Good Afternoon.
I’ve recently purchased TP-Link AXE5400 Tri-Band Wi-Fi 6E Router to use 6GHz in a congested 5GHz area.
The short summary is: Wi-Fi 7 card cannot maintain a stable connection on the 6 GHz band with WPA3-Personal nor enhanced open. The connection fails with an “association timeout”. However, the 5 GHz band on the same router works perfectly with WPA3.
Mobo: ASUSTeK model: ROG STRIX B850-I GAMING WIFI
09:00.0 Network controller [0280]: MEDIATEK Corp. Device [14c3:7925]
Subsystem: AzureWave Device [1a3b:6000]
Kernel driver in use: mt7925e
Kernel modules: mt7925e
Manjaro Linux Stable
6.12.48-1-MANJARO (6.16 was also attempted but resulted in the same outcome).
Signal strength is good (>70) on 6GHz.
I have disabled Band Steering/Smart Connect and set the 6GHz channel width to 80 MHz.
Regulatory domain is correctly set to
GBin /etc/default/crda. -
Set 6GHz security to “enhanced open” to no avail.
Other 6GHz capable devices are able to connect to the router with WPA3 or EO.
I once achieved a brief 6GHz connection by changing the password to one without special characters (!), which points to a parsing bug. However, the instability returned after a system update (6.12.44-1 > 6.12.48-1 performed yesterday).
NetworkManager Log:
Sep 28 14:34:26 ultima NetworkManager[964]: <info> [1759066466.6109] audit: op="statistics" interface="wlp9s0" ifindex=3 args="2000" pid=1452 uid=1000 resu
lt="success"
Sep 28 14:34:26 ultima NetworkManager[964]: <info> [1759066466.6144] audit: op="statistics" interface="wlp9s0" ifindex=3 args="500" pid=1549 uid=1000 resul
t="success"
Sep 28 14:34:28 ultima NetworkManager[964]: <info> [1759066468.0929] audit: op="statistics" interface="wlp9s0" ifindex=3 args="2000" pid=1452 uid=1000 resu
lt="success"
Sep 28 14:34:28 ultima NetworkManager[964]: <info> [1759066468.0976] audit: op="statistics" interface="wlp9s0" ifindex=3 args="500" pid=1549 uid=1000 resul
t="success"
Sep 28 14:35:27 ultima NetworkManager[964]: <info> [1759066527.5454] audit: op="statistics" interface="wlp9s0" ifindex=3 args="2000" pid=1452 uid=1000 resu
lt="success"
Sep 28 14:35:27 ultima NetworkManager[964]: <info> [1759066527.5488] audit: op="statistics" interface="wlp9s0" ifindex=3 args="500" pid=1549 uid=1000 resul
t="success"
Sep 28 14:37:26 ultima NetworkManager[964]: <info> [1759066646.3990] audit: op="statistics" interface="wlp9s0" ifindex=3 args="2000" pid=1452 uid=1000 resu
lt="success"
Sep 28 14:37:26 ultima NetworkManager[964]: <info> [1759066646.4026] audit: op="statistics" interface="wlp9s0" ifindex=3 args="500" pid=1549 uid=1000 resul
t="success"
Sep 28 14:37:35 ultima NetworkManager[964]: <info> [1759066655.3069] audit: op="statistics" interface="wlp9s0" ifindex=3 args="2000" pid=1452 uid=1000 resu
lt="success"
Sep 28 14:37:35 ultima NetworkManager[964]: <info> [1759066655.3106] audit: op="statistics" interface="wlp9s0" ifindex=3 args="500" pid=1549 uid=1000 resul
t="success"
Sep 28 14:37:36 ultima NetworkManager[964]: <info> [1759066656.6856] device (wlp9s0): disconnecting for new activation request.
Sep 28 14:37:36 ultima NetworkManager[964]: <info> [1759066656.6856] device (wlp9s0): state change: activated -> deactivating (reason 'new-activation', man
aged-type: 'full')
Sep 28 14:37:36 ultima NetworkManager[964]: <info> [1759066656.6857] manager: NetworkManager state is now DISCONNECTING
Sep 28 14:37:36 ultima NetworkManager[964]: <info> [1759066656.6860] audit: op="connection-activate" uuid="5d6b1a3d-7f9a-4a24-919e-4481a4de16de" name="TP-L
ink_8180_6G" pid=1452 uid=1000 result="success"
Sep 28 14:37:36 ultima NetworkManager[964]: <info> [1759066656.6985] audit: op="statistics" interface="wlp9s0" ifindex=3 args="0" pid=1452 uid=1000 result=
"success"
Sep 28 14:37:36 ultima NetworkManager[964]: <info> [1759066656.7027] audit: op="statistics" interface="wlp9s0" ifindex=3 args="500" pid=1549 uid=1000 resul
t="success"
Sep 28 14:37:37 ultima NetworkManager[964]: <info> [1759066657.2046] device (wlp9s0): state change: deactivating -> disconnected (reason 'new-activation',
managed-type: 'full')
Sep 28 14:37:37 ultima NetworkManager[964]: <info> [1759066657.2195] dhcp4 (wlp9s0): canceled DHCP transaction
Sep 28 14:37:37 ultima NetworkManager[964]: <info> [1759066657.2195] dhcp4 (wlp9s0): activation: beginning transaction (timeout in 45 seconds)
Sep 28 14:37:37 ultima NetworkManager[964]: <info> [1759066657.2195] dhcp4 (wlp9s0): state changed no lease
Sep 28 14:37:37 ultima NetworkManager[964]: <info> [1759066657.2882] device (wlp9s0): set-hw-addr: set MAC address to FA:32:64:4D:60:2D (scanning)
Sep 28 14:37:37 ultima NetworkManager[964]: <info> [1759066657.9850] manager: NetworkManager state is now DISCONNECTED
Sep 28 14:37:37 ultima NetworkManager[964]: <info> [1759066657.9851] device (wlp9s0): Activation: starting connection 'TP-Link_8180_6G' (5d6b1a3d-7f9a-4a24
-919e-4481a4de16de)
Sep 28 14:37:37 ultima NetworkManager[964]: <info> [1759066657.9854] device (wlp9s0): supplicant interface state: completed -> disconnected
Sep 28 14:37:37 ultima NetworkManager[964]: <info> [1759066657.9854] device (p2p-dev-wlp9s0): supplicant management interface state: completed -> disconnec
ted
Sep 28 14:37:37 ultima NetworkManager[964]: <info> [1759066657.9854] device (wlp9s0): supplicant interface state: disconnected -> interface_disabled
Sep 28 14:37:37 ultima NetworkManager[964]: <info> [1759066657.9854] device (p2p-dev-wlp9s0): supplicant management interface state: disconnected -> interf
ace_disabled
Sep 28 14:37:37 ultima NetworkManager[964]: <info> [1759066657.9858] device (wlp9s0): supplicant interface state: interface_disabled -> disconnected
Sep 28 14:37:37 ultima NetworkManager[964]: <info> [1759066657.9858] device (p2p-dev-wlp9s0): supplicant management interface state: interface_disabled ->
disconnected
Sep 28 14:37:37 ultima NetworkManager[964]: <info> [1759066657.9860] device (wlp9s0): state change: disconnected -> prepare (reason 'none', managed-type: '
full')
Sep 28 14:37:37 ultima NetworkManager[964]: <info> [1759066657.9860] manager: NetworkManager state is now CONNECTING
Sep 28 14:37:38 ultima NetworkManager[964]: <info> [1759066658.0980] device (wlp9s0): set-hw-addr: reset MAC address to C0:BF:BE:38:9D:A6 (preserve)
Sep 28 14:37:38 ultima NetworkManager[964]: <info> [1759066658.6737] device (wlp9s0): state change: prepare -> config (reason 'none', managed-type: 'full')
Sep 28 14:37:38 ultima NetworkManager[964]: <info> [1759066658.6738] device (wlp9s0): Activation: (wifi) access point 'TP-Link_8180_6G' has security, but s
ecrets are required.
