~]$ fastfetch
██████████████████ ████████ sum@ordi
██████████████████ ████████ OS: Manjaro Linux x86_64
██████████████████ ████████ Host: K K53SD 1.0
████████ ████████ Kernel: 5.12.1-2-MANJARO
████████ ████████ ████████ Uptime: 1 hour, 4 mins
████████ ████████ ████████ Packages: 2011 (pacman), 20 (flatpak)
████████ ████████ ████████ Shell: bash 5.1.4
████████ ████████ ████████ Resolution 1: 1366x768 @ 60Hz
████████ ████████ ████████ Resolution 2: 1680x1050 @ 60Hz
████████ ████████ ████████ DE: XFCE
████████ ████████ ████████ WM: XFWM (X11)
████████ ████████ ████████ Terminal: xfce4-terminal
████████ ████████ ████████ CPU: Intel Core i3-2350M (4) @ 2.3GHz
GPU 1: Intel 2nd Generation Core Processor Family Integrated Graphics Controller
GPU 2: Nvidia GF119M [GeForce 610M]
Memory: 5587MiB / 11751MiB (47%)
Disk (/): 38GB / 95GB (40%)
Disk (/home): 483GB / 819GB (58%)
Battery: ASUSTek K53--52 (Li-ion) [97%; Unknown]
Locale: fr_FR.UTF-8
Pipewire + Pulseffects + Shortwave.
I also use systemd-swap
I don’t use hibernation (never understood the purpose), got rid of light-locker, no screensaver thus.
All ok for a couple of hours, then you have kind of buffer filling : if I close Shortwave I can have up to 1 minute of music still playing and if I then look for a web video on Firefox for instance, sound comes up with a 1 minute lag !
Never had this issue before (with same setup apart kernel version, obviously).
[edit] I may not have been clear enough !
Can this behaviour be corrected or managed ?
Manjaro is the only distro I have where this happens (Shortwave + pulse effect on my other distros is real time with no increasing buffer… as was the case on Manjaro before Pipewire)
