I had Topaz Denose 3.03 running under PlayOnLinus and Wine ver. 6-4. Th update today, 4/9/21, killed it. Play on Linux has a feature that let’s you uninstall newer versions of wine in favor of older versions, and it said I had successfully swapped 6-4 back for the newer 6-5 version of Wine, but after Topaz Denoise crashed again on reinstall , the logs in PlayOnLinux indicated that Wine 6-5 was still active and being used.
How can I fix this, if PlayonLinux is unable to roll back wine versions successfully?