Sep 28 14:37:38 ultima NetworkManager[964]: <info> [1759066658.6738] device (wlp9s0): state change: config -> need-auth (reason 'none', managed-type: 'full
Sep 28 14:37:38 ultima NetworkManager[964]: <info> [1759066658.6802] device (wlp9s0): state change: need-auth -> prepare (reason 'none', managed-type: 'ful
l')
Sep 28 14:37:38 ultima NetworkManager[964]: <info> [1759066658.6803] device (wlp9s0): state change: prepare -> config (reason 'none', managed-type: 'full')
Sep 28 14:37:38 ultima NetworkManager[964]: <info> [1759066658.6804] device (wlp9s0): Activation: (wifi) connection 'TP-Link_8180_6G' has security, and sec
rets exist. No new secrets needed.
Sep 28 14:37:38 ultima NetworkManager[964]: <info> [1759066658.6804] Config: added 'ssid' value 'TP-Link_8180_6G'
Sep 28 14:37:38 ultima NetworkManager[964]: <info> [1759066658.6804] Config: added 'scan_ssid' value '1'
Sep 28 14:37:38 ultima NetworkManager[964]: <info> [1759066658.6804] Config: added 'bgscan' value 'simple:30:-70:86400'
Sep 28 14:37:38 ultima NetworkManager[964]: <info> [1759066658.6804] Config: added 'key_mgmt' value 'SAE FT-SAE'
Sep 28 14:37:38 ultima NetworkManager[964]: <info> [1759066658.6804] Config: added 'psk' value '<hidden>'
Sep 28 14:37:38 ultima NetworkManager[964]: <info> [1759066658.6804] Config: added 'ieee80211w' value '2'
Sep 28 14:37:38 ultima NetworkManager[964]: <info> [1759066658.7174] device (wlp9s0): supplicant interface state: disconnected -> scanning
Sep 28 14:37:38 ultima NetworkManager[964]: <info> [1759066658.7174] device (p2p-dev-wlp9s0): supplicant management interface state: disconnected -> scanni
ng
Sep 28 14:37:42 ultima NetworkManager[964]: <info> [1759066662.5004] device (wlp9s0): supplicant interface state: scanning -> authenticating
Sep 28 14:37:42 ultima NetworkManager[964]: <info> [1759066662.5005] device (p2p-dev-wlp9s0): supplicant management interface state: scanning -> authentica
ting
Sep 28 14:37:42 ultima NetworkManager[964]: <info> [1759066662.5153] device (wlp9s0): supplicant interface state: authenticating -> associating
Sep 28 14:37:42 ultima NetworkManager[964]: <info> [1759066662.5153] device (p2p-dev-wlp9s0): supplicant management interface state: authenticating -> asso
ciating
Sep 28 14:37:42 ultima NetworkManager[964]: <info> [1759066662.7843] device (wlp9s0): supplicant interface state: associating -> associated
Sep 28 14:37:42 ultima NetworkManager[964]: <info> [1759066662.7843] device (p2p-dev-wlp9s0): supplicant management interface state: associating -> associa
ted
Sep 28 14:37:43 ultima NetworkManager[964]: <info> [1759066663.5596] device (wlp9s0): supplicant interface state: associated -> 4way_handshake
Sep 28 14:37:43 ultima NetworkManager[964]: <info> [1759066663.5596] device (p2p-dev-wlp9s0): supplicant management interface state: associated -> 4way_han
dshake
Sep 28 14:37:51 ultima NetworkManager[964]: <info> [1759066671.9536] device (wlp9s0): supplicant interface state: 4way_handshake -> scanning
Sep 28 14:37:51 ultima NetworkManager[964]: <info> [1759066671.9536] device (p2p-dev-wlp9s0): supplicant management interface state: 4way_handshake -> scan
ning
Sep 28 14:37:55 ultima NetworkManager[964]: <info> [1759066675.7618] device (wlp9s0): supplicant interface state: scanning -> authenticating
Sep 28 14:37:55 ultima NetworkManager[964]: <info> [1759066675.7618] device (p2p-dev-wlp9s0): supplicant management interface state: scanning -> authentica
ting
Sep 28 14:37:55 ultima NetworkManager[964]: <info> [1759066675.7665] device (wlp9s0): supplicant interface state: authenticating -> associating
Sep 28 14:37:55 ultima NetworkManager[964]: <info> [1759066675.7665] device (p2p-dev-wlp9s0): supplicant management interface state: authenticating -> asso
ciating
Sep 28 14:37:56 ultima NetworkManager[964]: <info> [1759066676.0380] device (wlp9s0): supplicant interface state: associating -> associated
Sep 28 14:37:56 ultima NetworkManager[964]: <info> [1759066676.0380] device (p2p-dev-wlp9s0): supplicant management interface state: associating -> associa
ted
Sep 28 14:37:56 ultima NetworkManager[964]: <info> [1759066676.8068] device (wlp9s0): supplicant interface state: associated -> 4way_handshake
Sep 28 14:37:56 ultima NetworkManager[964]: <info> [1759066676.8068] device (p2p-dev-wlp9s0): supplicant management interface state: associated -> 4way_han
dshake
Sep 28 14:38:01 ultima NetworkManager[964]: <info> [1759066681.7484] device (wlp9s0): supplicant interface state: 4way_handshake -> scanning
Sep 28 14:38:01 ultima NetworkManager[964]: <info> [1759066681.7484] device (p2p-dev-wlp9s0): supplicant management interface state: 4way_handshake -> scan
ning
Sep 28 14:38:03 ultima NetworkManager[964]: <warn> [1759066683.4847] device (wlp9s0): Activation: (wifi) association took too long
Sep 28 14:38:03 ultima NetworkManager[964]: <info> [1759066683.4848] device (wlp9s0): state change: config -> need-auth (reason 'none', managed-type: 'full
Sep 28 14:38:03 ultima NetworkManager[964]: <warn> [1759066683.4850] device (wlp9s0): Activation: (wifi) asking for new secrets
Sep 28 14:38:03 ultima NetworkManager[964]: <info> [1759066683.4907] device (wlp9s0): state change: need-auth -> prepare (reason 'none', managed-type: 'ful
l')
Sep 28 14:38:03 ultima NetworkManager[964]: <info> [1759066683.4908] device (wlp9s0): state change: prepare -> config (reason 'none', managed-type: 'full')
