Hello,
I had virtualbox running, but after a recent update it now has a problem I am unable to figure out. When attempting to start a virtual machine, I get the error:
The VirtualBox Linux kernel driver is either not loaded or not set up correctly.
I believe this is because the kernel was updated, but the virtualbox driver package is not found. After the system update and a reboot, no modules are loaded, so virtualbox has an issue. I ran mhwd-kernel -li and it says:
Currently running: 5.9.16-1-MANJARO (linux59)
** * linux414**
** * linux59**
I can see that linux414 virtualbox host modules are installed, however I cannot seem to install the linux59 host modules. I ran sudo pacman -Syu linux59-virtualbox-host-modules and it says:
error: target not found: linux59-virtualbox-host-modules
Does anyone know why I am unable to find that package? Any help would be appreciated.
Thanks
