After login Desktop Icons not shown if preference "Show preview thumbnails" disabled
After login my desktop Icons are not shown if the preference “Show preview thumbnails” is disabled. Only the default icon placeholders are shown. However, icons will load either on mouseclick or selecting a icon desktop area with a rectangle.
First I tried to clear the icon cache, but still the same issue after login. This never happened before the latest update.
KDE Plasma Version: 6.2.4
KDE Frameworks Version: 6.8.0
Qt Version: 6.8.1
Kernel Version: 6.11.10-2-MANJARO (64-bit)
Graphics Platform: X11
Processors: 4 × AMD A10-7870K Radeon R7, 12 Compute Cores 4C+8G
Memory: 14,6 GiB of RAM
Graphics Processor: KAVERI
Welcome to the Manjaro community.
This seems consistent with my understanding of how these preview thumbnails should work, however, I have not noticed:
I’m sure others will provide additional feedback when they are able.
As a new forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information.
These announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
Output of the following command formatted according to forum requirements (see links above) may be useful for those wishing to help:
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
First, can you confirm this issue?
Did you really try to re-login with the preference I posted above, or not?
I use KDE Plasma personally. With Show Previews deactivated, no document icon previews are shown, as expected.
Neither is the condition you describe a noticable outcome after logging out and in again.
In short, I am unable to reproduce this.
You could try creating a new User account to see if the same issue manifests. If it does not, this outcome will indicate that whatever the problem might be, it’s limited to your current User account.
This knowledge alone will save others potentially much wasted time and guesswork, which ultimately helps you.
Report back with those results.
Now, please attend to the other matter of providing information in accordance with forum requirements. Doing so will help others to help you more easily. Read through the links previously provided; they are not given to complicate matters, but for your benefit.
For example, what you have given as system information appears to be from fastfetch (or similar) output – perhaps fine if we were looking to buy a computer, but otherwise limited – the inxi command given will provide information generally more useful to those wishing to help.
I tried this already, but same issue.
Sorry, but unable to post screenshots - probably due to forum restrictions.
[ik@rg ~]$ inxi --admin --verbosity=8 --filter --no-host --width
  Kernel: 6.11.10-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
    root=UUID=2dea840c-dda5-42c0-a198-f5d854fb14d7 rw udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Desktop Mobo: ASRock model: FM2A88X Extreme6+
    serial: <superuser required> uuid: <superuser required>
    UEFI-[Legacy]: American Megatrends v: P4.20 date: 01/13/2016
  System RAM: total: 16 GiB available: 14.57 GiB used: 3.88 GiB (26.6%)
  Array-1: capacity: 32 GiB note: est. slots: 4 modules: 3 EC: None
  Device-1: Channel-A DIMM 0 type: DDR3 detail: synchronous unbuffered
    (unregistered) size: 4 GiB speed: 1600 MT/s volts: curr: 2 min: 2 max: 2
    width (bits): data: 64 total: 64 manufacturer: N/A
    part-no: F3-12800CL9-4GBXL serial: N/A
  Device-2: Channel-A DIMM 1 type: DDR3 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 1600 MT/s volts: curr: 2 min: 2 max: 2
    width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: 99U5471-039.A00LF serial: <filter>
  Device-3: Channel-B DIMM 0 type: DDR3 detail: synchronous unbuffered
  Device-4: Channel-B DIMM 1 type: no module installed
  Info: model: AMD A10-7870K Radeon R7 12 Compute Cores 4C+8G bits: 64
    type: MCP arch: Steamroller level: v2 built: 2014 process: GF 28nm
    family: 0x15 (21) model-id: 0x38 (56) stepping: 1 microcode: 0x6003106
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache:
    L1: 256 KiB desc: d-4x16 KiB; i-2x96 KiB L2: 4 MiB desc: 2x2 MiB
  Speed (MHz): avg: 1696 min/max: 1700/3900 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1696 2: 1696 3: 1696
    4: 1696 bogomips: 31152
  Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 bpext clflush
    cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de
    decodeassists extapic extd_apicid f16c flushbyasid fma fma4 fpu fsgsbase
    fxsr fxsr_opt ht hw_pstate ibs lahf_lm lbrv lm lwp mca mce misalignsse mmx
    mmxext monitor msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_nb pfthreshold pge pni popcnt pse pse36 ptsc rdtscp rep_good sep
    skinit ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 svm svm_lock syscall tbm
    tce topoext tsc tsc_scale vmcb_clean vme vmmcall wdt xop xsave xsaveopt
  Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
  Device-1: Advanced Micro Devices [AMD/ATI] Kaveri [Radeon R7 Graphics]
    vendor: ASRock driver: radeon v: kernel alternate: amdgpu arch: GCN-2
    code: Sea Islands process: GF/TSMC 16-28nm built: 2013-17 ports:
    active: VGA-1 empty: DP-1,DVI-D-1,HDMI-A-1 bus-ID: 00:01.0
    chip-ID: 1002:130f class-ID: 0300
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: radeon unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: radeon display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 444x277mm (17.48x10.91")
    s-diag: 523mm (20.6") monitors: <missing: xrandr>
  Monitor-1: VGA-1 model: LG (GoldStar) W2220 serial: <filter> built: 2009
