Hi, im new to linux, got the dGpu running with Optirun and Primusrun (no Optimus Manager),
Kernel: 5.4.164-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.4-x86_64
root=UUID=1a7c5ff1-f63c-4fcc-9922-2df9fea7fdfc rw rootflags=subvol=@ quiet
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: K73SV v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: K73SV v: 1.0 serial: <superuser required>
BIOS: American Megatrends v: K73SV.207 date: 07/01/2011
RAM: total: 7.68 GiB used: 3.1 GiB (40.3%)
RAM Report:
Info: model: Intel Core i5-2410M bits: 64 type: MT MCP arch: Sandy Bridge
family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1945 high: 2552 min/max: 800/2900 scaling:
driver: intel_pstate governor: powersave cores: 1: 1554 2: 1822 3: 1854
4: 2552 bogomips: 18364
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good
sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0116
class-ID: 0300
Device-2: NVIDIA GF108M [GeForce GT 540M] driver: N/A
alternate: nouveau, nvidia_drm, nvidia bus-ID: 01:00.0 chip-ID: 10de:0df4
class-ID: 0300
Device-3: IMC Networks UVC VGA Webcam type: USB driver: uvcvideo
bus-ID: 1-1.2:3 chip-ID: 13d3:5710 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: intel display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
s-diag: 485mm (19.1")
Monitor-1: LVDS1 res: 1600x900 hz: 60 dpi: 107 size: 380x210mm (15.0x8.3")
diag: 434mm (17.1")
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2)
v: 3.3 Mesa 21.2.5 compat-v: 3.0 direct render: Yes
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
Sound Server-1: ALSA v: k5.4.164-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Ralink RT5390 Wireless 802.11n 1T/1R PCIe vendor: AzureWave
driver: rt2800pci v: 2.3.0 bus-ID: 03:00.0 chip-ID: 1814:5390 class-ID: 0280
Device-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: ASUSTeK
driver: atl1c v: 1.0.1.1-NAPI port: a000 bus-ID: 04:00.0 chip-ID: 1969:1083
class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 465.76 GiB used: 131.32 GiB (28.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9500325AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GT34N rev: AS00
dev-links: cdrom
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 131.32 GiB (28.2%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 1a7c5ff1-f63c-4fcc-9922-2df9fea7fdfc
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-3: /run/timeshift/backup raw-size: 465.76 GiB
size: 465.76 GiB (100.00%) used: 131.32 GiB (28.2%) fs: btrfs dev: /dev/sda1
maj-min: 8:1 label: N/A uuid: 1a7c5ff1-f63c-4fcc-9922-2df9fea7fdfc
ID-4: /var/cache raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-5: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.2:3 info: IMC Networks UVC VGA Webcam type: Video
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Device-1: 2-1.1:3 info: GreenAsia 2.4G RX type: Keyboard,Mouse
power: 100mA chip-ID: 0e8f:00a8 class-ID: 0301
System Temperatures: cpu: 67.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3000
Processes: 241 Uptime: 2h 43m wakeups: 1 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1431 pacman: 1415 lib: 388
flatpak: 9 snap: 7 Shell: Zsh v: 5.8 default: fish v: 3.3.1
running-in: konsole inxi: 3.3.11
now i just want to install a single Game with Lutris. but no luck.
i installed
sudo pacman -Syu wine-staging winetricks wine-mono wine_gecko vulkan-icd-loader lib32-vulkan-icd-loader vkd3d lib32-vkd3d gvfs
and
sudo pacman -S lutris
when i
optirun lutris
i get: Your NVIDIA driver is outdated. you are currently running driver 390.144 wich does not fully support all features for Vulkan and DXVK games.
primusrun lutris
doesnt work at all.
and starting just lutris opens it without an error message.
Now i click Add new Game
Give it a Name/ Runner=Wine/Executable=path to the instal.exe/ Wineprefix= New folder in GamesFolder
Wine version = System(6.23(Staging))
Disable DXVK VKD3D Esync
Use discrete graphics =disabled
i save and run the new game First Wine starts after that the installer.
now if i change the exe to the installed game and run nothing happens.
lutris-wrapper: Isaac 1.0
Started initial process 15800 from /usr/bin/wine /home/jakob/Games/Isaac1.0/drive_c/GOG Games/The Binding of Isaac Rebirth/isaac-ng_repentance.exe
Start monitoring process.
Xlib: extension "NV-GLX" missing on display ":0".
Monitored process exited.
Initial process has exited (return code: 13568)
Exit with return code 13568
when i turn on Optimus launcher (Nvidia Optimus laptops)= optirun/virtualgl
Started initial process 15976 from optirun -b virtualgl /usr/bin/wine /home/jakob/Games/Isaac1.0/drive_c/GOG Games/The Binding of Isaac Rebirth/isaac-ng_repentance.exe
ERROR: ld.so: object 'libdlfaker.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
ERROR: ld.so: object 'libvglfaker.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 154 (GLX)
Minor opcode of failed request: 7 (X_GLXQueryVersion)
Value in failed request: 0x17
Serial number of failed request: 9
Current serial number in output stream: 9
wine: Unhandled page fault on execute access to 00007F69BB14D880 at address 00007F69BB14D880 (thread 0080), starting debugger...
Any Help appreciated
