Updated to latest 5.10.2 kernel and Manajro Gnome update and now my computer freezes. Keybaord, mouse all dead. Have to use reset button. Tried selecting 5.4 at boot and now that one lost wifi.
How to check what is causing it? Was running 5.10 RC 7 I believe before and it was fine.
[SOLVED] Ignore it now happens on kernel 5.9. Not an kernel issue.
Please, start live ISO and post
inxi -Fxxxza --no-host
mhwd -l
I am attempting to solve it. Another computer would not even boot into 5.10.2 and it turned out nvidia drivers 4.55 were not installed. Installed linux5.10-nvidia4.555xxx driver and now it boots. The nvidia driver was not installed as well on this machine so I installed it. I think this might solve it. Give me a few days to test it. Here is the output from the command line after nvidia installed anyway but just wait because I might have solved it. Will post solved if it works after a few days. You can igonre the output for now.
[marcin@i4930kl ~]$ inxi -Fxxxza --no-host
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64
root=UUID=58189e2c-8a29-40d1-95b7-cbcb181272b1 rw rootflags=subvol=@ quiet
Desktop: GNOME 3.38.2 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: X79-DELUXE v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 4805 date: 02/02/2016
Device-1: hidpp_battery_0 model: Logitech Wireless Solar Keyboard K750
serial: <filter> charge: 100% rechargeable: yes status: Full
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M525
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Info: 6-Core model: Intel Core i7-4930K bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3E (62) stepping: 4 microcode: 42E
L2 cache: 12 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 81680
Speed: 1630 MHz min/max: 1200/3900 MHz Core speeds (MHz): 1: 1630 2: 1718
3: 2736 4: 2122 5: 2271 6: 2073 7: 2070 8: 1799 9: 2718 10: 1702 11: 2250
12: 3096
Type: l1tf
Device-1: NVIDIA GK104 [GeForce GTX 770] vendor: eVga.com. driver: nvidia
v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1184
Display: x11 server: X.Org 1.20.10 compositor: gnome-shell driver: nvidia
display ID: :1 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x572mm (40.0x22.5")
s-diag: 1166mm (45.9")
Monitor-1: DP-1 res: 3840x2160 hz: 60 dpi: 157
size: 621x341mm (24.4x13.4") diag: 708mm (27.9")
OpenGL: renderer: GeForce GTX 770/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: Intel C600/X79 series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1d20
Device-2: NVIDIA GK104 HDMI Audio vendor: eVga.com. driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 10de:0e0a
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 2-1.4:5 chip ID: 046d:0825 serial: <filter>
Sound Server: ALSA v: k5.10.2-2-MANJARO
Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe
driver: e1000e v: kernel port: f040 bus ID: 00:19.0 chip ID: 8086:1503
Device-2: Broadcom BCM4352 802.11ac Wireless Network Adapter
vendor: ASUSTeK driver: wl v: kernel modules: bcma port: d000
bus ID: 09:00.0 chip ID: 14e4:43b1
IF: wlp9s0 state: up mac: <filter>
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK driver: r8168 v: 8.048.03-NAPI modules: r8169 port: b000
bus ID: 0b:00.0 chip ID: 10ec:8168
IF: enp11s0 state: down mac: <filter>
Local Storage: total: 1.86 TiB used: 339.86 GiB (17.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 1TB
size: 931.51 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: BB6Q
ID-2: /dev/sdb maj-min: 8:16 vendor: Intel model: SSDSC2BP480G4
size: 447.13 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 0420
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 500GB
size: 465.76 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 1B6Q
ID-4: /dev/sdf maj-min: 8:80 type: USB vendor: SanDisk model: Ultra
size: 57.28 GiB block size: physical: 512 B logical: 512 B
serial: <filter> rev: 1.00
ID-1: / raw size: 447.03 GiB size: 447.03 GiB (100.00%)
used: 339.75 GiB (76.0%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-2: /boot/efi raw size: 105 MiB size: 103.4 MiB (98.45%)
used: 806 KiB (0.8%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw size: 447.03 GiB size: 447.03 GiB (100.00%)
System Temperatures: cpu: 26.0 C mobo: N/A gpu: nvidia temp: 42 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 42%
Processes: 348 Uptime: 16m wakeups: 8 Memory: 31.3 GiB
used: 2.76 GiB (8.8%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.0 Packages: pacman: 1940 lib: 469 flatpak: 0 Shell: Bash
v: 5.1.0 running in: gnome-terminal inxi: 3.2.01
Here is the output of the other command.
[marcin@i4930kl ~]$ mhwd -l
> 0000:09:00.0 (0200:14e4:43b1) Network controller Broadcom:
NAME VERSION FREEDRIVER TYPE
network-broadcom-wl 2018.10.07 true PCI
> 0000:0b:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
> 0000:01:00.0 (0300:10de:1184) Display controller nVidia Corporation:
video-nvidia 2020.11.30 false PCI
video-nvidia-390xx 2020.11.30 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
So maybe ignore this output for now.
Thanks for your help anyway
Installing the nvidia 4.55 driver which was installed before the update to 5.10.2 seeming the have solved the problem and now system is stable again. Somehow in the update nvidia driver got uninstalled
