Just finished fixing a bunch of problems that went wrong with the latest update. After which I was able to log in and play some games. That was yesterday, when I turned the computer on today the monitors will just disconnect.
inxi -Fazy
12System:
12Kernel 5.9.11-3-MANJARO x86_64 12bits 64 12compiler gcc 12v 10.2.0
12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_202 quiet systemd.show_status=1
apparmor=1 security=apparmor driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
12Console N/A 12wm kwin_x11 12Distro Manjaro Linux
12Machine:
12Type Desktop 12Mobo Micro-Star 12model B450 TOMAHAWK MAX (MS-7C02) 12v 1.0
12serial <filter> 12UEFI American Megatrends 12v 3.70 12date 06/09/2020
12CPU:
12Info 8-Core 12model AMD Ryzen 7 3700X 12socket AM4 12bits 64 12type MT MCP
12arch Zen 2 12family 17 (23) 12model-id 71 (113) 12stepping N/A 12microcode 8701021
12L1 cache 512 KiB 12L2 cache 4 MiB 12L3 cache 31.2 MiB
12flags avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
12bogomips 115246
12Speed 1865 MHz 12min/max 2200/3600 MHz 12base/boost 3600/4400 12boost enabled
12volts 1.1 V 12ext-clock 100 MHz 12Core speeds (MHz) 121 1865 122 2800 123 1863 124 1860
125 2195 126 2200 127 2194 128 2194 129 1866 1210 1866 1211 2198 1212 2200 1213 2200 1214 2198
1215 1861 1216 2793
12Vulnerabilities 12Type itlb_multihit 12status Not affected
12Type l1tf 12status Not affected
12Type mds 12status Not affected
12Type meltdown 12status Not affected
12Type spec_store_bypass
12mitigation Speculative Store Bypass disabled via prctl and seccomp
12Type spectre_v1
12mitigation usercopy/swapgs barriers and __user pointer sanitization
12Type spectre_v2 12mitigation Full AMD retpoline, IBPB: conditional, STIBP:
conditional, RSB filling
12Type srbds 12status Not affected
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 Conexant Systems CX23887/8 PCIe Broadcast Audio and Video Decoder
with 3D Comb
12vendor Hauppauge works 12driver cx23885 12v 0.0.4 12bus ID 21:00.0
12chip ID 14f1:8880
12Device-2 AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
12vendor Sapphire Limited 12driver amdgpu 12v kernel 12bus ID 28:00.0
12chip ID 1002:731f
12Display 12server X.Org 1.20.10 12compositor kwin_x11 12driver amdgpu
12note n/a (using device driver) 12display ID :0 12screens 1
12Screen-1 0 12s-res 3840x1080 12s-dpi 96 12s-size 1016x285mm (40.0x11.2")
12s-diag 1055mm (41.5")
12Monitor-1 DisplayPort-0 12res 1920x1080 12hz 60 12dpi 96
12size 510x287mm (20.1x11.3") 12diag 585mm (23")
12Monitor-2 HDMI-A-0 12res 1920x1080 12hz 60 12dpi 94 12size 521x293mm (20.5x11.5")
12diag 598mm (23.5")
12OpenGL 12renderer AMD Radeon RX 5600 XT (NAVI10 DRM 3.39.0 5.9.11-3-MANJARO
LLVM 11.0.0)
12v 4.6 Mesa 20.3.1 12direct render Yes
12Audio:
with 3D Comb
12chip ID 14f1:8880
12Device-2 AMD Navi 10 HDMI Audio 12driver snd_hda_intel 12v kernel 12bus ID 28:00.1
12chip ID 1002:ab38
12Device-3 AMD Starship/Matisse HD Audio 12vendor Micro-Star MSI
12driver snd_hda_intel 12v kernel 12bus ID 2a:00.4 12chip ID 1022:1487
12Device-4 Kingston HyperX Cloud Revolver S 12type USB
12driver hid-generic,snd-usb-audio,usbhid 12bus ID 1-2:2 12chip ID 0951:16ad
12serial <filter>
12Sound Server ALSA 12v k5.9.11-3-MANJARO
12Network:
12Device-1 Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
12vendor Micro-Star MSI 12driver r8169 12v kernel 12port f000 12bus ID 22:00.0
12chip ID 10ec:8168
12IF enp34s0 12state up 12speed 1000 Mbps 12duplex full 12mac <filter>
12Drives:
12Local Storage 12total 2.5 TiB 12used 1.89 TiB (75.8%)
12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Western Digital
12model WDS500G3X0C-00SJG0 12size 465.76 GiB 12block size 12physical 512 B
12logical 512 B 12speed 31.6 Gb/s 12lanes 4 12serial <filter> 12rev 102000WD
12temp 37.9 C
12SMART yes 12health PASSED 12on 179d 20h 12cycles 873
12read-units 26,009,978 [13.3 TB] 12written-units 16,495,193 [8.44 TB]
12ID-2 /dev/sda 12maj-min 8:0 12vendor Samsung 12model SSD 840 Series
12family based SSDs 12size 111.79 GiB 12block size 12physical 512 B 12logical 512 B
12sata 3.1 12speed 6.0 Gb/s 12serial <filter> 12rev 7B0Q 12temp 26 C
12SMART yes 12state enabled 12health PASSED 12on 2y 48d 0h 12cycles 5636
12written 9.02 TiB
12ID-3 /dev/sdb 12maj-min 8:16 12vendor Samsung 12model SSD 840 Series
12sata 3.1 12speed 6.0 Gb/s 12serial <filter> 12rev 7B0Q 12temp 27 C
12SMART yes 12state enabled 12health PASSED 12on 1y 350d 22h 12cycles 5636
12written 4.46 TiB
12ID-4 /dev/sdc 12maj-min 8:32 12vendor Western Digital 12model WD2003FZEX-00Z4SA0
12family Black 12size 1.82 TiB 12block size 12physical 4096 B 12logical 512 B 12sata 3.0
12speed 6.0 Gb/s 12rotation 7200 rpm 12serial <filter> 12rev 1A01 12temp 35 C
12SMART yes 12state enabled 12health PASSED 12on 2y 333d 19h 12cycles 1929
12ID-5 /dev/sdd 12maj-min 8:48 12type USB 12vendor Lexar 12model USB Flash Drive
12size 7.47 GiB 12block size 12physical 512 B 12logical 512 B 12serial <filter>
12rev 8.07
12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
12Partition:
12ID-1 / 12raw size 100 GiB 12size 97.93 GiB (97.93%) 12used 53.79 GiB (54.9%)
12fs ext4 12block size 4096 B 12dev /dev/dm-2 12maj-min 254:2
12mapped VolGroup00-root--lv
12ID-2 /boot/efi 12raw size 550 MiB 12size 548.9 MiB (99.80%) 12used 4.4 MiB (0.8%)
12fs vfat 12block size 512 B 12dev /dev/nvme0n1p1 12maj-min 259:1
12ID-3 /home 12raw size 365.22 GiB 12size 358.49 GiB (98.16%)
12used 305.05 GiB (85.1%) 12fs ext4 12block size 4096 B 12dev /dev/dm-3
12maj-min 254:3 12mapped VolGroup00-home--lv
12Swap:
12Alert No Swap data was found.
12Sensors:
12System Temperatures 12cpu 46.0 C 12mobo N/A 12gpu amdgpu 12temp 39.0 C 12mem 40.0 C
12Fan Speeds (RPM) N/A 12gpu amdgpu 12fan 0
12Info:
12Processes 388 12Uptime 20m 12wakeups 0 12Memory 15.65 GiB 12used 2.62 GiB (16.7%)
12Init systemd 12v 247 12Compilers 12gcc 10.2.0 12clang 11.0.0 12Packages 12pacman 1831
12lib 526 12flatpak 0 12Client Unknown Client: systemd 12inxi 3.2.01
This is after adding amdgpu.dc=0 to kernal parameters, without it the screen will just boot to a completly green screen.
journalctl
Jan 03 12:14:50 MANJAROGAMING sddm[708]: Initializing...
Jan 03 12:14:50 MANJAROGAMING sddm[708]: Starting...
Jan 03 12:14:50 MANJAROGAMING sddm[708]: Logind interface found
Jan 03 12:14:50 MANJAROGAMING sddm[708]: Adding new display on vt 1 ...
Jan 03 12:14:50 MANJAROGAMING sddm[708]: Loading theme configuration from ""
Jan 03 12:14:50 MANJAROGAMING sddm[708]: Display server starting...
