Optimus-manager doesn’t/can’t turn off the dGPU. I tried it. It’s a known issue with the 9560 that it’s very stubborn about turning off the dGPU. Please don’t recommend it to any 9560 users.
I think 4.9 is the kernel that worked. It is both ancient and LTS.
Is one thing that one particular GPU has that behavior, and is another to say “Optimus-manager doesn’t/can’t turn off the dGPU” - that implies is not working for any GPU … so, yeah.
ancient has nothing derogatory attached to it, if that is what you imply.
4.19 LTS was last patched on 2020-09-03 at the time of this writing and the reason why Manjaro supports multiple kernels. Bumblebee is in the same situation anyway: it receives patches but no new development.
If the 4.19 kernel solves your Bumblebee issue then that’s the solution…
P.S. Most people think that the latest new kernel is what you need all of the time but this is not true: You only need a new kernel if your new hardware is not supported by an older LTS kernel.
I needed 5.7/5.8 for a key feature. Sadly, these kernels break bumblebee and triple-click as middle-click functionality in Manjaro, which are pretty important on this particular laptop and my use thereof.
