed" "-1"
[ 482.453] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/0003:3044:EAC6.0001/input/input2/event2"
[ 482.453] (II) XINPUT: Adding extended input device "MIIIW MIIIW USB Receiver Mouse" (type: MOUSE, id 9)
[ 482.453] (**) Option "AccelerationScheme" "none"
[ 482.453] (**) MIIIW MIIIW USB Receiver Mouse: (accel) selected scheme none/0
[ 482.453] (**) MIIIW MIIIW USB Receiver Mouse: (accel) acceleration factor: 2.000
[ 482.453] (**) MIIIW MIIIW USB Receiver Mouse: (accel) acceleration threshold: 4
[ 482.455] (II) event2 - MIIIW MIIIW USB Receiver Mouse: is tagged by udev as: Mouse
[ 482.455] (II) event2 - MIIIW MIIIW USB Receiver Mouse: device is a pointer
[ 482.455] (II) config/udev: Adding input device MIIIW MIIIW USB Receiver Mouse (/dev/input/mouse0)
[ 482.455] (**) MIIIW MIIIW USB Receiver Mouse: Applying InputClass "My Mouse"
[ 482.455] (II) No input driver specified, ignoring this device.
[ 482.455] (II) This device may have been added with another device file.
[ 482.456] (II) config/udev: Adding input device MIIIW MIIIW USB Receiver Consumer Control (/dev/input/event3)
[ 482.456] (**) MIIIW MIIIW USB Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 482.456] (**) MIIIW MIIIW USB Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 482.456] (**) MIIIW MIIIW USB Receiver Consumer Control: Applying InputClass "system-keyboard"
[ 482.456] (II) Using input driver 'libinput' for 'MIIIW MIIIW USB Receiver Consumer Control'
[ 482.457] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 33 paused 0
[ 482.457] (**) MIIIW MIIIW USB Receiver Consumer Control: always reports core events
[ 482.457] (**) Option "Device" "/dev/input/event3"
[ 482.458] (II) event3 - MIIIW MIIIW USB Receiver Consumer Control: is tagged by udev as: Keyboard
[ 482.458] (II) event3 - MIIIW MIIIW USB Receiver Consumer Control: device is a keyboard
[ 482.458] (II) event3 - MIIIW MIIIW USB Receiver Consumer Control: device removed
[ 482.458] (II) libinput: MIIIW MIIIW USB Receiver Consumer Control: needs a virtual subdevice
[ 482.458] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/0003:3044:EAC6.0001/input/input3/event3"
[ 482.458] (II) XINPUT: Adding extended input device "MIIIW MIIIW USB Receiver Consumer Control" (type: MOUSE, id 10)
[ 482.458] (**) Option "AccelerationScheme" "none"
[ 482.458] (**) MIIIW MIIIW USB Receiver Consumer Control: (accel) selected scheme none/0
[ 482.458] (**) MIIIW MIIIW USB Receiver Consumer Control: (accel) acceleration factor: 2.000
[ 482.458] (**) MIIIW MIIIW USB Receiver Consumer Control: (accel) acceleration threshold: 4
[ 482.459] (II) event3 - MIIIW MIIIW USB Receiver Consumer Control: is tagged by udev as: Keyboard
[ 482.459] (II) event3 - MIIIW MIIIW USB Receiver Consumer Control: device is a keyboard
[ 482.460] (II) config/udev: Adding input device MIIIW MIIIW USB Receiver System Control (/dev/input/event4)
[ 482.460] (**) MIIIW MIIIW USB Receiver System Control: Applying InputClass "evdev keyboard catchall"
[ 482.460] (**) MIIIW MIIIW USB Receiver System Control: Applying InputClass "libinput keyboard catchall"
[ 482.460] (**) MIIIW MIIIW USB Receiver System Control: Applying InputClass "system-keyboard"
[ 482.460] (II) Using input driver 'libinput' for 'MIIIW MIIIW USB Receiver System Control'
[ 482.461] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 34 paused 0
[ 482.461] (**) MIIIW MIIIW USB Receiver System Control: always reports core events
[ 482.461] (**) Option "Device" "/dev/input/event4"
[ 482.462] (II) event4 - MIIIW MIIIW USB Receiver System Control: is tagged by udev as: Keyboard
[ 482.462] (II) event4 - MIIIW MIIIW USB Receiver System Control: device is a keyboard
[ 482.462] (II) event4 - MIIIW MIIIW USB Receiver System Control: device removed
[ 482.462] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/0003:3044:EAC6.0001/input/input4/event4"
[ 482.462] (II) XINPUT: Adding extended input device "MIIIW MIIIW USB Receiver System Control" (type: KEYBOARD, id 11)
[ 482.462] (**) Option "xkb_model" "pc105"
[ 482.462] (**) Option "xkb_layout" "us"
[ 482.463] (II) event4 - MIIIW MIIIW USB Receiver System Control: is tagged by udev as: Keyboard
[ 482.463] (II) event4 - MIIIW MIIIW USB Receiver System Control: device is a keyboard
[ 482.464] (II) config/udev: Adding input device MIIIW MIIIW USB Receiver (/dev/input/event5)
