Add Software does not search AUR
#1
Hi,
I just installed a fresh copy of Manjaro (with extras). But for some reason, I can not search AUR.
I followed the suggestions at Pamac Doesn't Search AUR
But this does not seem to find a solution.
Pacman config @ https://www.dropbox.com/s/nsu89n0rz1fkmvm/Pacman%20config.txt?dl=0
System info: https://www.dropbox.com/s/pw3yg4kjeal960g/System%20Details.txt?dl=0
Thanks,
Chris
[wiki] Manjaro - Updates and AUR
#2
AUR is disabled by default.
In Pamac -> Hamburger Menu -> Preferences
If for reasons unknown the app yaourt is missing you cannot enable AUR.
sudo pacman -S yaourt
#3
Hi fhdk,
I did turn on AUR under the GUI and I checked the config file to be sure.
See config output of Pacman config @ https://www.dropbox.com/s/nsu89n0rz1fkmvm/Pacman%20config.txt?dl=0
So its a bit of a strange problem.
#4
$ yaourt (insert AUR packagename)
Does that return anything?
#5
Yes. It works. I just tried “yaourt vlc”. It brings back search results & I can install a package.
#6
Logout/login again, but restarting Pamac should actually do it.
#7
That’s Pamac, not Pacman output, but yaourt is already enabled in Pacman.conf else you wouldn’t have gotten the return you did.
#8
I am going to close this. I wish I knew the answer but it is no longer an issue.
I reinstalled Manjaro to work through some graphics issues and this works now.
Thanks for the help.
My problem too.
Anybody have a solution?
Update: Maybe this help:
sudo yaourt psiphon
[sudo] password for saeed:
curl error: Problem with the SSL CA cert (path? access rights?)
#10
#11
Maybe this solves the problem.
Reinstall ca-certificate and then reboot.
closed #12
