Warning
It is generally not a good idea to run unattended updates via systemd, as the applications can get new permissions without the user aware of the changes. See this blogpost for examples.
To update your system runtimes and applications automatically, create the following files:
That’s nice, and is certainly effective. I guess I’ll use that for now.
But it would be nice if pamac managed this somehow, seeing as a similar setting for offline updates is available for repository package upgrades right now (as mentioned in the original post).
If that is considered safe and effective for new users, Manjaro Team might be able to deploy it as a BASH script or standalone package
If the systemd timer and service work as expected, changing pamac GUI plugin for Flatpak updates would not be needed
If additional features are added to pamac GUI new users might incorrectly assume that Manjaro supports Flatpak similar to repository packages. Flatpaks cannot be tested or curated like repository packages and issues should be reported to upstream maintainers
It does work well, a Manjaro package that makes installing this service and timer would make this simpler for users. This could potentially be a default package for new installs as well.
There the user will use arkdep to maintain the system. It is fully image based and uses flatpaks for additional applications. When there is an update, you can download it, but it only gets applied on a fresh boot of the machine. If that new update won’t work, you can select the previous state of the system.
Initial products shipping this style of Manjaro will be:
Sure, I get that Manjaro Summit exists, but I was wanting a solution for the existing stable branch.
Especially seeing as Flatpaks are independent of system packages, so there should be no harm to the system in automatically upgrading Flatpaks.
Also Summit doesn’t seem quite ready yet (its in alpha).
No - no - no - automatic updates always bear the potential to cause harm - no matter the method.
What is defined as harm is an open question.
Keeping a Manjaro system in a sane and working state is the local system administrators duty.
Manjaro provides updated packages - but whether to apply them or not - that is the local system administrators decision.
Yes - Pamac provides an option to do offline update - if you make use of it - fine - it is your system.
If you want automatic updates - you can script it - and if you run into issues - you have only yourself to thank.
Manjaro Summit is a completely different concept.
There is no updates to the system as such - it is a concept similar to macOS where the base system is a single unit - it is downloaded as a single unit and deployed as a single unit.
You cannot make changes to that unit and as such the replacement is atomic - it is all or nothing.
