Hello there,
I am a realtively new linux user who used ubuntu but moved now to manjaro (Manjaro Linux; Build ID: rolling) and gnome (41.2). Unfortunately, already in the installation process of manjaro gnome the display starts to flicker. I assume that something went wrong with the graphic drivers. My laptop provides the following hardware:
- Mesa Intel Xe Grapics (TGL GT2) - Graphics
- 11th Gen Intel Core i7-11370H @ 3.30 GHz x 8 - Processor
- Tuxedo Tuxedo InfinityBook Pro 14 Gen6 - Hardware Model of my laptop
I already tried to reinstall manjaro gnome with free and with proprietary drivers but without any success. Moreover I noticed that the problem is not occuring on an external monitor (here, however a scaling problem occurs). By entering mhwd -l
I get the following response:
- video-linux (Version: 2018.05.04; Freedriver: true; Type: Pci)
- video-modesetting (Version: 2020.01.13; Freedriver: true; Type: Pci)
- video-vesa (Version: 2017.03.12; Freedriver: true; Type: Pci)
Here, are the system information:
Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=aae2387d-5aac-424c-a075-bbea0547d5fb rw quiet splash apparmor=1
Desktop: GNOME 41.2 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0
Type: Laptop System: TUXEDO product: TUXEDO InfinityBook Pro 14 Gen6
v: Standard serial: <superuser required>
Mobo: NB02 model: PHxTxX1 v: Standard serial: <superuser required>
UEFI: American Megatrends LLC. v: N.1.15A08 date: 10/18/2021
ID-1: BAT0 charge: 43.5 Wh (82.1%) condition: 53.0/53.0 Wh (100.0%)
volts: 12.1 min: 11.6 model: standard type: Li-ion serial: <filter>
status: Discharging
RAM: total: 31.1 GiB used: 2.86 GiB (9.2%)
RAM Report:
Info: model: 11th Gen Intel Core i7-11370H bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0x9A
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 802 high: 1173 min/max: 400/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 718 2: 1173 3: 601 4: 611
5: 971 6: 941 7: 432 8: 976 bogomips: 52856
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics]
vendor: Tongfang Hongkong Limited driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 3-6:4
chip-ID: 04f2:b71a class-ID: 0e02 serial: <filter>
Display: wayland server: X.org 1.21.1.2 compositor: gnome-shell driver:
loaded: i915 note: n/a (using device driver) - try sudo/root display-ID: 0
Device-1: Intel Tiger Lake-LP Smart Sound Audio
vendor: Tongfang Hongkong Limited driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:a0c8
class-ID: 0403
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 2-1:2 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s13f0u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 3-10:5 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 931.51 GiB used: 8.59 GiB (0.9%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 3B2QEXM7 temp: 26.9 C scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 8.59 GiB (0.9%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: aae2387d-5aac-424c-a075-bbea0547d5fb
label: NO_LABEL uuid: 8F01-00C4
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 2-1:2 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 2 rev: 2.1 speed: 480 Mb/s
Device-1: 3-6:4 info: Chicony HD Webcam type: Video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b71a
Device-2: 3-10:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 4-1:2 info: Genesys Logic USB3.2 Hub ports: 2 rev: 3.2
speed: 5 Gb/s chip-ID: 05e3:0620 class-ID: 0900
Device-1: 4-1.1:3 info: Realtek Card Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA
chip-ID: 0bda:0316 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 43.0 C mobo: 43.0 C
Processes: 315 Uptime: 1h 24m wakeups: 7372 Init: systemd v: 249
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1130 lib: 302
flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.11
Does anyone has a suggestion what I can try to solve this issue?
