I’ll try to be as thorough as reasonably possible.
Yesterday, I started a game I hadn’t played in over two years (Terraria, if that matters). It worked just fine, but when I alt-tabbed out of the game to write something in a text file and went back into the game, my input devices were completely unresponsive. Passing my hand on the entire keyboard did nothing. The game kept running (not frozen) except that, a minute or two later, in the space of a single second, the screen suddenly turned black and displayed these three lines
Starting systemd-udevd version 252.9-1-manjaro
/dev/sda1: recovering journal
/dev/sda1: clean, numbers of files and blocks
just as if the system had rebooted in the background somehow (with the game hiding the fact that it had rebooted), except it stops there with a frozen cursor after those three lines.
And now that’s all it does. Same three lines (slightly different files/blocks numbers, up or down), same frozen cursor. It happens no matter which of my four kernels (5.15, 5.10, 5.4 and 4.19) and their four associated fallbacks I select.
I was told about some things called TTYs accessed via Ctrl+Alt+Fkeys, but it does nothing.
Trying to get in via a live environment, I made a bootable USB drive, set it to take priority when booting, and whether I choose open source or priority drivers, I get pretty much the same result:
Starting systemd-udevd version 252.5-1-manjaro
With a frozen cursor.
Given that I get the same result with all kernels and the USB drive, I’m starting to think that this problem is real bad, a lot worse than just my Manjaro install being damaged. Could it be a hardware problem? If so, what kind?
I am quite lost and don’t know where to even begin trying to identify the cause. Any information is appreciated.
