Problem during shutdown or reboot
sometimes when I reboot or shutdown my laptop will struck at
Can you post some information about your system?
inxi -Fza ?
  Kernel: 5.4.80-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.4-x86_64
  root=UUID=65bb43f0-0913-47ec-ad3b-72e35f09034d rw rootflags=subvol=@
  quiet apparmor=1 security=apparmor udev.log_priority=3
  Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A
  serial: <filter> Chassis: type: 9 serial: <filter>
  Mobo: Dell model: 0D53F5 v: A00 serial: <filter> UEFI: Dell v: 2.13.0
  date: 08/13/2020
  ID-1: BAT0 charge: 18.5 Wh condition: 18.5/41.4 Wh (45%)
  volts: 17.0/14.8 model: SMP DELL VN3N047 type: Li-ion serial: <filter>
  status: Full
  Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
  arch: Amber Lake family: 6 model-id: 8E (142) stepping: 9 microcode: DE
  L2 cache: 3072 KiB
  bogomips: 21607
  Speed: 800 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 800 2: 800
  3: 800 4: 800
  Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes,
  SMT vulnerable
  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:5916
  Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 /
  Radeon 520 Mobile]
  vendor: Dell driver: radeon v: kernel alternate: amdgpu bus ID: 01:00.0
  chip ID: 1002:6660
  Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
  bus ID: 1-5:3 chip ID: 0bda:5769 serial: <filter>
  Display: x11 server: X.Org 1.20.10 compositor: kwin_x11
  driver: ati,intel,radeon unloaded: modesetting alternate: fbdev,vesa
  display ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102
  size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
  OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2)
  v: 4.6 Mesa 20.2.3 direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
  chip ID: 8086:9d71
  Sound Server: ALSA v: k5.4.80-2-MANJARO
  Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000
  bus ID: 02:00.0 chip ID: 8086:3165
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
  driver: r8169 v: kernel port: d000 bus ID: 03:00.0 chip ID: 10ec:8136
  Local Storage: total: 931.51 GiB used: 320.38 GiB (34.4%)
  ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172
  size: 931.51 GiB block size: physical: 4096 B logical: 512 B
  speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: SDM3
  scheme: GPT
  ID-1: / raw size: 120.00 GiB size: 120.00 GiB (100.00%)
  used: 26.00 GiB (21.7%) fs: btrfs dev: /dev/sda2
  ID-2: /home raw size: 811.01 GiB size: 811.01 GiB (100.00%)
  used: 294.38 GiB (36.3%) fs: btrfs dev: /dev/sda3
  System Temperatures: cpu: 53.0 C mobo: 51.0 C gpu: radeon temp: 48.0 C
  Fan Speeds (RPM): cpu: 2570
  Processes: 233 Uptime: 1h 08m Memory: 7.65 GiB used: 1.58 GiB (20.7%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1321 pacman: 1319
  lib: 365 flatpak: 0 snap: 2 Shell: Bash v: 5.0.18 running in: konsole
  inxi: 3.1.08
Can you try a more recent kernel ?