Sep 28 14:38:03 ultima NetworkManager[964]: <info> [1759066683.4909] device (wlp9s0): Activation: (wifi) connection 'TP-Link_8180_6G' has security, and sec
Sep 28 14:38:03 ultima NetworkManager[964]: <info> [1759066683.4909] Config: added 'ssid' value 'TP-Link_8180_6G'
Sep 28 14:38:03 ultima NetworkManager[964]: <info> [1759066683.4909] Config: added 'scan_ssid' value '1'
Sep 28 14:38:03 ultima NetworkManager[964]: <info> [1759066683.4909] Config: added 'bgscan' value 'simple:30:-70:86400'
Sep 28 14:38:03 ultima NetworkManager[964]: <info> [1759066683.4909] Config: added 'key_mgmt' value 'SAE FT-SAE'
Sep 28 14:38:03 ultima NetworkManager[964]: <info> [1759066683.4909] Config: added 'psk' value '<hidden>'
Sep 28 14:38:03 ultima NetworkManager[964]: <info> [1759066683.4909] Config: added 'ieee80211w' value '2'
Sep 28 14:38:05 ultima NetworkManager[964]: <info> [1759066685.5442] device (wlp9s0): supplicant interface state: scanning -> authenticating
Sep 28 14:38:05 ultima NetworkManager[964]: <info> [1759066685.5442] device (p2p-dev-wlp9s0): supplicant management interface state: scanning -> authentica
ting
Sep 28 14:38:05 ultima NetworkManager[964]: <info> [1759066685.5574] device (wlp9s0): supplicant interface state: authenticating -> associating
Sep 28 14:38:05 ultima NetworkManager[964]: <info> [1759066685.5574] device (p2p-dev-wlp9s0): supplicant management interface state: authenticating -> asso
ciating
Sep 28 14:38:05 ultima NetworkManager[964]: <info> [1759066685.8254] device (wlp9s0): supplicant interface state: associating -> associated
Sep 28 14:38:05 ultima NetworkManager[964]: <info> [1759066685.8254] device (p2p-dev-wlp9s0): supplicant management interface state: associating -> associa
ted
Sep 28 14:38:06 ultima NetworkManager[964]: <info> [1759066686.5928] device (wlp9s0): supplicant interface state: associated -> 4way_handshake
Sep 28 14:38:06 ultima NetworkManager[964]: <info> [1759066686.5928] device (p2p-dev-wlp9s0): supplicant management interface state: associated -> 4way_han
dshake
Sep 28 14:38:17 ultima NetworkManager[964]: <info> [1759066697.8709] device (wlp9s0): supplicant interface state: 4way_handshake -> disconnected
Sep 28 14:38:17 ultima NetworkManager[964]: <info> [1759066697.8709] device (p2p-dev-wlp9s0): supplicant management interface state: 4way_handshake -> disc
onnected
Sep 28 14:38:17 ultima NetworkManager[964]: <info> [1759066697.8828] device (wlp9s0): supplicant interface state: disconnected -> scanning
Sep 28 14:38:17 ultima NetworkManager[964]: <info> [1759066697.8828] device (p2p-dev-wlp9s0): supplicant management interface state: disconnected -> scanni
ng
Sep 28 14:38:21 ultima NetworkManager[964]: <info> [1759066701.6672] device (wlp9s0): supplicant interface state: scanning -> authenticating
Sep 28 14:38:21 ultima NetworkManager[964]: <info> [1759066701.6673] device (p2p-dev-wlp9s0): supplicant management interface state: scanning -> authentica
ting
Sep 28 14:38:21 ultima NetworkManager[964]: <info> [1759066701.6721] device (wlp9s0): supplicant interface state: authenticating -> associating
Sep 28 14:38:21 ultima NetworkManager[964]: <info> [1759066701.6721] device (p2p-dev-wlp9s0): supplicant management interface state: authenticating -> asso
ciating
Sep 28 14:38:21 ultima NetworkManager[964]: <info> [1759066701.9385] device (wlp9s0): supplicant interface state: associating -> associated
Sep 28 14:38:21 ultima NetworkManager[964]: <info> [1759066701.9385] device (p2p-dev-wlp9s0): supplicant management interface state: associating -> associa
ted
Sep 28 14:38:22 ultima NetworkManager[964]: <info> [1759066702.7051] device (wlp9s0): supplicant interface state: associated -> 4way_handshake
Sep 28 14:38:22 ultima NetworkManager[964]: <info> [1759066702.7052] device (p2p-dev-wlp9s0): supplicant management interface state: associated -> 4way_han
dshake
Sep 28 14:38:28 ultima NetworkManager[964]: <warn> [1759066708.4847] device (wlp9s0): Activation: (wifi) association took too long
Sep 28 14:38:28 ultima NetworkManager[964]: <info> [1759066708.4847] device (wlp9s0): state change: config -> need-auth (reason 'none', managed-type: 'full
Sep 28 14:38:28 ultima NetworkManager[964]: <warn> [1759066708.4849] device (wlp9s0): Activation: (wifi) asking for new secrets
Sep 28 14:38:28 ultima NetworkManager[964]: <info> [1759066708.4919] device (wlp9s0): state change: need-auth -> prepare (reason 'none', managed-type: 'ful
l')
Sep 28 14:38:28 ultima NetworkManager[964]: <info> [1759066708.4919] device (wlp9s0): state change: prepare -> config (reason 'none', managed-type: 'full')
Sep 28 14:38:28 ultima NetworkManager[964]: <info> [1759066708.4921] device (wlp9s0): Activation: (wifi) connection 'TP-Link_8180_6G' has security, and sec
Sep 28 14:38:28 ultima NetworkManager[964]: <info> [1759066708.4921] Config: added 'ssid' value 'TP-Link_8180_6G'
Sep 28 14:38:28 ultima NetworkManager[964]: <info> [1759066708.4921] Config: added 'scan_ssid' value '1'
Sep 28 14:38:28 ultima NetworkManager[964]: <info> [1759066708.4921] Config: added 'bgscan' value 'simple:30:-70:86400'
Sep 28 14:38:28 ultima NetworkManager[964]: <info> [1759066708.4921] Config: added 'key_mgmt' value 'SAE FT-SAE'
Sep 28 14:38:28 ultima NetworkManager[964]: <info> [1759066708.4921] Config: added 'psk' value '<hidden>'