Jan 03 12:14:50 MANJAROGAMING sddm[708]: Adding cookie to "/var/run/sddm/{b27e953f-72d1-4b67-86e0-d1f815c0bd06}"
Jan 03 12:14:50 MANJAROGAMING sddm[708]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{b27e953f-72d1-4b67-86e0-d1f815c0bd06} -noreset -displayfd 17
Jan 03 12:14:50 MANJAROGAMING audit[733]: NETFILTER_CFG table=filter family=2 entries=0 op=xt_register pid=733 comm="modprobe"
Jan 03 12:14:50 MANJAROGAMING kernel: audit: type=1325 audit(1609697690.240:50): table=filter family=2 entries=0 op=xt_register pid=733 comm="modprobe"
Jan 03 12:14:50 MANJAROGAMING audit[736]: NETFILTER_CFG table=filter family=10 entries=0 op=xt_register pid=736 comm="modprobe"
Jan 03 12:14:50 MANJAROGAMING kernel: audit: type=1325 audit(1609697690.290:51): table=filter family=10 entries=0 op=xt_register pid=736 comm="modprobe"
Jan 03 12:14:50 MANJAROGAMING audit[739]: NETFILTER_CFG table=filter family=7 entries=0 op=xt_register pid=739 comm="modprobe"
Jan 03 12:14:50 MANJAROGAMING kernel: audit: type=1325 audit(1609697690.333:52): table=filter family=7 entries=0 op=xt_register pid=739 comm="modprobe"
Jan 03 12:14:50 MANJAROGAMING audit[726]: NETFILTER_CFG table=filter family=7 entries=0 op=xt_register pid=726 comm="daemon-init"
Jan 03 12:14:50 MANJAROGAMING audit[212]: NETFILTER_CFG table=filter family=7 entries=0 op=xt_unregister pid=212 comm="kworker/u64:4"
Jan 03 12:14:50 MANJAROGAMING avahi-daemon[545]: Leaving mDNS multicast group on interface enp34s0.IPv6 with address fe80::2d8:61ff:fea9:d412.
Jan 03 12:14:50 MANJAROGAMING avahi-daemon[545]: Joining mDNS multicast group on interface enp34s0.IPv6 with address 2607:0:2ff:6600:2d8:61ff:fea9:d412.
Jan 03 12:14:50 MANJAROGAMING avahi-daemon[545]: Registering new address record for 2607:0:2ff:6600:2d8:61ff:fea9:d412 on enp34s0.*.
Jan 03 12:14:50 MANJAROGAMING avahi-daemon[545]: Withdrawing address record for fe80::2d8:61ff:fea9:d412 on enp34s0.
Jan 03 12:14:52 MANJAROGAMING kernel: [drm] PCIE GART of 512M enabled (table at 0x0000008000000000).
Jan 03 12:14:52 MANJAROGAMING kernel: [drm] PSP is resuming...
Jan 03 12:14:52 MANJAROGAMING kernel: [drm] reserve 0x900000 from 0x800f400000 for PSP TMR
Jan 03 12:14:52 MANJAROGAMING kernel: amdgpu 0000:28:00.0: amdgpu: RAS: optional ras ta ucode is not available
Jan 03 12:14:52 MANJAROGAMING kernel: amdgpu 0000:28:00.0: amdgpu: RAP: optional rap ta ucode is not available
Jan 03 12:14:52 MANJAROGAMING kernel: amdgpu 0000:28:00.0: amdgpu: SMU is resuming...
Jan 03 12:14:52 MANJAROGAMING kernel: amdgpu 0000:28:00.0: amdgpu: smu driver if version = 0x00000036, smu fw if version = 0x00000037, smu fw version = 0x002a3d00 (42.61.0)
Jan 03 12:14:52 MANJAROGAMING kernel: amdgpu 0000:28:00.0: amdgpu: SMU driver if version not matched
Jan 03 12:14:54 MANJAROGAMING kernel: amdgpu 0000:28:00.0: amdgpu: failed send message: EnableAllSmuFeatures (6) param: 0x00000000 response 0xffffffc2
Jan 03 12:14:54 MANJAROGAMING kernel: amdgpu 0000:28:00.0: amdgpu: Failed to enable requested dpm features!
Jan 03 12:14:54 MANJAROGAMING kernel: amdgpu 0000:28:00.0: amdgpu: Failed to setup smc hw!
Jan 03 12:14:54 MANJAROGAMING kernel: [drm:amdgpu_device_ip_resume_phase2 [amdgpu]] *ERROR* resume of IP block <smu> failed -62
Jan 03 12:14:54 MANJAROGAMING kernel: amdgpu 0000:28:00.0: amdgpu: amdgpu_device_ip_resume failed (-62).
