Add Onlyoffice in Calamares
Hi everyone and specially Manjaro crew.
I have a suggestion, my suggestion is to add “Onlyoffice” to Calamares when the people are installing Manjaro.
Actually Calamares offers to install “Libreoffice” and “Free office” But could be good to add “Onlyoffice” in Calamares to don’t have to install Onlyoffice in the post installation. Because Onlyoffice is in the official repositories and I personally use Onlyoffice.
It’s my suggestion.
Thanks for read, and sorry for my bad English.
Hi, and welcome to the forum.
Thank you for your interest. I understand this has been discussed before. As I recall, it was mentioned that OnlyOffice isn’t a full office suite (due to the online component) and was not given consideration.
If you prefer OnlyOffice, unselect both LibreOffice and Free Office during Manjaro installation, and from that point it seems rather easy to issue a simple command post-install:
sudo pacman -S onlyoffice
Adding to @soundofthunder’s above comment re. this having an online component, also remember that anything we add bloats the .ISO size, particularly things like office suites (although due to said “online component”, it may not be as space-consuming as the other two).
OnlyOffice weighs in at around 1323 MiB (what the?!) at the moment; including dependencies, which vary a little depending upon whatever any given system already has installed.
Considering that LibreOffice is around 572 MB, and FreeOffice is 264 MB, I think @BG405’s guess is safely debunked. :wink:
Interesting is that OnlyOffice installs several multimedia packages, gstreamer and graphine – though I didn’t check specifically, I think some of those packages are sizeable.
Indeed, and there is no advantage to having it offered at installation time, given that, being a (curated) rolling-release distribution, Manjaro only needs to be installed once per target machine, and then simply kept updated.
Furthermore, onlyoffice isn’t really Free & Open Source Software. Parts of it are licensed under the AGPL, and parts of it are proprietary.
And before anyone would like to point out that freeoffice is proprietary as well, the thing with freeoffice is that its makers have a business relationship with the Manjaro GmbH, the commercial appendage of the Manjaro project. So there is at least a somewhat plausible reason as to why Philip Müller, the owner of the Manjaro GmbH, chose to include freeoffice in the ISOs.
Therefore, I’m afraid we’re going to have to pass on this feature request. :man_shrugging:
