5.12 is installed but it's running 5.11 and 5.12 isn't an option in Grub
I have installed 5.12 via Manjaro Settings Manager and it shows as installed.
Yet a command inquiry shows I’m only running 5.11 and 5.12 is not available in the advanced options of Grub to boot into.
mhwd-kernel -li shows 5.10, 5.11 and 5.12 all installed.
inxi follows:
  Kernel: 5.11.16-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
  root=UUID=2888ee6c-3156-40cc-ab58-b2efb0745350 rw quiet apparmor=1
  Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Laptop System: Apple product: MacBookPro10,1 v: 1.0 serial: <filter>
  Chassis: type: 10 v: Mac-C3EC7CD22292981F serial: <filter>
  Mobo: Apple model: Mac-C3EC7CD22292981F v: MacBookPro10,1 serial: <filter>
  UEFI: Apple v: 421.0.0.0.0 date: 12/17/2020
  ID-1: BAT0 charge: 93.7 Wh (100.0%) condition: 93.7/91.6 Wh (102.3%)
  volts: 12.7 min: 10.9 model: Newer Tech A1417 type: Li-ion serial: N/A
  status: Full cycles: 70
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
  serial: <filter> charge: 100% (should be ignored) rechargeable: yes
  status: Discharging
  Device-2: hidpp_battery_1
  model: Logitech K780 Multi-Device Wireless Keyboard serial: <filter>
  charge: 100% (should be ignored) rechargeable: yes status: Discharging
  RAM: total: 15.54 GiB used: 2.45 GiB (15.7%)
  Info: Quad Core model: Intel Core i7-3740QM bits: 64 type: MT MCP
  arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
  cache: L2: 6 MiB bogomips: 43123
  Speed: 1305 MHz min/max: 1200/3700 MHz Core speeds (MHz): 1: 1305 2: 1268
  3: 1475 4: 1274 5: 1414 6: 1401 7: 1856 8: 1318
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
  constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept erms
  est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida lahf_lm
  lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe
  pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
  rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
  tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
  xsaveopt xtopology xtpr
  Type: l1tf
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
  Device-2: NVIDIA GK107M [GeForce GT 650M Mac Edition] vendor: Apple
  driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:0fd5 class-ID: 0300
  Device-3: Apple FaceTime HD Camera (Built-in) type: USB driver: uvcvideo
  bus-ID: 1-1.1:3 chip-ID: 05ac:8510 class-ID: 0e02 serial: <filter>
  Device-4: Apple FaceTime HD Camera (Display) type: USB driver: uvcvideo
  bus-ID: 3-1.5:4 chip-ID: 05ac:1112 class-ID: 0e02 serial: <filter>
  Device-5: Apple FaceTime HD Camera (Display) type: USB driver: uvcvideo
  bus-ID: 4-1.5:4 chip-ID: 05ac:1112 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
  display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1353x380mm (53.3x15.0")
  s-diag: 1405mm (55.3")
  Monitor-1: DP-1 res: 2560x1440 hz: 60 dpi: 109 size: 597x336mm (23.5x13.2")
  diag: 685mm (27")
  Monitor-2: DP-2 res: 2560x1440 hz: 60 dpi: 109 size: 597x336mm (23.5x13.2")
  diag: 685mm (27")
  OpenGL: renderer: NVE7 v: 4.3 Mesa 21.0.3 direct render: Yes
  Device-1: Intel 7 Series/C216 Family High Definition Audio
  driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
  class-ID: 0403
  Device-2: NVIDIA GK107 HDMI Audio vendor: Apple driver: snd_hda_intel
  v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
  Device-3: Apple Thunderbolt Display Audio type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1.4:3 chip-ID: 05ac:1107
  class-ID: 0300 serial: <filter>
  Device-4: Apple Thunderbolt Display Audio type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 4-1.4:3 chip-ID: 05ac:1107
  Device-5: Logitech H600 [Wireless Headset] type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 9-2.3:5 chip-ID: 046d:0a29
  Sound Server-1: ALSA v: k5.11.16-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.26 running: yes
  Device-1: Broadcom NetXtreme BCM57786 Gigabit Ethernet PCIe driver: N/A