    res: 1680x1050 dpi: 91 gamma: 1.2 chroma: red: x: 0.639 y: 0.333 green:
    x: 0.294 y: 0.612 blue: x: 0.145 y: 0.051 white: x: 0.314 y: 0.329
    size: 474x296mm (18.66x11.65") diag: 552mm (21.7") ratio: 16:10
    modes: 1680x1050, 1280x1024, 1440x900, 1280x960, 1152x864, 1024x768,
    832x624, 800x600, 640x480, 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1 glx-v: 1.4
    direct-render: yes renderer: KAVERI (radeonsi LLVM 18.1.8 DRM 2.50
    6.11.10-2-MANJARO) device-ID: 1002:130f memory: 1000 MiB unified: no
  Device-1: Advanced Micro Devices [AMD/ATI] Kaveri HDMI/DP Audio
    vendor: ASRock driver: snd_hda_intel v: kernel bus-ID: 00:01.1
    chip-ID: 1002:1308 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] FCH Azalia vendor: ASRock
    driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d
    class-ID: 0403
  API: ALSA v: k6.11.10-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: ASRock
    driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
    bus-ID: 04:00.0 chip-ID: 1969:10a1 class-ID: 0200
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 4.32 TiB used: 25.39 GiB (0.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM001-1ER164
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC25 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: MG04ACA200E
    size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: <unknown>
    tech: HDD rpm: 7200 serial: <filter> fw-rev: FP4B scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: HD501LJ
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: <unknown>
    tech: N/A serial: <filter> fw-rev: 0-10 scheme: MBR
  Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-224GB rev: SB00
    dev-links: cdrom
  ID-1: / raw-size: 232.88 GiB size: 228.17 GiB (97.98%)
    used: 25.39 GiB (11.1%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
    label: sys02_ssd uuid: 2dea840c-dda5-42c0-a198-f5d854fb14d7
  ID-1: /dev/sda1 maj-min: 8:1 size: 886.45 GiB fs: ntfs label: st-scsi-01
    uuid: A260122F60120AA5
  ID-2: /dev/sda2 maj-min: 8:2 size: 976.56 GiB fs: ntfs
    label: st-scsi-01-start+sys2 uuid: 248451C3845197DE
  ID-3: /dev/sdc1 maj-min: 8:33 size: 1.82 TiB fs: ntfs label: bak_tosh_2GB
    uuid: 36A8EAA1A8EA5EBD
  ID-4: /dev/sdd1 maj-min: 8:49 size: 465.76 GiB fs: ext4 label: sys01_hd501
    uuid: 38f2b473-9c26-45d2-a022-b326943b6af9
  Hub-1: 1-0:1 info: full speed or root hub ports: 5 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
  Hub-2: 2-0:1 info: full speed or root hub ports: 5 rev: 2.0
  Hub-3: 3-0:1 info: full speed or root hub ports: 5 rev: 2.0
  Hub-4: 4-0:1 info: full speed or root hub ports: 5 rev: 1.1
  Device-1: 4-3:2 info: Trust Keyboard type: mouse,keyboard
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 50mA chip-ID: 145f:0316 class-ID: 0301
  Hub-5: 5-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Hub-6: 6-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-7: 7-0:1 info: super-speed hub ports: 2 rev: 3.0
  Hub-8: 8-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-9: 9-0:1 info: super-speed hub ports: 2 rev: 3.0
  Hub-10: 10-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 10-2:2 info: Pixart Imaging Optical Mouse type: mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 093a:2510 class-ID: 0301
  Hub-11: 11-0:1 info: super-speed hub ports: 2 rev: 3.0
  System Temperatures: cpu: 45.4 C mobo: N/A gpu: radeon temp: 39.0 C
  Fan Speeds (rpm): N/A
  Packages: 1307 pm: pacman pkgs: 1299 libs: 367 tools: pamac pm: flatpak
    pkgs: 8
    1: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    2: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    3: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    4: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    5: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    7: http://manjaro.grena.ge/stable/$repo/$arch
    8: https://manjaro.ynh.ovh/stable/$repo/$arch
    9: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    10: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    11: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    12: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    13: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    14: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    15: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    16: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    17: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    18: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    19: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    20: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    22: https://mirrors2.manjaro.org/stable/$repo/$arch
    23: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    24: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    25: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    26: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    27: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    28: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    29: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    30: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    31: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    32: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    33: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    34: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    35: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    36: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    37: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    38: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    39: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    40: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    41: https://mirror.23m.com/manjaro/stable/$repo/$arch
