I have an old laptop (Acer Aspire 5740G). It has temperature sensors which are recognized and registered, but for some reason they show no readings when measured. Other sensors (Temp 1
and Temp 2
) work fine, it’s only the core temperatures and GPU temp that do this. I’m presuming it’s not a missing driver not implemented by the kernel, as in that case the sensors would simply not show up.
Here is the output of the sensors-detect
command when I run it as root to update the list:
# sensors-detect version 3.6.0+git
# System: Acer Aspire 5740 [V1.28] (laptop)
# Kernel: 6.4.6-1-MANJARO x86_64
# Processor: Intel(R) Core(TM) i3 CPU M 330 @ 2.13GHz (6/37/2)
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no): yes
Silicon Integrated Systems SIS5595... No
VIA VT82C686 Integrated Sensors... No
VIA VT8231 Integrated Sensors... No
AMD K8 thermal sensors... No
AMD Family 10h thermal sensors... No
AMD Family 11h thermal sensors... No
AMD Family 12h and 14h thermal sensors... No
AMD Family 15h thermal sensors... No
AMD Family 16h thermal sensors... No
AMD Family 17h thermal sensors... No
AMD Family 15h power sensors... No
AMD Family 16h power sensors... No
Hygon Family 18h thermal sensors... No
AMD Family 19h thermal sensors... No
Intel digital thermal sensor... Success!
(driver `coretemp')
Intel AMB FB-DIMM thermal sensor... No
Intel 5500/5520/X58 thermal sensor... No
VIA C7 thermal sensor... No
VIA Nano thermal sensor... No
Some Super I/O chips contain embedded sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no): yes
Probing for Super-I/O at 0x2e/0x2f
Trying family `National Semiconductor/ITE'... No
Trying family `SMSC'... No
Trying family `VIA/Winbond/Nuvoton/Fintek'... No
Trying family `ITE'... No
Probing for Super-I/O at 0x4e/0x4f
Trying family `National Semiconductor/ITE'... Yes
Found unknown chip with ID 0xfc11
Some hardware monitoring chips are accessible through the ISA I/O ports.
We have to write to arbitrary I/O ports to probe them. This is usually
safe though. Yes, you do have ISA I/O ports even if you do not have any
ISA slots! Do you want to scan the ISA I/O ports? (YES/no): yes
Probing for `National Semiconductor LM78' at 0x290... No
Probing for `National Semiconductor LM79' at 0x290... No
Probing for `Winbond W83781D' at 0x290... No
Probing for `Winbond W83782D' at 0x290... No
Lastly, we can probe the I2C/SMBus adapters for connected hardware
monitoring devices. This is the most risky part, and while it works
reasonably well on most systems, it has been reported to cause trouble
on some systems.
Do you want to probe the I2C/SMBus adapters now? (YES/no): yes
Using driver `i2c-i801' for device 0000:00:1f.3: Intel 3400/5 Series (PCH)
Next adapter: SMBus I801 adapter at 1840 (i2c-0)
Do you want to scan it? (YES/no/selectively): yes
Client found at address 0x50
Handled by driver `at24' (already loaded), chip type `spd'
(note: this is probably NOT a sensor chip!)
