I have been Using pyinstaller to build apps now but ldd gives me an error saying that it doesn’t have permission to access the libraries that I use also after checking thier website I found this.
I need Someone to tell me how to do these.
Your help is appreciated
GNU/Linux
PyInstaller requires the ldd
terminal application to discover the shared libraries required by each program or shared library. It is typically found in the distribution-package glibc
or libc-bin
It also requires the objdump
terminal application to extract information from object files and the objcopy
terminal application to append data to the bootloader. These are typically found in the distribution-package binutils