    42: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    43: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    44: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    45: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    46: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    47: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    48: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    49: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    50: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    51: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    52: https://manjaro.kurdy.org/stable/$repo/$arch
    53: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    54: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    55: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    56: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    57: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    58: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    59: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    60: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    61: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    62: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    63: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    64: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    65: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    66: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    67: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    68: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    69: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    70: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    71: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    72: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    73: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    74: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    75: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    76: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    77: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    78: http://manjaro.mirror.ac.za/stable/$repo/$arch
    79: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    80: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    81: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    82: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    83: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    84: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    85: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    86: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    87: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    88: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    89: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    90: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    91: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    92: https://mirror.init7.net/manjaro/stable/$repo/$arch
    93: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    94: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    95: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    96: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    97: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    98: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    99: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    100: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    101: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    102: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    103: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    104: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    105: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    106: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    107: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    108: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    109: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    110: https://linorg.usp.br/manjaro/stable/$repo/$arch
    111: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    112: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    113: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 237
  1: cpu: 100% command: ps pid: 28490 mem: 3.57 MiB (0.0%)
  2: cpu: 30.4% command: floorp pid: 26472 mem: 544.1 MiB (3.6%)
  3: cpu: 17.3% command: floorp pid: 27863 mem: 317.9 MiB (2.1%)
  4: cpu: 11.9% command: floorp pid: 27813 mem: 302.6 MiB (2.0%)
  5: cpu: 7.5% command: xfce4-terminal pid: 28457 mem: 49.5 MiB (0.3%)
  Memory top: 5 of 237
  1: mem: 609.7 MiB (4.0%) command: plasmashell pid: 716 cpu: 2.1%
  2: mem: 544.1 MiB (3.6%) command: floorp pid: 26472 cpu: 30.4%
  3: mem: 317.9 MiB (2.1%) command: floorp pid: 27863 cpu: 17.3%
  4: mem: 308.2 MiB (2.0%) command: floorp pid: 27352 cpu: 5.1%
  5: mem: 302.6 MiB (2.0%) command: floorp pid: 27813 cpu: 11.9%
  Processes: 237 Power: uptime: 3h 9m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 5.81 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: N/A Shell: Bash v: 5.2.37 running-in: xfce4-terminal
    inxi: 3.3.36
[ik@rg ~]$
Thank you.
