trying the second solution…
/var/cache/pamac/vala-panel-appmenu/PKGBUILD
Спойлер
Maintainer : Yamada Hayao hayao@fascode.net
Contributer: rilian-la-te ria.freelander@gmail.com
_disable_mate=false
_disable_xfce=false
_disable_vala=false
_disable_budgie=true
i edited and restarted…
Спойлер
Finished with result: success
Main processes terminated with: code=exited/status=0
Service runtime: 1min 19.814s
CPU time consumed: 1min 48.405s
Running as unit: run-u72.service
Service runtime: 22.086s
CPU time consumed: 25.003s
Checking the keychain… [2/2]
Integrity check… [2/2]
Loading package files… [2/2]
Checking files for conflicts … [2/2]
Checking available disk space… [2/2]
Installing vala-panel-appmenu-common (0.7.6-2)… [1/2]
Installing vala-panel-appmenu-mate (0.7.6-2)… [2/2]
Post-transaction handlers running…
Arming ConditionNeedsUpdate… [1/2]
Compiling GSettings XML schema files… [2/2]
The transaction completed successfully.
[user1@user1-onetwol5351 ~]$
thank you all
