For network reason, Pamac build ros-noetic-desktop-full(AUR) fail. I can do this again when network get better until it installed successfully.
However, when install ros-noetic-desktop-full,it will install 230 depends and remove some pkgs. If it fails at last. It still install 230depends, If I do want to install ros-noetic-desktop-full at last. I need to uninstall 230 depends one by one via pamac history. Is there a better way to remove its depends?
230 dependencies seems like a lot.
Are you sure those are not ordinary system updates? (Pamac always updates the system before a new package gets installed)
yes good reply. Maybe some of them are sysyem update. I will reinstall to check.
for network and some other problem. I still try to install
all 131depends. Good news is that only 7 are direct denpend
