Hello
Dear friends, I installed the nautilus file manager!
I wanted to be able to open a terminal inside this file manager whenever I right-click.
As far as I know I have to create a launcher for it with the command “exo-open --launch TerminalEmulator” but I do not know Thank you for helping me add this feature inside the nautilus file manager.
Gnome edition has this by default. Search pamac for nautilus, I think there is an extension that does this.
nautilus-open-any-terminal
I installed this, my problem was solved
The Nautilus file manager has that feature that allows you to right-click on any folder and select “Open Terminal” The problem is that this feature only works with gnome-terminal