Sep 28 14:38:28 ultima NetworkManager[964]: <info> [1759066708.4921] Config: added 'ieee80211w' value '2'
Sep 28 14:38:29 ultima NetworkManager[964]: <info> [1759066709.7535] device (wlp9s0): supplicant interface state: 4way_handshake -> disconnected
Sep 28 14:38:29 ultima NetworkManager[964]: <info> [1759066709.7535] device (p2p-dev-wlp9s0): supplicant management interface state: 4way_handshake -> disc
onnected
Sep 28 14:38:29 ultima NetworkManager[964]: <info> [1759066709.7652] device (wlp9s0): supplicant interface state: disconnected -> scanning
Sep 28 14:38:29 ultima NetworkManager[964]: <info> [1759066709.7652] device (p2p-dev-wlp9s0): supplicant management interface state: disconnected -> scanni
ng
Sep 28 14:38:33 ultima NetworkManager[964]: <info> [1759066713.6098] device (wlp9s0): supplicant interface state: scanning -> authenticating
Sep 28 14:38:33 ultima NetworkManager[964]: <info> [1759066713.6098] device (p2p-dev-wlp9s0): supplicant management interface state: scanning -> authentica
ting
Sep 28 14:38:33 ultima NetworkManager[964]: <info> [1759066713.6247] device (wlp9s0): supplicant interface state: authenticating -> associating
Sep 28 14:38:33 ultima NetworkManager[964]: <info> [1759066713.6247] device (p2p-dev-wlp9s0): supplicant management interface state: authenticating -> asso
ciating
Sep 28 14:38:33 ultima NetworkManager[964]: <info> [1759066713.9163] device (wlp9s0): supplicant interface state: associating -> associated
Sep 28 14:38:33 ultima NetworkManager[964]: <info> [1759066713.9163] device (p2p-dev-wlp9s0): supplicant management interface state: associating -> associa
ted
Sep 28 14:38:34 ultima NetworkManager[964]: <info> [1759066714.6715] device (wlp9s0): supplicant interface state: associated -> 4way_handshake
Sep 28 14:38:34 ultima NetworkManager[964]: <info> [1759066714.6715] device (p2p-dev-wlp9s0): supplicant management interface state: associated -> 4way_han
dshake
Sep 28 14:38:45 ultima NetworkManager[964]: <info> [1759066725.9423] device (wlp9s0): supplicant interface state: 4way_handshake -> disconnected
Sep 28 14:38:45 ultima NetworkManager[964]: <info> [1759066725.9423] device (p2p-dev-wlp9s0): supplicant management interface state: 4way_handshake -> disc
onnected
Sep 28 14:38:45 ultima NetworkManager[964]: <info> [1759066725.9541] device (wlp9s0): supplicant interface state: disconnected -> scanning
Sep 28 14:38:45 ultima NetworkManager[964]: <info> [1759066725.9541] device (p2p-dev-wlp9s0): supplicant management interface state: disconnected -> scanni
ng
Sep 28 14:38:53 ultima NetworkManager[964]: <warn> [1759066733.4846] device (wlp9s0): Activation: (wifi) association took too long
Sep 28 14:38:53 ultima NetworkManager[964]: <info> [1759066733.4846] device (wlp9s0): state change: config -> failed (reason 'no-secrets', managed-type: 'f
ull')
Sep 28 14:38:53 ultima NetworkManager[964]: <info> [1759066733.4847] manager: NetworkManager state is now DISCONNECTED
Sep 28 14:38:53 ultima NetworkManager[964]: <info> [1759066733.5504] device (wlp9s0): set-hw-addr: set MAC address to 26:F4:CB:8E:C0:D4 (scanning)
Sep 28 14:38:54 ultima NetworkManager[964]: <warn> [1759066734.1776] device (wlp9s0): Activation: failed for connection 'TP-Link_8180_6G'
Sep 28 14:38:54 ultima NetworkManager[964]: <info> [1759066734.1778] device (wlp9s0): supplicant interface state: scanning -> interface_disabled
Sep 28 14:38:54 ultima NetworkManager[964]: <info> [1759066734.1778] device (p2p-dev-wlp9s0): supplicant management interface state: scanning -> interface_
disabled
Sep 28 14:38:54 ultima NetworkManager[964]: <info> [1759066734.1778] device (wlp9s0): supplicant interface state: interface_disabled -> disconnected
Sep 28 14:38:54 ultima NetworkManager[964]: <info> [1759066734.1778] device (p2p-dev-wlp9s0): supplicant management interface state: interface_disabled ->
disconnected
Sep 28 14:38:54 ultima NetworkManager[964]: <info> [1759066734.1778] device (wlp9s0): supplicant interface state: disconnected -> inactive
Sep 28 14:38:54 ultima NetworkManager[964]: <info> [1759066734.1778] device (p2p-dev-wlp9s0): supplicant management interface state: disconnected -> inacti
ve
Sep 28 14:38:54 ultima NetworkManager[964]: <info> [1759066734.1779] device (wlp9s0): state change: failed -> disconnected (reason 'none', managed-type: 'f
ull')
Sep 28 14:38:57 ultima NetworkManager[964]: <info> [1759066737.5112] policy: auto-activating connection 'TP-Link_8180' (4c3285ad-b259-4518-9ad9-2983844b907
1)
Sep 28 14:38:57 ultima NetworkManager[964]: <info> [1759066737.5114] device (wlp9s0): Activation: starting connection 'TP-Link_8180' (4c3285ad-b259-4518-9a
d9-2983844b9071)
Sep 28 14:38:57 ultima NetworkManager[964]: <info> [1759066737.5114] device (wlp9s0): state change: disconnected -> prepare (reason 'none', managed-type: '
full')
Sep 28 14:38:57 ultima NetworkManager[964]: <info> [1759066737.5115] manager: NetworkManager state is now CONNECTING
Sep 28 14:38:57 ultima NetworkManager[964]: <info> [1759066737.5652] device (wlp9s0): set-hw-addr: reset MAC address to C0:BF:BE:38:9D:A6 (preserve)
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1851] device (wlp9s0): state change: prepare -> config (reason 'none', managed-type: 'full')
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1852] device (wlp9s0): Activation: (wifi) access point 'TP-Link_8180' has security, but secr
ets are required.