[ 482.464] (**) MIIIW MIIIW USB Receiver: Applying InputClass "evdev keyboard catchall"
[ 482.464] (**) MIIIW MIIIW USB Receiver: Applying InputClass "libinput keyboard catchall"
[ 482.464] (**) MIIIW MIIIW USB Receiver: Applying InputClass "system-keyboard"
[ 482.464] (II) Using input driver 'libinput' for 'MIIIW MIIIW USB Receiver'
[ 482.465] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 35 paused 0
[ 482.465] (**) MIIIW MIIIW USB Receiver: always reports core events
[ 482.465] (**) Option "Device" "/dev/input/event5"
[ 482.466] (II) event5 - MIIIW MIIIW USB Receiver: is tagged by udev as: Keyboard
[ 482.466] (II) event5 - MIIIW MIIIW USB Receiver: device is a keyboard
[ 482.466] (II) event5 - MIIIW MIIIW USB Receiver: device removed
[ 482.466] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/0003:3044:EAC6.0002/input/input5/event5"
[ 482.466] (II) XINPUT: Adding extended input device "MIIIW MIIIW USB Receiver" (type: KEYBOARD, id 12)
[ 482.466] (**) Option "xkb_model" "pc105"
[ 482.466] (**) Option "xkb_layout" "us"
[ 482.468] (II) event5 - MIIIW MIIIW USB Receiver: is tagged by udev as: Keyboard
[ 482.468] (II) event5 - MIIIW MIIIW USB Receiver: device is a keyboard
[ 482.484] (**) MIIIW MIIIW USB Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 482.484] (**) MIIIW MIIIW USB Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 482.484] (**) MIIIW MIIIW USB Receiver Consumer Control: Applying InputClass "system-keyboard"
[ 482.484] (II) Using input driver 'libinput' for 'MIIIW MIIIW USB Receiver Consumer Control'
[ 482.484] (II) systemd-logind: returning pre-existing fd for /dev/input/event3 13:67
[ 482.484] (**) MIIIW MIIIW USB Receiver Consumer Control: always reports core events
[ 482.484] (**) Option "Device" "/dev/input/event3"
[ 482.484] (II) libinput: MIIIW MIIIW USB Receiver Consumer Control: is a virtual subdevice
[ 482.484] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/0003:3044:EAC6.0001/input/input3/event3"
[ 482.484] (II) XINPUT: Adding extended input device "MIIIW MIIIW USB Receiver Consumer Control" (type: KEYBOARD, id 13)
[ 482.484] (**) Option "xkb_model" "pc105"
[ 482.484] (**) Option "xkb_layout" "us"
[ 483.208] (II) modeset(0): EDID vendor "AOC", prod id 8771
[ 483.208] (II) modeset(0): Using EDID range info for horizontal sync
[ 483.208] (II) modeset(0): Using EDID range info for vertical refresh
[ 483.208] (II) modeset(0): Printing DDC gathered Modelines:
[ 483.208] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 483.208] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 483.208] (II) modeset(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 483.208] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 483.208] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 483.208] (II) modeset(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 483.208] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 483.208] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 483.208] (II) modeset(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 483.208] (II) modeset(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 483.208] (II) modeset(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 483.208] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 483.208] (II) modeset(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 483.208] (II) modeset(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 483.208] (II) modeset(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 483.208] (II) modeset(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 483.208] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 483.208] (II) modeset(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 483.208] (II) modeset(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 483.248] (--) modeset(0): HDMI max TMDS frequency 250000KHz
[ 483.358] (II) modeset(0): Allocate new frame buffer 1920x1080 stride
[ 485.064] (II) modeset(0): EDID vendor "AOC", prod id 8771
[ 485.064] (II) modeset(0): Using hsync ranges from config file
[ 485.064] (II) modeset(0): Using vrefresh ranges from config file
[ 485.064] (II) modeset(0): Printing DDC gathered Modelines:
[ 485.064] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 485.064] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 485.064] (II) modeset(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 485.064] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 485.064] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 485.064] (II) modeset(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 485.064] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 485.064] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 485.064] (II) modeset(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 485.064] (II) modeset(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 485.064] (II) modeset(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 485.064] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 485.064] (II) modeset(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 485.064] (II) modeset(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 485.064] (II) modeset(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 485.064] (II) modeset(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 485.064] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 485.064] (II) modeset(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 485.064] (II) modeset(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 485.093] (--) modeset(0): HDMI max TMDS frequency 250000KHz
[ 530.119] (**) Option "fd" "27"
[ 530.119] (II) event1 - Power Button: device removed
[ 530.120] (**) Option "fd" "30"
[ 530.120] (II) event6 - Video Bus: device removed
[ 530.120] (**) Option "fd" "31"
[ 530.120] (II) event0 - Power Button: device removed
[ 530.121] (**) Option "fd" "32"
[ 530.121] (II) event2 - MIIIW MIIIW USB Receiver Mouse: device removed
[ 530.121] (**) Option "fd" "33"
[ 530.121] (**) Option "fd" "34"
[ 530.121] (II) event4 - MIIIW MIIIW USB Receiver System Control: device removed
[ 530.122] (**) Option "fd" "35"
[ 530.122] (II) event5 - MIIIW MIIIW USB Receiver: device removed
[ 530.122] (**) Option "fd" "33"
[ 530.122] (II) event3 - MIIIW MIIIW USB Receiver Consumer Control: device removed
[ 530.122] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 530.223] (II) systemd-logind: got pause for 13:68
[ 530.223] (II) systemd-logind: got pause for 13:69
[ 530.223] (II) systemd-logind: got pause for 13:65
[ 530.223] (II) systemd-logind: got pause for 13:64
[ 530.223] (II) systemd-logind: got pause for 13:67
[ 530.223] (II) systemd-logind: got pause for 13:70
[ 530.223] (II) systemd-logind: got pause for 13:66
[ 804.429] (II) UnloadModule: "libinput"
[ 804.429] (II) systemd-logind: not releasing fd for 13:67, still in use
[ 804.429] (II) systemd-logind: releasing fd for 13:69
[ 805.759] (II) UnloadModule: "libinput"
[ 805.759] (II) systemd-logind: releasing fd for 13:68
[ 805.855] (II) UnloadModule: "libinput"
[ 805.855] (II) systemd-logind: releasing fd for 13:67
[ 805.929] (II) UnloadModule: "libinput"
[ 805.929] (II) systemd-logind: releasing fd for 13:66
[ 805.989] (II) UnloadModule: "libinput"
[ 805.989] (II) systemd-logind: releasing fd for 13:64
[ 806.082] (II) UnloadModule: "libinput"
[ 806.082] (II) systemd-logind: releasing fd for 13:70
[ 806.149] (II) UnloadModule: "libinput"
[ 806.149] (II) systemd-logind: releasing fd for 13:65
[ 806.245] (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
[ 806.245] (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
[ 806.245] (WW) xf86OpenConsole: VT_GETSTATE failed: Input/output error
[ 806.262] (II) Server terminated successfully (0). Closing log file.
I found! I was using “modesetting” on my graphics card config. It was a long time with this settings, why happen now?
Reverting to the defaults cards config by Manjaro, resolved. I like more the order things appears with modesetting.
What I was noticing was the lack of xorg.conf file and the resulting errors.
Maybe a Google for a valid xorg.conf file would have helped. But it looks like you got it sorted out so “all’s well that end well”
Today I updated xorg-server. Maybe it was a problem with it. Tomorrow I will test “modesetting” drive again. Now I know where is the thing.
Yes, modesetting is not working for me.
It’s back to work when I mirror the screens. Xfce4-4.18 reconfigured my setup and I didn’t see that the first monitor was the HDMI which is always off. Anyway didn’t understand why it was black.
I uninstalled xf86-video-intel first.