  port: 2000 bus-ID: 03:00.0 chip-ID: 14e4:16a3 class-ID: 0200
  Device-2: Broadcom BCM4331 802.11a/b/g/n vendor: Apple AirPort Extreme
  driver: wl v: kernel modules: bcma port: 2000 bus-ID: 04:00.0
  chip-ID: 14e4:4331 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  Device-3: Broadcom NetXtreme BCM57761 Gigabit Ethernet PCIe vendor: Apple
  driver: tg3 v: kernel port: 2000 bus-ID: 0d:00.0 chip-ID: 14e4:16b0
  class-ID: 0200
  IF: enp13s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-4: Broadcom NetXtreme BCM57761 Gigabit Ethernet PCIe vendor: Apple
  driver: tg3 v: kernel port: 2000 bus-ID: 3e:00.0 chip-ID: 14e4:16b0
  class-ID: 0200
  IF: enp62s0 state: down mac: <filter>
  Device-1: Apple Bluetooth Host Controller type: USB driver: btusb v: 0.8
  bus-ID: 2-1.8.1.3:8 chip-ID: 05ac:8286 class-ID: fe01
  Local Storage: total: 8.24 TiB used: 2.43 TiB (29.4%)
  ID-1: /dev/sda maj-min: 8:0 model: Aura Pro S MB258 size: 931.51 GiB
  block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD
  serial: <filter> rev: 6ANR scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: Backup+ Hub BK
  size: 7.28 TiB block-size: physical: 4096 B logical: 512 B serial: <filter>
  rev: D781 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Cruzer Fit
  size: 59.16 GiB block-size: physical: 512 B logical: 512 B serial: <filter>
  rev: 1.00 scheme: MBR
  ID-1: / raw-size: 525.56 GiB size: 516.24 GiB (98.23%)
  used: 41.84 GiB (8.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: 2888ee6c-3156-40cc-ab58-b2efb0745350
  ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.45%)
  used: 8.4 MiB (4.3%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: EFI
  uuid: 67E3-17ED
  ID-3: /run/media/bryank/69850ce5-70e8-4c75-932e-6a9041aec7de
  raw-size: 186.06 GiB size: 182.08 GiB (97.86%) used: 29.61 GiB (16.3%)
  fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
  uuid: 69850ce5-70e8-4c75-932e-6a9041aec7de
  ID-4: /run/media/bryank/Data raw-size: 202.81 GiB size: 198.57 GiB (97.91%)
  used: 31.86 GiB (16.0%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: Data
  uuid: 118bfd46-6603-48f5-b56c-2fd577082f14
  ID-5: /run/media/bryank/Manjaro External raw-size: 933.72 GiB
  size: 918 GiB (98.32%) used: 60 KiB (0.0%) fs: ext4 dev: /dev/sdb3
  maj-min: 8:19 label: Manjaro External
  uuid: c9710831-4d6c-4c5f-b85c-fa6e616c18cb
  ID-6: /run/media/bryank/Seagate 8TB raw-size: 6.37 TiB
  size: 6.37 TiB (100.00%) used: 2.33 TiB (36.6%) fs: hfsplus dev: /dev/sdb2
  maj-min: 8:18 label: Seagate 8TB uuid: 900e39fb-e11f-391c-b3eb-e23951153d08
  ID-1: swap-1 type: partition size: 16.77 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sda5 maj-min: 8:5 label: N/A
  uuid: 2feb6cc8-3860-4730-8947-66bdfab3c1f6
  ID-1: /dev/sda1 maj-min: 8:1 size: 200 MiB fs: vfat label: EFI
  uuid: 67E3-17ED
  ID-2: /dev/sdc1 maj-min: 8:33 size: 2.59 GiB fs: iso9660
  label: MANJARO_GNOME_2101 uuid: 2021-04-10-10-44-02-00
  ID-3: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
  uuid: C29E-F10D
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.1:3 info: Apple FaceTime HD Camera (Built-in) type: Video
  driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Hub-5: 2-1.8:3 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 2 rev: 2.0
  speed: 480 Mb/s power: 2mA chip-ID: 0424:2512 class-ID: 0900
  Hub-6: 2-1.8.1:4
  info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth) ports: 3
  rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
  Device-1: 2-1.8.1.3:8 info: Apple Bluetooth Host Controller type: Bluetooth
  driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 05ac:8286
  class-ID: fe01
  Device-2: 2-1.8.2:5 info: Apple Apple Internal Keyboard / Trackpad
  type: Keyboard,HID,Mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
  speed: 12 Mb/s power: 40mA chip-ID: 05ac:0262 class-ID: 0301
  Hub-7: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Hub-8: 3-1:2 info: Apple Hub in Thunderbolt Display ports: 7 rev: 2.0