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1853] device (wlp9s0): state change: config -> need-auth (reason 'none', managed-type: 'full
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1853] sup-iface[d4e3189b7f4c2355,0,wlp9s0]: wps: type pbc start...
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1859] device (wlp9s0): supplicant interface state: inactive -> interface_disabled
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1859] device (p2p-dev-wlp9s0): supplicant management interface state: inactive -> interface_
disabled
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1859] device (wlp9s0): supplicant interface state: interface_disabled -> disconnected
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1859] device (p2p-dev-wlp9s0): supplicant management interface state: interface_disabled ->
disconnected
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1859] device (wlp9s0): supplicant interface state: disconnected -> inactive
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1859] device (p2p-dev-wlp9s0): supplicant management interface state: disconnected -> inacti
ve
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1938] device (wlp9s0): state change: need-auth -> prepare (reason 'none', managed-type: 'ful
l')
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1939] device (wlp9s0): state change: prepare -> config (reason 'none', managed-type: 'full')
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1940] device (wlp9s0): Activation: (wifi) connection 'TP-Link_8180' has security, and secret
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1940] Config: added 'ssid' value 'TP-Link_8180'
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1940] Config: added 'scan_ssid' value '1'
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1940] Config: added 'bgscan' value 'simple:30:-65:300'
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1941] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1941] Config: added 'auth_alg' value 'OPEN'
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.1941] Config: added 'psk' value '<hidden>'
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.2063] device (wlp9s0): supplicant interface state: inactive -> scanning
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.2063] device (p2p-dev-wlp9s0): supplicant management interface state: inactive -> scanning
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.2893] device (wlp9s0): supplicant interface state: scanning -> authenticating
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.2893] device (p2p-dev-wlp9s0): supplicant management interface state: scanning -> authentica
ting
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.2942] device (wlp9s0): supplicant interface state: authenticating -> associating
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.2942] device (p2p-dev-wlp9s0): supplicant management interface state: authenticating -> asso
ciating
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.5559] device (wlp9s0): supplicant interface state: associating -> associated
Sep 28 14:38:58 ultima NetworkManager[964]: <info> [1759066738.5559] device (p2p-dev-wlp9s0): supplicant management interface state: associating -> associa
ted
Sep 28 14:38:59 ultima NetworkManager[964]: <info> [1759066739.4281] device (wlp9s0): supplicant interface state: associated -> completed
Sep 28 14:38:59 ultima NetworkManager[964]: <info> [1759066739.4281] device (wlp9s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connec
ted to wireless network "TP-Link_8180"
Sep 28 14:38:59 ultima NetworkManager[964]: <info> [1759066739.4281] device (p2p-dev-wlp9s0): supplicant management interface state: associated -> complete
d
Sep 28 14:38:59 ultima NetworkManager[964]: <info> [1759066739.4281] device (wlp9s0): state change: config -> ip-config (reason 'none', managed-type: 'full
Sep 28 14:38:59 ultima NetworkManager[964]: <info> [1759066739.4284] dhcp4 (wlp9s0): activation: beginning transaction (timeout in 45 seconds)
Sep 28 14:38:59 ultima NetworkManager[964]: <info> [1759066739.4569] dhcp4 (wlp9s0): state changed new lease, address=192.168.1.80, acd pending
Sep 28 14:38:59 ultima NetworkManager[964]: <info> [1759066739.6242] dhcp4 (wlp9s0): state changed new lease, address=192.168.1.80
Sep 28 14:38:59 ultima NetworkManager[964]: <info> [1759066739.6267] policy: set 'TP-Link_8180' (wlp9s0) as default for IPv4 routing and DNS
Sep 28 14:38:59 ultima NetworkManager[964]: <info> [1759066739.6381] device (wlp9s0): state change: ip-config -> ip-check (reason 'none', managed-type: 'fu
ll')
Sep 28 14:38:59 ultima NetworkManager[964]: <info> [1759066739.6853] device (wlp9s0): state change: ip-check -> secondaries (reason 'none', managed-type: '
full')
Sep 28 14:38:59 ultima NetworkManager[964]: <info> [1759066739.6854] device (wlp9s0): state change: secondaries -> activated (reason 'none', managed-type:
'full')
Sep 28 14:38:59 ultima NetworkManager[964]: <info> [1759066739.6855] manager: NetworkManager state is now CONNECTED_SITE
Sep 28 14:38:59 ultima NetworkManager[964]: <info> [1759066739.6858] device (wlp9s0): Activation: successful, device activated.
Sep 28 14:38:59 ultima NetworkManager[964]: <info> [1759066739.6859] manager: NetworkManager state is now CONNECTED_GLOBAL
Sep 28 14:38:59 ultima NetworkManager[964]: <info> [1759066739.6952] audit: op="statistics" interface="wlp9s0" ifindex=3 args="2000" pid=1452 uid=1000 resu
lt="success"
Sep 28 14:38:59 ultima NetworkManager[964]: <info> [1759066739.6999] audit: op="statistics" interface="wlp9s0" ifindex=3 args="500" pid=1549 uid=1000 resul
t="success"
DMESG:
2400.451609] wlp9s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 7a:07:1d:bc:81:7c
[ 2755.289710] wlp9s0: deauthenticating from 7a:07:1d:bc:81:7c by local choice (Reason: 3=DEAUTH_LEAVING)
[ 2761.559226] wlp9s0: authenticate with 82:07:1d:bc:81:7d (local address=c0:bf:be:38:9d:a6)
[ 2761.576289] wlp9s0: send auth to 82:07:1d:bc:81:7d (try 1/3)
[ 2761.583399] wlp9s0: authenticate with 82:07:1d:bc:81:7d (local address=c0:bf:be:38:9d:a6)
[ 2761.583403] wlp9s0: send auth to 82:07:1d:bc:81:7d (try 1/3)
[ 2761.587462] wlp9s0: authenticated
[ 2761.592986] wlp9s0: associate with 82:07:1d:bc:81:7d (try 1/3)
[ 2761.617375] wlp9s0: RX AssocResp from 82:07:1d:bc:81:7d (capab=0x1011 status=0 aid=24)
[ 2761.651514] wlp9s0: associated
[ 2772.627952] wlp9s0: deauthenticating from 82:07:1d:bc:81:7d by local choice (Reason: 3=DEAUTH_LEAVING)
[ 2777.714527] wlp9s0: authenticate with 82:07:1d:bc:81:7d (local address=c0:bf:be:38:9d:a6)
[ 2777.724306] wlp9s0: send auth to 82:07:1d:bc:81:7d (try 1/3)
[ 2777.725509] wlp9s0: authenticated
[ 2777.729579] wlp9s0: associate with 82:07:1d:bc:81:7d (try 1/3)
[ 2777.756695] wlp9s0: RX AssocResp from 82:07:1d:bc:81:7d (capab=0x1011 status=0 aid=25)
[ 2777.788402] wlp9s0: associated
[ 2782.603705] wlp9s0: deauthenticating from 82:07:1d:bc:81:7d by local choice (Reason: 3=DEAUTH_LEAVING)
[ 2787.665355] wlp9s0: authenticate with 82:07:1d:bc:81:7d (local address=c0:bf:be:38:9d:a6)
[ 2787.682452] wlp9s0: send auth to 82:07:1d:bc:81:7d (try 1/3)
[ 2787.689965] wlp9s0: authenticate with 82:07:1d:bc:81:7d (local address=c0:bf:be:38:9d:a6)
[ 2787.689972] wlp9s0: send auth to 82:07:1d:bc:81:7d (try 1/3)
[ 2787.694048] wlp9s0: authenticated
[ 2787.699576] wlp9s0: associate with 82:07:1d:bc:81:7d (try 1/3)
[ 2787.722787] wlp9s0: RX AssocResp from 82:07:1d:bc:81:7d (capab=0x1011 status=0 aid=26)
[ 2787.754374] wlp9s0: associated
[ 2798.729933] wlp9s0: deauthenticating from 82:07:1d:bc:81:7d by local choice (Reason: 3=DEAUTH_LEAVING)
[ 2803.786517] wlp9s0: authenticate with 82:07:1d:bc:81:7d (local address=c0:bf:be:38:9d:a6)
[ 2803.796312] wlp9s0: send auth to 82:07:1d:bc:81:7d (try 1/3)
[ 2803.797533] wlp9s0: authenticated
[ 2803.802950] wlp9s0: associate with 82:07:1d:bc:81:7d (try 1/3)
[ 2803.826825] wlp9s0: RX AssocResp from 82:07:1d:bc:81:7d (capab=0x1011 status=0 aid=27)
[ 2803.860578] wlp9s0: associated
[ 2807.603682] wlp9s0: deauthenticating from 82:07:1d:bc:81:7d by local choice (Reason: 3=DEAUTH_LEAVING)
[ 2812.734598] wlp9s0: authenticate with 82:07:1d:bc:81:7d (local address=c0:bf:be:38:9d:a6)
[ 2812.744375] wlp9s0: send auth to 82:07:1d:bc:81:7d (try 1/3)
[ 2812.751882] wlp9s0: authenticate with 82:07:1d:bc:81:7d (local address=c0:bf:be:38:9d:a6)
[ 2812.751888] wlp9s0: send auth to 82:07:1d:bc:81:7d (try 1/3)
[ 2812.756050] wlp9s0: authenticated
[ 2812.759663] wlp9s0: associate with 82:07:1d:bc:81:7d (try 1/3)
[ 2812.784821] wlp9s0: RX AssocResp from 82:07:1d:bc:81:7d (capab=0x1011 status=0 aid=28)
[ 2812.817399] wlp9s0: associated
[ 2823.796141] wlp9s0: deauthenticating from 82:07:1d:bc:81:7d by local choice (Reason: 3=DEAUTH_LEAVING)
[ 2828.838735] wlp9s0: authenticate with 82:07:1d:bc:81:7d (local address=c0:bf:be:38:9d:a6)
[ 2828.855810] wlp9s0: send auth to 82:07:1d:bc:81:7d (try 1/3)
[ 2828.858749] wlp9s0: authenticated
[ 2828.866452] wlp9s0: associate with 82:07:1d:bc:81:7d (try 1/3)
[ 2828.886947] wlp9s0: RX AssocResp from 82:07:1d:bc:81:7d (capab=0x1011 status=0 aid=29)
[ 2828.920673] wlp9s0: associated
[ 2832.603785] wlp9s0: deauthenticating from 82:07:1d:bc:81:7d by local choice (Reason: 3=DEAUTH_LEAVING)
[ 2835.932634] wlp9s0: authenticate with 7a:07:1d:bc:81:7c (local address=c0:bf:be:38:9d:a6)
[ 2835.949726] wlp9s0: send auth to 7a:07:1d:bc:81:7c (try 1/3)
[ 2835.952681] wlp9s0: authenticated
[ 2835.959864] wlp9s0: associate with 7a:07:1d:bc:81:7c (try 1/3)
[ 2835.969704] wlp9s0: RX AssocResp from 7a:07:1d:bc:81:7c (capab=0x1011 status=0 aid=18)
[ 2836.004634] wlp9s0: associated
[ 2836.066393] wlp9s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 7a:07:1d:bc:81:7c
EDIT: Logs of successful connection to 6GHz and failing on IP refresh -
Sep 28 13:45:50 ultima NetworkManager[977]: <info> [1759063550.4142] device (wlp9s0): state change: prepare -> config (reason 'none', managed-type: 'full')
Sep 28 13:45:50 ultima NetworkManager[977]: <info> [1759063550.4143] device (wlp9s0): Activation: (wifi) connection 'TP-Link_8180_6G' has security, and sec
Sep 28 13:45:50 ultima NetworkManager[977]: <info> [1759063550.4143] Config: added 'ssid' value 'TP-Link_8180_6G'
Sep 28 13:45:50 ultima NetworkManager[977]: <info> [1759063550.4143] Config: added 'scan_ssid' value '1'
Sep 28 13:45:50 ultima NetworkManager[977]: <info> [1759063550.4143] Config: added 'bgscan' value 'simple:30:-70:86400'
Sep 28 13:45:50 ultima NetworkManager[977]: <info> [1759063550.4143] Config: added 'key_mgmt' value 'SAE FT-SAE'
Sep 28 13:45:50 ultima NetworkManager[977]: <info> [1759063550.4143] Config: added 'psk' value '<hidden>'
Sep 28 13:45:50 ultima NetworkManager[977]: <info> [1759063550.4143] Config: added 'ieee80211w' value '2'
Sep 28 13:45:50 ultima NetworkManager[977]: <info> [1759063550.4545] device (wlp9s0): supplicant interface state: disconnected -> scanning
Sep 28 13:45:50 ultima NetworkManager[977]: <info> [1759063550.4545] device (p2p-dev-wlp9s0): supplicant management interface state: disconnected -> scanni
ng
Sep 28 13:46:11 ultima NetworkManager[977]: <info> [1759063571.8782] device (wlp9s0): supplicant interface state: scanning -> authenticating
Sep 28 13:46:11 ultima NetworkManager[977]: <info> [1759063571.8782] device (p2p-dev-wlp9s0): supplicant management interface state: scanning -> authentica
ting
Sep 28 13:46:11 ultima NetworkManager[977]: <info> [1759063571.9492] device (wlp9s0): supplicant interface state: authenticating -> associating
Sep 28 13:46:11 ultima NetworkManager[977]: <info> [1759063571.9493] device (p2p-dev-wlp9s0): supplicant management interface state: authenticating -> asso
ciating
Sep 28 13:46:12 ultima NetworkManager[977]: <info> [1759063572.3547] device (wlp9s0): supplicant interface state: associating -> associated
Sep 28 13:46:12 ultima NetworkManager[977]: <info> [1759063572.3547] device (p2p-dev-wlp9s0): supplicant management interface state: associating -> associa
ted
Sep 28 13:46:13 ultima NetworkManager[977]: <info> [1759063573.1562] device (wlp9s0): supplicant interface state: associated -> completed
Sep 28 13:46:13 ultima NetworkManager[977]: <info> [1759063573.1562] device (wlp9s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connec
ted to wireless network "TP-Link_8180_6G"
Sep 28 13:46:13 ultima NetworkManager[977]: <info> [1759063573.1562] device (p2p-dev-wlp9s0): supplicant management interface state: associated -> complete
d
Sep 28 13:46:13 ultima NetworkManager[977]: <info> [1759063573.1563] device (wlp9s0): state change: config -> ip-config (reason 'none', managed-type: 'full
Sep 28 13:46:13 ultima NetworkManager[977]: <info> [1759063573.1565] dhcp4 (wlp9s0): activation: beginning transaction (timeout in 45 seconds)
Sep 28 13:46:13 ultima NetworkManager[977]: <info> [1759063573.3307] dhcp4 (wlp9s0): state changed new lease, address=192.168.1.80, acd pending
Sep 28 13:46:13 ultima NetworkManager[977]: <info> [1759063573.5161] dhcp4 (wlp9s0): state changed new lease, address=192.168.1.80
Sep 28 13:46:13 ultima NetworkManager[977]: <info> [1759063573.5199] policy: set 'TP-Link_8180_6G' (wlp9s0) as default for IPv4 routing and DNS
Sep 28 13:46:13 ultima NetworkManager[977]: <info> [1759063573.5280] device (wlp9s0): state change: ip-config -> ip-check (reason 'none', managed-type: 'fu
ll')
Sep 28 13:46:13 ultima NetworkManager[977]: <info> [1759063573.5731] device (wlp9s0): state change: ip-check -> secondaries (reason 'none', managed-type: '
full')
Sep 28 13:46:13 ultima NetworkManager[977]: <info> [1759063573.5732] device (wlp9s0): state change: secondaries -> activated (reason 'none', managed-type:
'full')
Sep 28 13:46:13 ultima NetworkManager[977]: <info> [1759063573.5733] manager: NetworkManager state is now CONNECTED_SITE
Sep 28 13:46:13 ultima NetworkManager[977]: <info> [1759063573.5736] device (wlp9s0): Activation: successful, device activated.
Sep 28 13:46:13 ultima NetworkManager[977]: <info> [1759063573.5737] manager: NetworkManager state is now CONNECTED_GLOBAL
Sep 28 13:46:13 ultima NetworkManager[977]: <info> [1759063573.5844] audit: op="statistics" interface="wlp9s0" ifindex=3 args="2000" pid=1553 uid=1000 resu
lt="success"
Sep 28 13:46:13 ultima NetworkManager[977]: <info> [1759063573.5879] audit: op="statistics" interface="wlp9s0" ifindex=3 args="500" pid=1789 uid=1000 resul
t="success"
Sep 28 13:46:21 ultima NetworkManager[977]: <info> [1759063581.6057] device (wlp9s0): ip:dhcp4: restarting
Sep 28 13:46:21 ultima NetworkManager[977]: <info> [1759063581.6494] dhcp4 (wlp9s0): canceled DHCP transaction
Sep 28 13:46:21 ultima NetworkManager[977]: <info> [1759063581.6495] dhcp4 (wlp9s0): activation: beginning transaction (timeout in 45 seconds)
Sep 28 13:46:21 ultima NetworkManager[977]: <info> [1759063581.6495] dhcp4 (wlp9s0): state changed no lease
Sep 28 13:46:22 ultima NetworkManager[977]: <info> [1759063582.5109] device (wlp9s0): ip:dhcp4: restarting
Sep 28 13:46:22 ultima NetworkManager[977]: <info> [1759063582.5561] dhcp4 (wlp9s0): canceled DHCP transaction
Sep 28 13:46:22 ultima NetworkManager[977]: <info> [1759063582.5561] dhcp4 (wlp9s0): state changed no lease
Sep 28 13:46:22 ultima NetworkManager[977]: <info> [1759063582.5562] dhcp4 (wlp9s0): activation: beginning transaction (timeout in 45 seconds)
Sep 28 13:46:22 ultima NetworkManager[977]: <info> [1759063582.5563] device (wlp9s0): supplicant interface state: completed -> scanning
Sep 28 13:46:22 ultima NetworkManager[977]: <info> [1759063582.5563] device (p2p-dev-wlp9s0): supplicant management interface state: completed -> scanning
Sep 28 13:46:26 ultima NetworkManager[977]: <info> [1759063586.2863] device (wlp9s0): supplicant interface state: scanning -> disconnected
Sep 28 13:46:26 ultima NetworkManager[977]: <info> [1759063586.2864] device (p2p-dev-wlp9s0): supplicant management interface state: scanning -> disconnect
ed
Sep 28 13:46:29 ultima NetworkManager[977]: <info> [1759063589.7516] device (wlp9s0): supplicant interface state: disconnected -> authenticating
