Hi,
After an hour, my laptop will automatically suspend due to inactivity. In the Plasma System Settings → Power Management section, I also enabled the ‘While asleep, hibernate after a period of inactivity’ option which causes my laptop to hibernate after being suspended. After waking up my laptop and then logging in, the plasmashell loads just fine. Everything works as expected, but after a minute the entire shell just crashes: the panel, the desktop background, the application menu. It’s gone. Only a black screen along with the cursor remain. Fortunately, I can still open my terminal with CTRL+ALT+T and then type kstart5 plasmashell
. This has been my interim solution, but I would like to know how I can resolve this permanantly.
Here’s my system info:
Kernel: 5.10.36-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=20873ee3-6da2-4348-bd86-fce85dbf7109 rw quiet apparmor=1
security=apparmor resume=UUID=9bde9cdb-63b1-42c7-8d51-ff054ceb9982
udev.log_priority=3
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1
dm: LightDM 1.30.0, SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: XPS 13 7390 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0G2D0W v: A00 serial: <filter> UEFI: Dell v: 1.7.0
date: 10/22/2020
ID-1: BAT0 charge: 49.4 Wh (100.0%) condition: 49.4/52.0 Wh (95.0%)
volts: 8.4 min: 7.6 model: SMP DELL G8VCF6C type: Li-poly serial: <filter>
status: Full
RAM: total: 15.34 GiB used: 3.56 GiB (23.2%)
Info: Quad Core model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: DE cache: L2: 8 MiB bogomips: 36812
Speed: 800 MHz min/max: 400/4900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x2160 s-dpi: 96 s-size: 506x570mm (19.9x22.4")
s-diag: 762mm (30")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 168 size: 290x160mm (11.4x6.3")
diag: 331mm (13")
Monitor-2: DP1-1 res: 1920x1080 hz: 60 dpi: 92 size: 530x300mm (20.9x11.8")
diag: 609mm (24")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.0.3
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.10.36-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: yes
Device-1: Intel Wi-Fi 6 AX200 vendor: Rivet Networks driver: iwlwifi
v: kernel port: efa0 bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 4-1.3:13 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp59s0u1u3 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-7:2
Report: rfkill ID: hci0 rfk-id: 6 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 122.74 GiB (25.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KXG60ZNV512G NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 10604107 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 459.67 GiB size: 451.46 GiB (98.21%)
used: 121.02 GiB (26.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 20873ee3-6da2-4348-bd86-fce85dbf7109
used: 33.1 MiB (11.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 5824-77B5
ID-1: swap-1 type: partition size: 16.97 GiB used: 1.69 GiB (10.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 9bde9cdb-63b1-42c7-8d51-ff054ceb9982
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-7:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-2: 1-9:14 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Device-1: 1-9.1:15 info: Areson Corp Elecom MR-K013 Multicard Reader
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 25a7:fa61 class-ID: 0301
Device-2: 1-9.5:22 info: Anker USB-C Hub Device type: Billboard driver: N/A
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 291a:8380
class-ID: 1100 serial: <filter>
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-6: 4-1:11 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Device-1: 4-1.2:12 info: Genesys Logic SD Card Reader and Writer
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s
power: 896mA chip-ID: 05e3:0749 class-ID: 0806 serial: <filter>
Device-2: 4-1.3:13 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 269 Uptime: 4d 9h 10m wakeups: 7629 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 alt: 8 clang: 11.1.0 Packages: 1626
pacman: 1616 lib: 486 snap: 10 Shell: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.04