Jan 03 12:14:54 MANJAROGAMING kernel: snd_hda_intel 0000:28:00.1: refused to change power state from D3hot to D0
Jan 03 12:14:55 MANJAROGAMING kernel: snd_hda_intel 0000:28:00.1: CORB reset timeout#2, CORBRP = 65535
Jan 03 12:14:55 MANJAROGAMING kernel: snd_hda_codec_hdmi hdaudioC0D0: Unable to sync register 0x2f0d00. -5
Jan 03 12:14:55 MANJAROGAMING kernel: snd_hda_codec_hdmi hdaudioC0D0: HDMI ATI/AMD: no speaker allocation for ELD
Jan 03 12:15:05 MANJAROGAMING sddm[708]: Failed to read display number from pipe
Jan 03 12:15:05 MANJAROGAMING sddm[708]: Display server stopping...
Jan 03 12:15:05 MANJAROGAMING sddm[708]: Attempt 1 starting the Display server on vt 1 failed
Jan 03 12:15:06 MANJAROGAMING kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma1 timeout, signaled seq=1, emitted seq=2
Jan 03 12:15:06 MANJAROGAMING kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process pid 0 thread pid 0
Jan 03 12:15:06 MANJAROGAMING kernel: amdgpu 0000:28:00.0: amdgpu: GPU reset begin!
Jan 03 12:15:06 MANJAROGAMING kernel: general protection fault, probably for non-canonical address 0x3665303363326163: 0000 [#1] PREEMPT SMP NOPTI
Jan 03 12:15:06 MANJAROGAMING kernel: CPU: 5 PID: 245 Comm: kworker/5:2 Tainted: G S 5.10.2-2-MANJARO #1
Jan 03 12:15:06 MANJAROGAMING kernel: Hardware name: Micro-Star International Co., Ltd MS-7C02/B450 TOMAHAWK MAX (MS-7C02), BIOS 3.70 06/09/2020
Jan 03 12:15:06 MANJAROGAMING kernel: Workqueue: events drm_sched_job_timedout [gpu_sched]
Jan 03 12:15:06 MANJAROGAMING kernel: RIP: 0010:kernel_queue_uninit+0xd/0xf0 [amdgpu]
Jan 03 12:15:06 MANJAROGAMING kernel: Code: ee 48 89 c7 e8 a4 f9 ff ff 84 c0 0f 84 8c b2 1f 00 4c 89 e0 5d 41 5c 41 5d c3 0f 1f 00 0f 1f 44 00 00 55 48 8b 47 10 48 89 fd <8b> 50 28 83 fa 02 74 78 83 fa 03 0f 84 b1 00 00 00 48 8b 7f 08 4c
Jan 03 12:15:06 MANJAROGAMING kernel: RSP: 0018:ffffae2a024dfd50 EFLAGS: 00010246
Jan 03 12:15:06 MANJAROGAMING kernel: RAX: 3665303363326163 RBX: ffff9abf1f59c800 RCX: 000000008080007e
Jan 03 12:15:06 MANJAROGAMING kernel: RDX: 000000008080007f RSI: 0000000000000001 RDI: ffff9abf205adc80
Jan 03 12:15:06 MANJAROGAMING kernel: RBP: ffff9abf205adc80 R08: 0000000000000001 R09: 0000000000000000
Jan 03 12:15:06 MANJAROGAMING kernel: R10: ffff9abf16b6c560 R11: 0000000000000001 R12: ffff9abf1f59c8d0
Jan 03 12:15:06 MANJAROGAMING kernel: R13: ffff9abf20400000 R14: ffff9abf01701000 R15: ffff9abf017010b8
Jan 03 12:15:06 MANJAROGAMING kernel: FS: 0000000000000000(0000) GS:ffff9ac1fe940000(0000) knlGS:0000000000000000
Jan 03 12:15:06 MANJAROGAMING kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jan 03 12:15:06 MANJAROGAMING kernel: CR2: 00007fa731345000 CR3: 00000001b8a10000 CR4: 0000000000350ee0
Jan 03 12:15:06 MANJAROGAMING kernel: Call Trace:
Jan 03 12:15:06 MANJAROGAMING kernel: stop_cpsch+0xa2/0xc0 [amdgpu]
Jan 03 12:15:06 MANJAROGAMING kernel: kgd2kfd_suspend.part.0+0x2f/0x40 [amdgpu]
Jan 03 12:15:06 MANJAROGAMING kernel: kgd2kfd_pre_reset+0x3f/0x50 [amdgpu]
