So my laptop has a combo jack. It’s usable as a line in, headphone, microphone, headset, any 3.5mm jack. On Linux however, it only works as a headphone jack. How do I make it so I can use it as a headset jack so I can use the earbuds and the mic on my earphones simultaneously? I’ve tried the alsa-base.conf file, didn’t work. I’ve tried running on the latest kernel, didn’t work. I’ve tried hdajackretask, didn’t work. Could really use some help here…
Update: With hdajackretask, pin 0x19 is the pink pin for the microphone recognised by the system. However, when I plug in my earphones, there is nothing picked up by this new microphone option. Also, after this if I unplug the earphones, I can no longer use the laptop’s internal mic and it’s perpetually displayed as unplugged till I restart, and the microphone for that pin is still displayed as plugged in but picks up no volume at all.
and Node 0x19 is not present in !!ALSA/HDA dmesg section.
Only the Internal Mic (Node 0x12) is correctly detected
I suggest you run sudo hdajackretask and then Remove boot override
and try first to get audio working with a kernel modprobe option hdajacksensetest and hdajackretask are good tools for adjusting an audio codec but
do not work well when used at the same time as a modprobe option
Another Manjaro user posted about the same model laptop recently (Aspire E5-573G) 3.5mm input headphone microphone are not working
I could not find a modprobe option for this model but the modprobe option alc255-acer is for the same ALC255 audio codec as Aspire E5-523G and Aspire ES1-432
(This modprobe patch does affect Node 0x19 so you were probably retasking the right pin, but it was not registering the configuration change in alsa-info data)
I suggest you remove the 2 modprobe options index=0 and model=dell-headset-multi from file /etc/modprobe.d/alsa-base.conf and try this model option instead snd_hda_intel model=alc255-acer
