I have installed Manjaro 21.1.0 off the latest minimal ISO. Chose to erase the hard drive and install into a new BTRFS partition with encryption. No issues during installation, but after restarting the computer, I get the message “Start PXE over IPv4”.
I have reviewed the boot order, which seemed fine. Removed the Manjaro boot option since it’s not working anyway. Checked the NVME in the BIOS, it’s all good.
Booted into the live system to reinstall and reconfigure GRUB. Mounted the encrypted LUKS partition. Now I have two relevant partitions:
/dev/nvme0n1p1
: EFI partition -
/dev/mapper/luks-abcdef
: Root partition
Following the instructions from another thread in this forum, I did the following:
# mount /dev/mapper/luks-abcdef /mnt
# mount /dev/nvme0n1p1 /mnt/@/boot/efi
If go to /mnt/@/boot/efi
, I can see the EFI
dir inside, so this seems to have worked.
Unfortunately, if I chroot like this:
# manjaro-chroot /mnt/@ /bin/bash
…and go to /boot/efi
, the directory is empty.
If I try to do a grub-install
, I get this unsurprising error:
# grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
Installing for x86_64-efi platform.
grub-install: error: /boot/efi doesn't look like an EFI partition
This isn’t the first time that I have to fix GRUB, but the first time using BTRFS and the first time that it isn’t working. Can anyone see what I’m doing wrong?