  speed: 480 Mb/s power: 100mA chip-ID: 05ac:9127 class-ID: 0900
  Device-1: 3-1.4:3 info: Apple Thunderbolt Display Audio type: Audio,HID
  driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
  speed: 12 Mb/s power: 2mA chip-ID: 05ac:1107 class-ID: 0300 serial: <filter>
  Device-2: 3-1.5:4 info: Apple FaceTime HD Camera (Display) type: Video
  Device-3: 3-1.7:5 info: Apple Thunderbolt Display type: HID
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 2mA
  chip-ID: 05ac:9227 class-ID: 0300 serial: <filter>
  Hub-9: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Hub-10: 4-1:2 info: Apple Hub in Thunderbolt Display ports: 7 rev: 2.0
  Device-1: 4-1.4:3 info: Apple Thunderbolt Display Audio type: Audio,HID
  Device-2: 4-1.5:4 info: Apple FaceTime HD Camera (Display) type: Video
  Device-3: 4-1.7:5 info: Apple Thunderbolt Display type: HID
  Hub-11: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1
  speed: 12 Mb/s chip-ID: 1d6b:0001 class-ID: 0900
  Hub-12: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1
  Hub-13: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1
  Hub-14: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1
  Hub-15: 9-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 9-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
  power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Hub-16: 9-2:3 info: Seagate RSS LLC Backup Plus Hub ports: 3 rev: 2.1
  speed: 480 Mb/s power: 100mA chip-ID: 0bc2:ab44 class-ID: 0900
  Device-1: 9-2.2:4 info: SanDisk Cruzer Fit type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 224mA
  chip-ID: 0781:5571 class-ID: 0806 serial: <filter>
  Device-2: 9-2.3:5 info: Logitech H600 [Wireless Headset] type: Audio,HID
  speed: 12 Mb/s power: 144mA chip-ID: 046d:0a29 class-ID: 0300
  serial: <filter>
  Hub-17: 10-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0
  speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  Hub-18: 10-2:2 info: Seagate RSS LLC Backup+ Hub ports: 3 rev: 3.0
  speed: 5 Gb/s chip-ID: 0bc2:ab45 class-ID: 0900
  Device-1: 10-2.1:3 info: Seagate RSS LLC Backup Plus Hub (Mass Storage)
  type: Mass Storage driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s
  chip-ID: 0bc2:ab38 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 80.0 C mobo: 55.0 C gpu: nouveau temp: 60.0 C
  Processes: 293 Uptime: 9m wakeups: 7 Init: systemd v: 247 tool: systemctl
  Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1418 pacman: 1405 lib: 367
  flatpak: 6 snap: 7 Shell: Bash v: 5.1.0 running-in: yakuake inxi: 3.3.04```
Hi, did you reboot since you’ve installed 5.12 ?
3x’s. As I mentioned, 5.12 is not in the advanced options of Grub to choose. I wouldn’t have known that unless I had rebooted.
Give sudo update-grub and sudo mkinitcpio -P a try, then reboot.
bash: sudo-update-grub: command not found
There is typo. Do sudo update-grub
Installed.
Rebooted, checked Grub
No Joy.
Hmm.
First check if your sys is fully up-to-date:
sudo pacman -Syu
What you could also try is reinstalling the kernel package and post the output here:
sudo pacman -S linux512
This symptom is common when another distro controls the grub menu. The fix in that case is to boot to the host distro and update-grub there.
Ah yeah that makes sense. Didn’t even think about that.
OP didn’t tell, but according to his profile he has a dual manjaro setup it seems.
Ok, I tried sudo pacman -Syu & sudo pacman -S linux512 but still the same. I’m not running 5.12.
FYI, I ran sudo update-grub & sudo mkinitcpio -P in Gnome first and then in KDE.
Please check if os-prober is enabled (I assume that has to be enabled for your setup).
Post output of:
cat /etc/default/grub | grep PROBER
I just found this on another forum. Grub now defaults os-prober as disabled.
[bryank@Manjaro-KDE ~]$ cat /etc/default/grub | grep PROBER GRUB_DISABLE_OS_PROBER=false
On both installs?
Sorry, didn’t check both, just KDE. Give me a minute.
Same output:
FWIW, I reinstalled KDE and now I’m running 5.12.
