After kernel update from 316 to 414
kde
kernel
#1
#2
So, can you select 3.16 in Grub menu? Does it boot?
#3
No , I cant
#4
did you remove Linux 3.16?
#5
error parsing pcc subspaces from pcct
ToDo: on Linux-Windows dual boot. Disable hiberboot (fast startup) in Windows
Windows > Control Panel > All Control Panel Items > Power Options > System Settings > Change settings that are currently unavailable (UAC) > Turn on fast startup (recommended) — unchecked this.
#6
Thanks, I solved the problem and that was because of Windows boot
#7
Thank you very much :slight_smile:
#8
please like to happen