Jan 03 12:15:06 MANJAROGAMING kernel: amdgpu_device_gpu_recover.cold+0x36e/0x95d [amdgpu]
Jan 03 12:15:06 MANJAROGAMING kernel: amdgpu_job_timedout+0x121/0x140 [amdgpu]
Jan 03 12:15:06 MANJAROGAMING kernel: drm_sched_job_timedout+0x64/0xe0 [gpu_sched]
Jan 03 12:15:06 MANJAROGAMING kernel: process_one_work+0x1d6/0x3a0
Jan 03 12:15:06 MANJAROGAMING kernel: worker_thread+0x4d/0x3d0
Jan 03 12:15:06 MANJAROGAMING kernel: ? rescuer_thread+0x410/0x410
Jan 03 12:15:06 MANJAROGAMING kernel: kthread+0x133/0x150
Jan 03 12:15:06 MANJAROGAMING kernel: ? __kthread_bind_mask+0x60/0x60
Jan 03 12:15:06 MANJAROGAMING kernel: ret_from_fork+0x22/0x30
Jan 03 12:15:06 MANJAROGAMING kernel: Modules linked in: ebtable_filter ebtables ip6table_filter ip6_tables iptable_filter rpcsec_gss_krb5 auth_rpcgss nfsv4 dns_resolver nfs lockd grace sunrpc nfs_ssc fscache mousedev snd_usb_audio snd_usbmidi_lib snd_rawmidi usbhid snd_seq_device mt2131 s5h1409 tda8290 tuner cx25840 rfkill amdgpu snd_hda_codec_realtek snd_hda_codec_generic cx23885 ledtrig_audio snd_hda_codec_hdmi altera_ci tda18271 nct6775 snd_hda_intel altera_stapl hwmon_vid m88ds3103 snd_intel_dspcfg tveeprom pktcdvd soundwire_intel wmi_bmof soundwire_generic_allocation cx2341x soundwire_cadence videobuf2_dvb dvb_core snd_hda_codec i2c_mux videobuf2_dma_sg snd_hda_core videobuf2_vmalloc videobuf2_memops snd_hwdep videobuf2_v4l2 gpu_sched soundwire_bus nls_iso8859_1 videobuf2_common i2c_algo_bit vfat edac_mce_amd fat videodev snd_soc_core ttm snd_compress ac97_bus mc snd_pcm_dmaengine drm_kms_helper kvm r8169 snd_pcm snd_timer cec snd realtek sp5100_tco irqbypass syscopyarea mdio_devres sysfillrect sysimgblt rapl
Jan 03 12:15:06 MANJAROGAMING kernel: pcspkr k10temp fb_sys_fops soundcore libphy i2c_piix4 wmi pinctrl_amd gpio_amdpt gpio_generic mac_hid acpi_cpufreq drm uinput sg crypto_user fuse agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 dm_crypt cbc encrypted_keys trusted tpm dm_mod crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel aesni_intel crypto_simd cryptd glue_helper ccp rng_core sr_mod cdrom xhci_pci
Jan 03 12:15:06 MANJAROGAMING kernel: fbcon: Taking over console
Jan 03 12:15:06 MANJAROGAMING kernel: ---[ end trace 209a34a50458372c ]---
Jan 03 12:15:06 MANJAROGAMING kernel: ------------[ cut here ]------------
Jan 03 12:15:06 MANJAROGAMING kernel: WARNING: CPU: 5 PID: 245 at kernel/rcu/tree_plugin.h:297 rcu_note_context_switch+0x42/0x480
Jan 03 12:15:06 MANJAROGAMING kernel: CPU: 5 PID: 245 Comm: kworker/5:2 Tainted: G S D 5.10.2-2-MANJARO #1
Jan 03 12:15:06 MANJAROGAMING kernel: RIP: 0010:rcu_note_context_switch+0x42/0x480
Jan 03 12:15:06 MANJAROGAMING kernel: Code: c3 c0 ce 02 00 65 48 03 1d f3 f5 4f 51 0f 1f 44 00 00 40 84 ed 75 15 65 48 8b 04 25 c0 7b 01 00 8b 90 b0 03 00 00 85 d2 7e 02 <0f> 0b 65 48 8b 04 25 c0 7b 01 00 8b 80 b0 03 00 00 85 c0 7e 0a 41
Jan 03 12:15:06 MANJAROGAMING kernel: RSP: 0018:ffffae2a024df7a0 EFLAGS: 00010002
Jan 03 12:15:06 MANJAROGAMING kernel: RAX: ffff9abf0a28bd80 RBX: ffff9ac1fe96cec0 RCX: 0000000000000000
