This is how I get:
[ 30:033439] watchdog: watchdog0: watchdog did not stop!
[ 30:132702] watchdog: watchdog0: watchdog did not stop!
How can I get rid of this message? My desktop information is:
System: Host: FIRESTAR Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.22.5
Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 20WKA000CD v: ThinkPad X13 Gen 2i
serial: <superuser required>
Mobo: LENOVO model: 20WKA000CD v: SDK0L77769 WIN serial: <superuser required> UEFI: LENOVO
v: N35ET34W (1.34 ) date: 04/22/2021
Battery: ID-1: BAT0 charge: 50.1 Wh (91.6%) condition: 54.7/54.7 Wh (100.0%)
CPU: Info: Quad Core 11th Gen Intel Core i7-1165G7 [MT MCP] speed: 2127 MHz min/max: 400/4700 MHz
Graphics: Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
Device-2: IMC Networks Integrated RGB Camera type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.13 driver: loaded: modesetting s-res: 2560x1600
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.2.1
Network: Device-1: Intel Ethernet I219-V driver: e1000e
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi
Drives: Local Storage: total: 953.87 GiB used: 72.18 GiB (7.6%)
Info: Processes: 258 Uptime: 8m Memory: 15.36 GiB used: 2.84 GiB (18.5%) Shell: Bash inxi: 3.3.06
Update 20211226: try sysctl kernel.nmi_watchdog=0
Hello @Firestar
file: /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="nowatchdog"
sudo update-grub
file: /etc/mkinitcpio.conf
HOOKS=(base udev autodetect modconf block keyboard keymap filesystems resume shutdown)
sudo mkinitcpio -P
Thanks! But this does not work.
Wollie
4
Add nmi_watchdog=0 nowatchdog after quiet in line starting
GRUB_CMDLINE_LINUX_DEFAULT=" of your /etc/default/grub.
Then run
sudo update grub
and reboot.
Unfortunately this solution and these two solutions combined cannot make it disappear.
Now it is:
[ 668:438999] watchdog: watchdog0: watchdog did not stop!
[ 668:559269] watchdog: watchdog0: watchdog did not stop!
What does this mean?
/etc/default/grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet nmi_watchdog=0 nowatchdog loglevel=3 udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=2560x1440,auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
GRUB_THEME="/boot/grub/themes/vimix/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
#GRUB_ROOT_FS_RO=true
HOOKS="base systemd autodetect modconf block keyboard keymap filesystems fsck resume shutdown"
And it seems that it only happens when rebooting. This does not happen on my old surface pro either
Wollie
6
Create the file /etc/modprobe.d/watchdog.conf
by
sudo nano /etc/modprobe.d/watchdog.conf
with following content:
# Blacklist unwanted drivers
blacklist iTCO_wdt
blacklist iTCO_vendor_support
Afterwards exececute
sudo update-grub
and reboot.
Only this would be OK. But I got a stuck yesterday evening when I was rebooting. I cannot reproduce it now.
Update 9.20:
It happens again and the solution by @Wollie does not work now.
