/etc/passwd.pacnew
/etc/shells.pacnew
/etc/locale.gen.pacnew
/etc/default/grub.pacnew
/etc/pam.d/kde.pacnew
/etc/pamac.conf.pacnew
/etc/mkinitcpio.conf.pacnew
/etc/pacman.conf.pacnew
/etc/pacman-mirrors.conf.pacnew
/etc/sane.d/canon_lide70.conf.pacnew
/etc/sane.d/escl.conf.pacnew
/etc/pam.d/sddm.pacnew
/etc/systemd/homed.conf.pacnew
/etc/systemd/pstore.conf.pacnew
My system
Kernel: 5.15.167-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Desktop: KDE Plasma v: 6.1.5 Distro: Manjaro base: Arch Linux
Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A
serial: <superuser required>
Mobo: Dell model: 0FGN4M v: A00 serial: <superuser required> UEFI: Dell
v: 2.10.0 date: 05/10/2019
ID-1: BAT0 charge: 9.8 Wh (42.8%) condition: 22.9/41.4 Wh (55.3%)
volts: 15.6 min: 14.8 model: SMP DELL GR43778 status: charging
Info: dual core model: Intel Core i3-6006U bits: 64 type: MT MCP
arch: Skylake rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 1917 min/max: 400/2000 cores: 1: 1917 2: 1917 3: 1917
4: 1917 bogomips: 16006
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel arch: Gen-9 bus-ID: 00:02.0
Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
type: USB bus-ID: 1-5:2
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2 driver: X:
loaded: modesetting dri: iris gpu: i915 resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: iris,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.0.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
API: Vulkan v: 1.3.295 drivers: intel surfaces: xcb,xlib devices: 1
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3
API: ALSA v: k5.15.167-1-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.2.5 status: off
Server-3: PulseAudio v: 17.0 status: active
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel bus-ID: 01:00.0
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB bus-ID: 1-8:4
Local Storage: total: 931.51 GiB used: 840.55 GiB (90.2%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
ID-1: / size: 97.87 GiB used: 84.91 GiB (86.8%) fs: ext4 dev: /dev/sda1
ID-2: /boot/efi size: 511 MiB used: 312 KiB (0.1%) fs: vfat dev: /dev/sda2
ID-1: swap-1 type: partition size: 8.59 GiB used: 0 KiB (0.0%)
dev: /dev/sda3
System Temperatures: cpu: 31.0 C pch: 30.0 C mobo: 30.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 8 GiB available: 7.63 GiB used: 2.11 GiB (27.6%)
Processes: 203 Uptime: 54m Init: systemd
Packages: 1673 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9
inxi: 3.3.36
/usr/share/icons/default/index.theme
[Icon Theme]
Inherits=Adwaita
/usr/share/icons/default/index.theme.pacsave
[icon theme]
Inherits=xcursor-breeze
I do use zshell but it’s not in shells.pacnew but still if it’s has some other meaning
/etc/shells
# Pathnames of valid login shells.
# See shells(5) for details.
/bin/sh
/bin/bash
/bin/zsh
/usr/bin/zsh
/usr/bin/git-shell
/bin/rbash
/usr/bin/rbash
/usr/bin/bash
/usr/bin/sh
/usr/bin/systemd-home-fallback-shell
/etc/shells.pacnew
/bin/sh
/bin/bash
/bin/rbash
/usr/bin/sh
/usr/bin/bash
/usr/bin/rbash
I think /etc/locale.gen.pacnew
doesn’t need to merge if I’m not wrong
Ok this one will definitely send me downhill it’s /etc/default/grub.pacnew
/etc/default/grub
# GRUB boot loader configuration
GRUB_DEFAULT=saved
GRUB_TIMEOUT=10
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=d4a2bbfe-f657-4b6d-ad7b-291b32ce3bb1 udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
GRUB_DISABLE_OS_PROBER=false
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3"
# Set to 'countdown' or 'menu' to change timeout behavior,
# press ESC key to display menu.
GRUB_GFXMODE=auto
#GRUB_THEME="/path/to/gfxtheme"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
#GRUB_DISABLE_OS_PROBER=false
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
I see slightly difference in kde.pacnew
only the word local
/etc/pam.d/kde
#%PAM-1.0
auth include system-login
account include system-login
password include system-login
session include system-login
#%PAM-1.0
auth include system-local-login
account include system-local-login
password include system-local-login
session include system-local-login
/etc/pamac.conf
### Pamac configuration file
## When removing a package, also remove those dependencies
## that are not required by other packages (recurse option):
#RemoveUnrequiredDeps
## How often to check for updates, value in hours (0 to disable):
RefreshPeriod = 6
## When there are no updates available, hide the tray icon:
#NoUpdateHideIcon
## When applying updates, enable packages downgrade:
#EnableDowngrade
## When installing packages, do not check for updates:
#SimpleInstall
## Allow Pamac to search and install packages from AUR:
EnableAUR
## Keep built packages from AUR in cache after installation:
#KeepBuiltPkgs
## When AUR support is enabled check for updates from AUR:
#CheckAURUpdates
## When check updates from AUR support is enabled check for vcs updates:
#CheckAURVCSUpdates
## AUR build directory:
BuildDirectory = /var/tmp
## Number of versions of each package to keep in the cache:
KeepNumPackages = 3
## Remove only the versions of uninstalled packages when clean cache:
#OnlyRmUninstalled
## Download updates in background:
#DownloadUpdates
## Maximum Parallel Downloads:
MaxParallelDownloads = 4
#CheckFlatpakUpdates
EnableSnap
EnableFlatpak
#OfflineUpgrade
RefreshPeriod = 6
## When no update is available, hide the tray icon:
#NoUpdateHideIcon
#EnableDowngrade
#SimpleInstall
#EnableAUR
#KeepBuiltPkgs
#CheckAURUpdates
#CheckAURVCSUpdates
## Number of versions of each package to keep when cleaning the packages cache:
KeepNumPackages = 3
## Remove only the versions of uninstalled packages when cleaning the packages cache:
#OnlyRmUninstalled
#DownloadUpdates
## Offline upgrade:
#OfflineUpgrade
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
MODULES=()
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES=()
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No raid, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect block filesystems)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev block filesystems)