Sep 28 13:46:29 ultima NetworkManager[977]: <info> [1759063589.7516] device (p2p-dev-wlp9s0): supplicant management interface state: disconnected -> authen
ticating
Sep 28 13:46:29 ultima NetworkManager[977]: <info> [1759063589.7556] device (wlp9s0): supplicant interface state: authenticating -> associating
Sep 28 13:46:29 ultima NetworkManager[977]: <info> [1759063589.7556] device (p2p-dev-wlp9s0): supplicant management interface state: authenticating -> asso
ciating
Sep 28 13:46:30 ultima NetworkManager[977]: <info> [1759063590.1546] device (wlp9s0): supplicant interface state: associating -> associated
Sep 28 13:46:30 ultima NetworkManager[977]: <info> [1759063590.1546] device (p2p-dev-wlp9s0): supplicant management interface state: associating -> associa
ted
Sep 28 13:46:30 ultima NetworkManager[977]: <info> [1759063590.7897] device (wlp9s0): supplicant interface state: associated -> 4way_handshake
Sep 28 13:46:30 ultima NetworkManager[977]: <info> [1759063590.7897] device (p2p-dev-wlp9s0): supplicant management interface state: associated -> 4way_han
dshake
Sep 28 13:46:34 ultima NetworkManager[977]: <info> [1759063594.9723] device (wlp9s0): ip:dhcp4: restarting
Sep 28 13:46:35 ultima NetworkManager[977]: <info> [1759063595.0161] dhcp4 (wlp9s0): canceled DHCP transaction
Sep 28 13:46:35 ultima NetworkManager[977]: <info> [1759063595.0161] dhcp4 (wlp9s0): state changed no lease
Sep 28 13:46:35 ultima NetworkManager[977]: <info> [1759063595.0162] dhcp4 (wlp9s0): activation: beginning transaction (timeout in 45 seconds)
Sep 28 13:46:35 ultima NetworkManager[977]: <info> [1759063595.7445] device (wlp9s0): supplicant interface state: 4way_handshake -> scanning
Sep 28 13:46:35 ultima NetworkManager[977]: <info> [1759063595.7445] device (p2p-dev-wlp9s0): supplicant management interface state: 4way_handshake -> scan
ning
Sep 28 13:46:39 ultima NetworkManager[977]: <info> [1759063599.5376] device (wlp9s0): supplicant interface state: scanning -> authenticating
Sep 28 13:46:39 ultima NetworkManager[977]: <info> [1759063599.5377] device (p2p-dev-wlp9s0): supplicant management interface state: scanning -> authentica
ting
Sep 28 13:46:39 ultima NetworkManager[977]: <info> [1759063599.5423] device (wlp9s0): supplicant interface state: authenticating -> associating
Sep 28 13:46:39 ultima NetworkManager[977]: <info> [1759063599.5423] device (p2p-dev-wlp9s0): supplicant management interface state: authenticating -> asso
ciating
Sep 28 13:46:39 ultima NetworkManager[977]: <info> [1759063599.7955] device (wlp9s0): supplicant interface state: associating -> associated
Sep 28 13:46:39 ultima NetworkManager[977]: <info> [1759063599.7955] device (p2p-dev-wlp9s0): supplicant management interface state: associating -> associa
ted
Sep 28 13:46:40 ultima NetworkManager[977]: <info> [1759063600.5761] device (wlp9s0): supplicant interface state: associated -> 4way_handshake
Sep 28 13:46:40 ultima NetworkManager[977]: <info> [1759063600.5761] device (p2p-dev-wlp9s0): supplicant management interface state: associated -> 4way_han
dshake
Sep 28 13:46:50 ultima NetworkManager[977]: <info> [1759063610.0666] dhcp4 (wlp9s0): state changed no lease
Sep 28 13:46:50 ultima NetworkManager[977]: <info> [1759063610.5798] device (wlp9s0): ip:dhcp4: restarting
Sep 28 13:46:50 ultima NetworkManager[977]: <info> [1759063610.5995] dhcp4 (wlp9s0): canceled DHCP transaction
Sep 28 13:46:50 ultima NetworkManager[977]: <info> [1759063610.5995] dhcp4 (wlp9s0): state changed no lease
Sep 28 13:46:50 ultima NetworkManager[977]: <info> [1759063610.5995] dhcp4 (wlp9s0): activation: beginning transaction (timeout in 45 seconds)
Sep 28 13:46:51 ultima NetworkManager[977]: <info> [1759063611.2385] policy: set 'TP-Link_8180_6G' (wlp9s0) as default for IPv4 routing and DNS
Sep 28 13:46:51 ultima NetworkManager[977]: <info> [1759063611.8496] device (wlp9s0): supplicant interface state: 4way_handshake -> disconnected
Sep 28 13:46:51 ultima NetworkManager[977]: <info> [1759063611.8496] device (p2p-dev-wlp9s0): supplicant management interface state: 4way_handshake -> disc
onnected
Sep 28 13:46:51 ultima NetworkManager[977]: <info> [1759063611.8611] device (wlp9s0): supplicant interface state: disconnected -> scanning
Sep 28 13:46:51 ultima NetworkManager[977]: <info> [1759063611.8611] device (p2p-dev-wlp9s0): supplicant management interface state: disconnected -> scanni
ng
Sep 28 13:46:55 ultima NetworkManager[977]: <info> [1759063615.6203] device (wlp9s0): supplicant interface state: scanning -> authenticating
Sep 28 13:46:55 ultima NetworkManager[977]: <info> [1759063615.6203] device (p2p-dev-wlp9s0): supplicant management interface state: scanning -> authentica
ting
Sep 28 13:46:55 ultima NetworkManager[977]: <info> [1759063615.6250] device (wlp9s0): supplicant interface state: authenticating -> associating
Sep 28 13:46:55 ultima NetworkManager[977]: <info> [1759063615.6250] device (p2p-dev-wlp9s0): supplicant management interface state: authenticating -> asso
ciating
Sep 28 13:46:55 ultima NetworkManager[977]: <info> [1759063615.8976] device (wlp9s0): supplicant interface state: associating -> associated
Sep 28 13:46:55 ultima NetworkManager[977]: <info> [1759063615.8976] device (p2p-dev-wlp9s0): supplicant management interface state: associating -> associa
ted
On graceful shutdown, I sometimes get - mt7925e 0000:09:00.0: driver own failed
Any assistance or guidance would be greatly appreciated! Thank you.
