do you use it?
is it worth using?
is it mostly troublesome?
is it safe now?(i saw they had some issues a few years ago).
what’s the difference in Pamac between:
“Firetools (firetools)-firejail tools and stats” and “Firejail configuration wizard(firetools)-firejail configuration wizard”;
i’m looking for the “normal” Firetools.
i looked in the Arch wiki and the Firejail website and it seems it can be used with simple configurations,but also go quit far.
