Abiword appears to work correctly until I try to copy a text selection to clipboard using Ctrl+c or right-click+copy at which time it crashes. Pasting using Ctrl+v or right-click+paste works fine.
Offical Repository abiword version 3.0.4
inxi -F:
System: Host: macmini51 Kernel: 5.4.112-1-MANJARO x86_64 bits: 64 Desktop: Xfce 4.16.0 Distro: Manjaro Linux
Machine: Type: Laptop System: Apple product: Macmini5,1 v: 1.0 serial: C07H208PDJD0
Mobo: Apple model: Mac-8ED6AF5B48C039E1 v: Macmini5,1 serial: C0720150AKXDKP2AG UEFI: Apple v: 135.0.0.0.0
date: 06/13/2019
CPU: Info: Dual Core model: Intel Core i5-2415M bits: 64 type: MT MCP cache: L2: 3 MiB
Speed: 798 MHz min/max: 800/2900 MHz Core speeds (MHz): 1: 798 2: 798 3: 798 4: 799
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics driver: i915 v: kernel
Display: server: X.Org 1.20.11 driver: loaded: intel unloaded: modesetting resolution: 1360x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2) v: 3.3 Mesa 21.0.2
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.4.112-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 14.2 running: yes
Network: Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
IF: enp2s0f0 state: down mac: 3c:07:54:67:10:09
Device-2: Broadcom BCM4331 802.11a/b/g/n driver: bcma-pci-bridge
IF-ID-1: wlp3s0b1 state: up mac: 7c:c3:a1:73:03:cd
Bluetooth: Device-1: Apple Bluetooth Host Controller type: USB driver: btusb
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: see --recommends
Drives: Local Storage: total: 465.76 GiB used: 8.58 GiB (1.8%)
ID-1: /dev/sda vendor: Toshiba model: MK5065GSXF size: 465.76 GiB
Partition: ID-1: / size: 78.62 GiB used: 8.49 GiB (10.8%) fs: ext4 dev: /dev/sda4
ID-2: /boot/efi size: 196.9 MiB used: 23.3 MiB (11.9%) fs: vfat dev: /dev/sda1
Swap: ID-1: swap-1 type: partition size: 2.57 GiB used: 0 KiB (0.0%) dev: /dev/sda6
Sensors: System Temperatures: cpu: 41.0 C mobo: 50.0 C
Info: Processes: 177 Uptime: 19m Memory: 3.76 GiB used: 895.1 MiB (23.2%) Shell: Bash inxi: 3.3.04
journalctl:
Apr 22 14:55:39 macmini51 audit[1641]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=1641 comm="abiword" exe="/us>
Apr 22 14:55:39 macmini51 kernel: audit: type=1701 audit(1619117739.299:102): auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=>
Apr 22 14:55:39 macmini51 systemd[1]: Created slice system-systemd\x2dcoredump.slice.
Apr 22 14:55:39 macmini51 systemd[1]: Started Process Core Dump (PID 1693/UID 0).
Apr 22 14:55:39 macmini51 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-cored>
Apr 22 14:55:39 macmini51 kernel: audit: type=1130 audit(1619117739.402:103): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconf>
Apr 22 14:55:40 macmini51 systemd-coredump[1694]: Process 1641 (abiword) of user 1000 dumped core.
Stack trace of thread 1641:
#0 0x00007f3f407e3ef5 raise (libc.so.6 + 0x3cef5)
#1 0x00007f3f407cd862 abort (libc.so.6 + 0x26862)
#2 0x00007f3f40d8a017 _ZN10AP_UnixApp12catchSignalsEi (libabiword-3.0.so + 0x41601>
#3 0x00007f3f40d8a0ab _Z13signalWrapperi (libabiword-3.0.so + 0x4160ab)
#4 0x00007f3f407e3f80 __restore_rt (libc.so.6 + 0x3cf80)
#5 0x00007f3f408456b7 __strchr_sse2 (libc.so.6 + 0x9e6b7)
#6 0x00007f3f40e86270 _ZN28IE_Exp_HTML_NavigationHelperC1EP11PD_DocumentRK13UT_UTF>
#7 0x00007f3f40e6ed81 _ZN11IE_Exp_HTML14_writeDocumentEv (libabiword-3.0.so + 0x4f>