With this information, others might better determine whether there are specific system-related factors that might be contributing.
In the meantime;
You might also try removing the .cache directory.
It is safe to delete this, but it must not be done while the GUI is not running. After deletion, the directory content will be progressively recreated with fresh data as you continue using your computer.
1. Reboot to the SDDM login screen.
2. Login via a TTY:
Ctrl+Alt+F3
3.Remove the .cache directory:
rm -rf ~/.cache
4. When completed, logout from TTY, switch to SDDM:
Ctrl+Alt+F2
and reboot.
Please note any relevant changes as a result of this.
Screenshots are not encouraged for text content. Pasting to a preformatted text box (as you did) is always preferred. Screenshots with no apparent value will often be removed by the Moderation team.
Your general forum privileges will increase the more you actively participate in the forum; that is, read links given, use forum features, etc; it’s fairly automated as part of Discourse, which the Manjaro forum is built upon.
Quick tip: Currently you cannot post live links either – a practical workaround follows this example:
https://forum.manjaro.org
This still allows others to copy/paste the URL with relative ease, if needed.
Removed the whole .cache directory from tty at login, but still the same issue.
Please note, and as I mentioned already, just enabling preference “Show preview thumbnails” makes all icons load normally after login. This indicates that this issue is not related to a corrupted cache.
Does the issue also occur when you are logged into a Plasma Wayland session?
Just tried Wayland, but same problem.
Just what is it you’re expecting to happen when enabling or disabling “Show Previews”? So far, you seem to be describing what normally should happen, with or without logging out/in.
Your responses up until now have been (paraphrasing) “Did that. It didn’t work”. It would be more helpful from the onset if you had listed those things you have tried in your first post.
Please, list everything you have tried and show the results, so that you’re not causing further unnecessary duplication of effort from those wishing to help.
I expect “Disabling previews” to stop showing mini previews of images files, linked on the desktop. Instead I like to see the general image symbol, different in colour depending on image type.
Please do not confuse this with regular application icons when apps have been added from launcher to desktop. All those apps have a different different app icon (different symbol and color, e.g. Xfce terminal or LibreOffice Writer).
But shown is just the same placeholder icon, exactly the same black-white symbol for any application linked on desktop.
Any desktop icons should be loaded automatically, showing the specific application symbol, and certainly this worked all the time before.
Again, this happens only after login or auto-login. Once refreshed (just by drawing a rectangle around all icons with the mouse) icons are shown until next login or boot.
There was just one thing I missed in my first post: Creating a new user account for testing purpose as suggested above. I apologize, I did not remember this at the time. But there is nothing else to mention.
There is no confusion.
This too is what I would expect, and indeed is the result of disabling “Show Previews”; document previews are replaced in favour of the default document icon; “document” also includes images, in this respect.
I cannot reproduce what you describe. I have since returned to Wayland and will spend no further time chasing this. Whatever the issue might be seems specific to you; or, at least, I can find no known information that suggests otherwise.
Perhaps it might be an artifact of some other condition. I have no way of determining what that might be. You might try working your way though the Known Issues and Solutions sections of recent Update announcements to see if any might apply to you, and subsequently have any affect on this apparent condition.
This was really helpful, but anyway, thanks for your and others attention.
On the chance that others might notice anything similar, this thread will remain open for additional input. If the condition seems to magically disappear (after an update, for example) please leave a brief note to that effect.
Some weeks ago, the condition magically disappeared, I am very happy, but unsure what made it disappearing (well, meanwhile there have been lots of updates, but I did not check for this issue after every update).
I see no option to close the issue myself, but I think it can be closed now.
Good to know; and thanks for the update.
This phenomenon tends to occur occasionally. :wink:
I suspect it may have been an artifact of a known issue, which has since been corrected.
Usually, marking a post as the solution will allow the topic to automatically close after a designated time. As there is no specific post to that end, I can simply close this topic, instead.
