Is that inside the ESP( /dev/nvme0n1p2 ) or the 6th partition?
Thats just inside the /mnt/boot/efi like you asked before
That is very strange because:
are identical in that caseā¦
Due to real life (Itās 22:32 here) iām handing the resolution to @stephane if you donāt mind.
Else i can continue in morning my timeā¦
Okay thanks a lot and have a good night !
error in path it should be /boot/efi/EFI/
efibootmgr -c -d /dev/sdX -p N -L "manjaro" -l "\EFI\Manjaro\grubx64.efi"
efibootmgr -v
I donāt understand what do you mean by that
@stephane, the path is correct from the point of view of the ESP, it should not start with the lowercase efiā¦
@koebelt, you seem to have lost your UEFI entry for Manjaroā¦
See the difference of the output you provided, above:
This entry was lost:
Boot0000* manjaro HD(1,GPT,12db9e9d-3025-438a-8b25-02648e6fe6f2,0x800,0x108800)/File(\EFI\Manjaro\grubx64.efi)
Can you provide the complete output of:
- sudo fdisk -x
- ls -la /dev/disk/by-uuid
- ls -la /dev/disk/by-partuuid
Hello back ! Sorry for the delayā¦
Here the output of the commands :
[manjaro@manjaro ~]$ sudo fdisk -x
Disk /dev/nvme0n1: 476.94 GiB, 512110190592 bytes, 1000215216 sectors
Disk model: SK hynix BC511 HFM512GDJTNI-82A0A
Disklabel type: gpt
Disk identifier: 90A7EED1-79A4-4D7E-B97D-039FE87E7D70
First LBA: 34
Last LBA: 1000215182
Alternative LBA: 1000215215
Partition entries LBA: 2
Allocated partition entries: 128
Device Start End Sectors Type-UUID UUID Name Attrs
/dev/nvme0n1p1 2048 1085439 1083392 DE94BBA4-06D1-4D40-A16A-BFD50179D6AC 12DB9E9D-3025-438A-8B25-02648E6FE6F2 Basic data partition
RequiredPartition
/dev/nvme0n1p2 1085440 1290239 204800 C12A7328-F81F-11D2-BA4B-00A0C93EC93B 68D20E24-1153-45E6-8997-64BF6DB004F3 EFI System Partition
/dev/nvme0n1p3 1290240 1323007 32768 E3C9E316-0B5C-4DB8-817D-F92DF00215AE D6844E2F-7FE4-4193-B388-ADC74D5299BF Microsoft reserved partition
/dev/nvme0n1p4 1323008 671746047 670423040 EBD0A0A2-B9E5-4433-87C0-68B6B72699C7 DA960469-A08E-45CA-97D2-CEEEE80FB2DD Basic data partition
/dev/nvme0n1p5 671746048 738861478 67115431 EBD0A0A2-B9E5-4433-87C0-68B6B72699C7 F94F2E3D-0B0A-11EB-B046-34CFF6D96BBE Basic data partition
/dev/nvme0n1p6 738861479 1000215182 261353704 0FC63DAF-8483-4772-8E79-3D69D8477DE4 EA17CCE5-3455-7540-9A5B-22FEB614C6F3
Disk /dev/loop0: 20.84 MiB, 21856256 bytes, 42688 sectors
Disk /dev/loop1: 596.41 MiB, 625385472 bytes, 1221456 sectors
Disk /dev/loop2: 1.61 GiB, 1732997120 bytes, 3384760 sectors
Disk /dev/loop3: 632.48 MiB, 663203840 bytes, 1295320 sectors
Disk /dev/sda: 29.3 GiB, 31457280000 bytes, 61440000 sectors
Disk model: Flash Disk
Disklabel type: dos
Disk identifier: 0x00000000
Device Boot Start End Sectors Id Type Start-C/H/S End-C/H/S Attrs
/dev/sda1 * 64 6077687 6077624 0 Empt 0/2/1 1021/21/24 80
/dev/sda2 6077688 6085879 8192 ef EFI 1021/21/25 1022/91/24
[manjaro@manjaro ~]$ ls -la /dev/disk/by-uuid
total 0
drwxr-xr-x 2 root root 180 Dec 28 15:54 .
drwxr-xr-x 8 root root 160 Dec 28 15:54 ..
lrwxrwxrwx 1 root root 10 Dec 28 15:54 1AFD-57C6 -> ../../sda2
lrwxrwxrwx 1 root root 10 Dec 28 15:54 2020-10-01-14-09-49-00 -> ../../sda1
lrwxrwxrwx 1 root root 15 Dec 28 15:54 3AEB-CFD5 -> ../../nvme0n1p2
lrwxrwxrwx 1 root root 15 Dec 28 15:54 66A8EB30A8EAFD85 -> ../../nvme0n1p1
lrwxrwxrwx 1 root root 15 Dec 28 15:54 ab36f5d2-acbf-4fa5-9122-6ed3aadf980f -> ../../nvme0n1p6
lrwxrwxrwx 1 root root 15 Dec 28 15:54 C492744392743C4C -> ../../nvme0n1p4
lrwxrwxrwx 1 root root 15 Dec 28 15:54 DAED-E00C -> ../../nvme0n1p5
[manjaro@manjaro ~]$ ls -la /dev/disk/by-partuuid
total 0
drwxr-xr-x 2 root root 160 Dec 28 15:54 .
lrwxrwxrwx 1 root root 15 Dec 28 15:54 12db9e9d-3025-438a-8b25-02648e6fe6f2 -> ../../nvme0n1p1
lrwxrwxrwx 1 root root 15 Dec 28 15:54 68d20e24-1153-45e6-8997-64bf6db004f3 -> ../../nvme0n1p2
lrwxrwxrwx 1 root root 15 Dec 28 15:54 d6844e2f-7fe4-4193-b388-adc74d5299bf -> ../../nvme0n1p3
lrwxrwxrwx 1 root root 15 Dec 28 15:54 da960469-a08e-45ca-97d2-ceeee80fb2dd -> ../../nvme0n1p4
lrwxrwxrwx 1 root root 15 Dec 28 15:54 ea17cce5-3455-7540-9a5b-22feb614c6f3 -> ../../nvme0n1p6
lrwxrwxrwx 1 root root 15 Dec 28 15:54 f94f2e3d-0b0a-11eb-b046-34cff6d96bbe -> ../../nvme0n1p5
Ok looking at the combined output of those it seems that either one of us made a mistakeā¦
Which means your UEFI-entry was pointing to partition 1 instead of 2 as intended, soā¦
- Start your Live media iso of Manjaro.
- Open a terminal
- Execute: sudo systemd-mount /dev/nvme0n1p6 /mnt
- Execute: sudo manjaro-chroot /mnt
- We will skip the step to remove the old UEFI-menu entry because you already seem to have lost that oneā¦
- Execute the
efibootmgrline that @stephane gave with modifications, like this:
sudo efibootmgr --verbose --create --disk=/dev/nvme0n1 --part=2 --label=āManjaro Linuxā --loader=ā\EFI\Manjaro\grubx64.efiā - Check the created entry to be sure that it is using the
68d20e24-1153-45e6-8997-64bf6db004f3partition with:
efibootmgr --verbose - Reboot into your system, it should now boot into Manjar because that was last added to the UEFI-menu entriesā¦
Okay it finally works ! I tried to reboot several times into windows and manjaro and it still works just fine !
Thanks a lot to both of you @TriMoon and @stephane !
The mistake was probably on my side, sorry for wasting your time