## This setup assembles a pata mdadm array with an encrypted root FS.
## Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
# HOOKS=(base udev block mdadm encrypt filesystems)
## This setup loads an lvm2 volume group on a usb device.
# HOOKS=(base udev block lvm2 filesystems)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr, fsck and shutdown hooks.
HOOKS=(base udev autodetect modconf kms block keyboard keymap resume filesystems)
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
# Use 'cat' to create an uncompressed image.
#COMPRESSION="zstd"
COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
# MODULES_DECOMPRESS
# Decompress loadable kernel modules and their firmware during initramfs
# creation. Switch (yes/no).
# Enable to allow further decreasing image size when using high compression
# (e.g. xz -9e or zstd --long --ultra -22) at the expense of increased RAM usage
# at early boot.
# Note that any compressed files will be placed in the uncompressed early CPIO
# to avoid double compression.
#MODULES_DECOMPRESS="no"
# vim:set ft=sh
# MODULES
# MODULES=(usbhid xhci_hcd)
MODULES=()
# BINARIES
BINARIES=()
# FILES
FILES=()
# HOOKS
# Examples:
## No RAID, lvm2, or encrypted root is needed.
# HOOKS=(base)
# HOOKS=(base udev autodetect modconf block filesystems fsck)
# HOOKS=(base udev modconf block filesystems fsck)
## This setup assembles a mdadm array with an encrypted root file system.
## Note: See 'mkinitcpio -H mdadm_udev' for more information on RAID devices.
# HOOKS=(base udev modconf keyboard keymap consolefont block mdadm_udev encrypt filesystems fsck)
## This setup loads an lvm2 volume group.
# HOOKS=(base udev modconf block lvm2 filesystems fsck)
## This will create a systemd based initramfs which loads an encrypted root filesystem.
# HOOKS=(base systemd autodetect modconf kms keyboard sd-vconsole sd-encrypt block filesystems fsck)
# usr and fsck hooks.
HOOKS=(base udev autodetect microcode modconf kms keyboard keymap consolefont block filesystems fsck)
# COMPRESSION
# Use this to compress the initramfs image. By default, zstd compression
# is used for Linux ≥ 5.9 and gzip compression is used for Linux < 5.9.
#COMPRESSION="zstd"
#COMPRESSION="gzip"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
# at early boot.
Already made changes on /etc/pacman.conf
but still …
/etc/pacman.conf
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir = /
#DBPath = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile = /var/log/pacman.log
#GPGDir = /etc/pacman.d/gnupg/
#HookDir = /etc/pacman.d/hooks/
HoldPkg = pacman glibc manjaro-system
#XferCommand = /usr/bin/curl -L -C - -f -o %o %u
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta = 0.7
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ParallelDownloads = 1
DownloadUser = alpm
DisableSandbox
#ILoveCandy
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Manjaro Linux
# packagers with `pacman-key --populate archlinux manjaro`.
# REPOSITORIES
# - can be defined here or included from another file
# - pacman will search repositories in the order defined here
# - local/custom mirrors can be added here or in separate files
# - repositories listed first will take precedence when packages
# have identical names, regardless of version number
# - URLs will have $repo replaced by the name of the current repo
# - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
# [repo-name]
# Server = ServerName
# Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
[core]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[extra]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[multilib]
# An example of a custom package repository. See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
#RootDir = /
#CacheDir = /var/cache/pacman/pkg/
Architecture = auto
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
DownloadUser = alpm
#DisableSandbox
#ILoveCandy
# keyring can then be populated with the keys of all official Arch and Manjaro Linux
# REPOSITORIES
# [repo-name]
[core]
[extra]
[multilib]
#[custom]
/etc/pam.d/sddm
#%PAM-1.0
auth optional pam_kwallet5.so
session optional pam_kwallet5.so auto_start
#%PAM-1.0
-auth optional pam_gnome_keyring.so
-auth optional pam_kwallet5.so
-password optional pam_gnome_keyring.so use_authtok
session optional pam_keyinit.so force revoke
-session optional pam_gnome_keyring.so auto_start
-session optional pam_kwallet5.so auto_start
/etc/passwd.pacnew
is the most confusing one because it only has one line but /etc/passwd
has lot of lines
Also If I didn’t post any .pacnew files it’s either are same with .conf or all the lines has comment
