I recently made the upgrade from 5.13 → 5.15. And everything is working fine.
However, when rebooting my computer I am given an error:
error: file '/boot/vmlinuz-5.13.-x86_64 not found. error: you need to load the kernel first.
That makes sense, because I removed 5.13 after installing 5.15. So now, everytime I reboot I need to go into the emacs-like editor and manually replace instances of 5.13 with 5.15 to get the kernel to load.
How can I edit whatever file that is (the one that is opened by the emacs-like editor) so I can get this machine to stop trying to boot 5.13? Thanks in advance.
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
done
Exact same problem… instead of i915 (intel builtin?) my system was amdgpu (I imagine the other backlight issue is in play any time the backlight isn’t targeting a virtual device)…
So, seems if you’ve implemented the backlight workaround (at least two variations), it’d be a solid idea to make sure everything was generated as expected, before rebooting.
To that end, go ahead and take the time to revisit your workaround and see if there’s a more easily managed fix (this was the 3rd time the workaround that worked for me botched and automated process in a way that was more frustrating than my backlight issue itself… I’ve changed my stance on it).