Jan 03 12:15:06 MANJAROGAMING kernel: RDX: 0000000000000001 RSI: ffffffffaf495b8b RDI: 0000000000000000
Jan 03 12:15:06 MANJAROGAMING kernel: RBP: 0000000000000000 R08: 0000000000561884 R09: ffff9ac1fe96c230
Jan 03 12:15:06 MANJAROGAMING kernel: R10: 0000000000000002 R11: 00000000003b9bab R12: 000000000002c100
Jan 03 12:15:06 MANJAROGAMING kernel: R13: ffff9abf0a28bd80 R14: ffff9abf0a28bd80 R15: ffff9ac1fe96c100
Jan 03 12:15:06 MANJAROGAMING kernel: __schedule+0xae/0x810
Jan 03 12:15:06 MANJAROGAMING kernel: schedule+0x5b/0xc0
Jan 03 12:15:06 MANJAROGAMING kernel: schedule_timeout+0x11c/0x160
Jan 03 12:15:06 MANJAROGAMING kernel: wait_for_completion+0x9e/0x100
Jan 03 12:15:06 MANJAROGAMING kernel: virt_efi_query_variable_info+0x141/0x150
Jan 03 12:15:06 MANJAROGAMING kernel: efi_query_variable_store+0x7b/0x1e0
Jan 03 12:15:06 MANJAROGAMING kernel: ? vsnprintf+0x6e/0x4f0
Jan 03 12:15:06 MANJAROGAMING kernel: efivar_entry_set_safe+0xbd/0x210
Jan 03 12:15:06 MANJAROGAMING kernel: efi_pstore_write+0x12d/0x1a0
Jan 03 12:15:06 MANJAROGAMING kernel: pstore_dump+0x1b3/0x2f0
Jan 03 12:15:06 MANJAROGAMING kernel: kmsg_dump+0xa8/0xd0
Jan 03 12:15:06 MANJAROGAMING kernel: oops_end+0x61/0xd0
Jan 03 12:15:06 MANJAROGAMING kernel: exc_general_protection+0x202/0x3c0
Jan 03 12:15:06 MANJAROGAMING kernel: asm_exc_general_protection+0x1e/0x30
Jan 03 12:15:06 MANJAROGAMING kernel: ---[ end trace 209a34a50458372d ]---
Jan 03 12:15:06 MANJAROGAMING kernel: CR2: 00007fa731345000 CR3: 00000001042bc000 CR4: 0000000000350ee0
Jan 03 12:15:07 MANJAROGAMING sddm[708]: Display server starting...
Jan 03 12:15:07 MANJAROGAMING sddm[708]: Adding cookie to "/var/run/sddm/{b27e953f-72d1-4b67-86e0-d1f815c0bd06}"
Jan 03 12:15:07 MANJAROGAMING sddm[708]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{b27e953f-72d1-4b67-86e0-d1f815c0bd06} -noreset -displayfd 17
Jan 03 12:15:09 MANJAROGAMING systemd[1]: systemd-hostnamed.service: Succeeded.
Jan 03 12:15:09 MANJAROGAMING audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 03 12:15:09 MANJAROGAMING kernel: kauditd_printk_skb: 2 callbacks suppressed
Jan 03 12:15:09 MANJAROGAMING kernel: audit: type=1131 audit(1609697709.673:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 03 12:15:09 MANJAROGAMING audit[410]: NETFILTER_CFG table=filter family=7 entries=0 op=xt_unregister pid=410 comm="kworker/u64:14"
Jan 03 12:15:09 MANJAROGAMING kernel: audit: type=1325 audit(1609697709.750:56): table=filter family=7 entries=0 op=xt_unregister pid=410 comm="kworker/u64:14"
Jan 03 12:15:09 MANJAROGAMING audit: BPF prog-id=12 op=UNLOAD
Jan 03 12:15:09 MANJAROGAMING audit: BPF prog-id=11 op=UNLOAD
Jan 03 12:15:09 MANJAROGAMING kernel: audit: type=1334 audit(1609697709.830:57): prog-id=12 op=UNLOAD
Jan 03 12:15:09 MANJAROGAMING kernel: audit: type=1334 audit(1609697709.830:58): prog-id=11 op=UNLOAD
Jan 03 12:15:09 MANJAROGAMING systemd-timesyncd[535]: Initial synchronization to time server [2606:4700:f1::123]:123 (2.manjaro.pool.ntp.org).