Client found at address 0x52
Next adapter: Radeon i2c bit bus 0x90 (i2c-1)
Do you want to scan it? (yes/NO/selectively): yes
Next adapter: Radeon i2c bit bus 0x91 (i2c-2)
Next adapter: Radeon i2c bit bus 0x92 (i2c-3)
Next adapter: Radeon i2c bit bus 0x93 (i2c-4)
Client found at address 0x18
Probing for `Analog Devices ADM1021'... No
Probing for `Analog Devices ADM1021A/ADM1023'... No
Probing for `Maxim MAX1617'... No
Probing for `Maxim MAX1617A'... No
Probing for `Maxim MAX1668'... No
Probing for `Maxim MAX1805'... No
Probing for `Maxim MAX1989'... No
Probing for `Maxim MAX6655/MAX6656'... No
Probing for `TI THMC10'... No
Probing for `National Semiconductor LM84'... No
Probing for `Genesys Logic GL523SM'... No
Probing for `Onsemi MC1066'... No
Probing for `Maxim MAX1618'... No
Probing for `Maxim MAX1619'... No
Probing for `National Semiconductor LM82/LM83'... No
Probing for `Maxim MAX6654'... No
Probing for `Maxim MAX6690'... No
Probing for `Maxim MAX6680/MAX6681'... No
Probing for `Maxim MAX6695/MAX6696'... No
Probing for `Texas Instruments TMP400'... No
Probing for `Texas Instruments AMC6821'... No
Probing for `National Semiconductor LM95233'... No
Probing for `National Semiconductor LM95234'... No
Probing for `National Semiconductor LM95235'... No
Probing for `National Semiconductor LM95245'... No
Probing for `National Semiconductor LM64'... No
Probing for `SMSC EMC1047'... No
Probing for `SMSC EMC1402'... No
Probing for `SMSC EMC1403'... No
Probing for `SMSC EMC1404'... No
Probing for `ST STTS424'... No
Probing for `ST STTS424E'... No
Probing for `ST STTS2002'... No
Probing for `ST STTS3000'... No
Probing for `NXP SE97/SE97B'... No
Probing for `NXP SE98'... No
Probing for `Analog Devices ADT7408'... No
Probing for `IDT TS3000/TSE2002'... No
Probing for `IDT TSE2004'... No
Probing for `IDT TS3001'... No
Probing for `Maxim MAX6604'... No
Probing for `Microchip MCP9804'... No
Probing for `Microchip MCP9808'... No
Probing for `Microchip MCP98242'... No
Probing for `Microchip MCP98243'... No
Probing for `Microchip MCP98244'... No
Probing for `Microchip MCP9843'... No
Probing for `ON CAT6095/CAT34TS02'... No
Probing for `ON CAT34TS02C'... No
Probing for `ON CAT34TS04'... No
Probing for `Atmel AT30TS00'... No
Probing for `Giantec GT30TS00'... No
Client found at address 0x1a
Client found at address 0x1e
Probing for `TI / National Semiconductor ADC128D818'... No
Probing for `Texas Instruments TMP421'... No
Probing for `Texas Instruments TMP441'... No
Client found at address 0x28
Probing for `National Semiconductor LM78'... No
Probing for `National Semiconductor LM79'... No
Probing for `National Semiconductor LM80'... No
Probing for `National Semiconductor LM96080'... No
Probing for `Winbond W83781D'... No
Probing for `Winbond W83782D'... No
Probing for `Nuvoton NCT7802Y'... No
Probing for `Winbond W83627HF'... No
Probing for `Winbond W83627EHF'... No
Probing for `Winbond W83627DHG/W83667HG/W83677HG'... No
Probing for `Asus AS99127F (rev.1)'... No
Probing for `Asus AS99127F (rev.2)'... No
Probing for `Asus ASB100 Bach'... No
Probing for `Analog Devices ADM1029'... No
Probing for `ITE IT8712F'... No
Client found at address 0x49
Probing for `National Semiconductor LM75'... No
Probing for `National Semiconductor LM75A'... No
Probing for `Dallas Semiconductor DS75'... No
Probing for `National Semiconductor LM77'... No
Probing for `Analog Devices ADT7410/ADT7420'... No
Probing for `Maxim MAX6642'... No
Probing for `Texas Instruments TMP435'... No
Probing for `National Semiconductor LM73'... No
Probing for `National Semiconductor LM92'... No
Probing for `National Semiconductor LM76'... No
Probing for `Maxim MAX6633/MAX6634/MAX6635'... No
Probing for `NXP/Philips SA56004'... No
Probing for `SMSC EMC1023'... No
Probing for `SMSC EMC1043'... No
Probing for `SMSC EMC1053'... No
Probing for `SMSC EMC1063'... No
Next adapter: Radeon i2c bit bus 0x94 (i2c-5)
Next adapter: Radeon i2c bit bus 0x95 (i2c-6)
Next adapter: Radeon i2c bit bus 0x96 (i2c-7)
Next adapter: Radeon i2c bit bus 0x97 (i2c-8)
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `coretemp':
* Chip `Intel digital thermal sensor' (confidence: 9)
Do you want to overwrite /etc/conf.d/lm_sensors? (YES/no): yes
Despite the sensors being found and listed, I see only the names but no value in any system monitor, even when I re-add them to ensure I’m using up-to-date entries.