#8 0x00007f3f40e6c7a8 _ZN6IE_Exp9writeFileEPKc (libabiword-3.0.so + 0x4f87a8)
#9 0x00007f3f40e6e4af _ZN11IE_Exp_HTML12copyToBufferEP16PD_DocumentRangeP10UT_Byte>
#10 0x00007f3f40d8a251 _ZN10AP_UnixApp15copyToClipboardEP16PD_DocumentRangeb (libab>
#11 0x00007f3f40cea39b _ZN7FV_View7cmdCopyEb (libabiword-3.0.so + 0x37639b)
#12 0x00007f3f40e18525 _ZN14ap_EditMethods4copyEP7AV_ViewP21EV_EditMethodCallData (>
#13 0x00007f3f40f6c694 _ZN7EV_Menu16invokeMenuMethodEP7AV_ViewP13EV_EditMethodRK9UT>
#14 0x00007f3f40f63462 _ZN11EV_UnixMenu9menuEventEi (libabiword-3.0.so + 0x5ef462)
#15 0x00007f3f3ee22ddf g_closure_invoke (libgobject-2.0.so.0 + 0x12ddf)
#16 0x00007f3f3ee4bfbd n/a (libgobject-2.0.so.0 + 0x3bfbd)
#17 0x00007f3f3ee3fcad g_signal_emit_valist (libgobject-2.0.so.0 + 0x2fcad)
#18 0x00007f3f3ee40210 g_signal_emit (libgobject-2.0.so.0 + 0x30210)
#19 0x00007f3f3fdc6eb1 n/a (libgtk-3.so.0 + 0x32ceb1)
#20 0x00007f3f3ee22ddf g_closure_invoke (libgobject-2.0.so.0 + 0x12ddf)
#21 0x00007f3f3ee4bfbd n/a (libgobject-2.0.so.0 + 0x3bfbd)
#22 0x00007f3f3ee3f2db g_signal_emit_valist (libgobject-2.0.so.0 + 0x2f2db)
#23 0x00007f3f3ee40210 g_signal_emit (libgobject-2.0.so.0 + 0x30210)
#24 0x00007f3f3fb2e8fc gtk_accel_group_activate (libgtk-3.so.0 + 0x948fc)
#25 0x00007f3f3fb2fcfe gtk_accel_groups_activate (libgtk-3.so.0 + 0x95cfe)
#26 0x00007f3f3fdf0f1f gtk_window_activate_key (libgtk-3.so.0 + 0x356f1f)
#27 0x00007f3f3fdeb1b3 n/a (libgtk-3.so.0 + 0x3511b3)
#28 0x00007f3f3fb1e235 n/a (libgtk-3.so.0 + 0x84235)
#29 0x00007f3f3ee40096 g_signal_emit_valist (libgobject-2.0.so.0 + 0x30096)
#30 0x00007f3f3ee40210 g_signal_emit (libgobject-2.0.so.0 + 0x30210)
#31 0x00007f3f3fddd5a5 n/a (libgtk-3.so.0 + 0x3435a5)
#32 0x00007f3f3fc797d2 n/a (libgtk-3.so.0 + 0x1df7d2)
#33 0x00007f3f3fc7aa5d gtk_main_do_event (libgtk-3.so.0 + 0x1e0a5d)
#34 0x00007f3f3f9d7a03 n/a (libgdk-3.so.0 + 0x3da03)
#35 0x00007f3f3fa27a64 n/a (libgdk-3.so.0 + 0x8da64)
#36 0x00007f3f3ed2f02c g_main_context_dispatch (libglib-2.0.so.0 + 0x5402c)
#37 0x00007f3f3ed82b59 n/a (libglib-2.0.so.0 + 0xa7b59)
#38 0x00007f3f3ed2e593 g_main_loop_run (libglib-2.0.so.0 + 0x53593)
#39 0x00007f3f3fc7058f gtk_main (libgtk-3.so.0 + 0x1d658f)
#40 0x00007f3f40c4a008 _ZN10AP_UnixApp4mainEPKciPPc (libabiword-3.0.so + 0x2d6008)
#41 0x00007f3f407ceb25 __libc_start_main (libc.so.6 + 0x27b25)
#42 0x000055d84901f06e n/a (abiword + 0x106e)
Stack trace of thread 1642:
#0 0x00007f3f4089b37f __poll (libc.so.6 + 0xf437f)
#1 0x00007f3f3ed82ae8 n/a (libglib-2.0.so.0 + 0xa7ae8)
#2 0x00007f3f3ed2c781 g_main_context_iteration (libglib-2.0.so.0 + 0x51781)
#3 0x00007f3f3ed2c7d2 n/a (libglib-2.0.so.0 + 0x517d2)
#4 0x00007f3f3ed5d0c1 n/a (libglib-2.0.so.0 + 0x820c1)
#5 0x00007f3f3e33f299 start_thread (libpthread.so.0 + 0x9299)
#6 0x00007f3f408a6053 __clone (libc.so.6 + 0xff053)
Stack trace of thread 1645:
#2 0x00007f3f3ed2e593 g_main_loop_run (libglib-2.0.so.0 + 0x53593)
#3 0x00007f3f3efb2558 n/a (libgio-2.0.so.0 + 0x102558)
Apr 22 14:55:40 macmini51 kernel: audit: type=1131 audit(1619117740.286:104): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconf>
Apr 22 14:55:40 macmini51 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredu>
Apr 22 14:55:40 macmini51 systemd[1]: systemd-coredump@0-1693-0.service: Succeeded.
Any help would be appreciated.
