3 monitors kwin flicker when opening apps
So whenever i open up Steam or Chatty i get this background black flicker on my main monitor sometimes. I wonder what is the issue here?
I tried taking a screenshot of it, but couldn’t capture it.
It started doing that after recent updates. Probably not the last big update, but the one before that. Though maybe it has only started appearing when ive added a third monitor.
I tried it with two monitors as well without the added monitor. Still does the black flickering. I wonder if this is related to the recent mesa updates?
Are you using X11 or Wayland?
Actually, rather than a 100 questions, please provide system information as described (below).
I’m sure someone will help when they are able.
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Technical Resources
  Kernel: 6.12.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=f10c80c3-7da1-4392-94e8-e7d116d6fa84 rw quiet splash
    udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
  Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.13.0
  Type: Desktop Mobo: Gigabyte model: B550 AORUS PRO V2
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: F17 date: 03/22/2024
  System RAM: total: 16 GiB available: 15.52 GiB used: 3.77 GiB (24.3%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 3600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Crucial
    part-no: BL8G36C16U4B.M8FE1 serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA20102D
    desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 4590 high: 4591 min/max: N/A cores: 1: 4591 2: 4591
    3: 4591 4: 4591 5: 4591 6: 4591 7: 4591 8: 4591 9: 4591 10: 4591 11: 4591
    12: 4589 bogomips: 110236
    stibp succor svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
    v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
    wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6600/6600
    XT/6600M] vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2
    code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-2,DP-3,HDMI-A-1
    empty: DP-1,Writeback-1 bus-ID: 07:00.0 chip-ID: 1002:73ff class-ID: 0300
  Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6.2:6
    chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu d-rect: 7440x4290 display-ID: 0
  Monitor-1: DP-2 pos: bottom-r model: 32W_LCD_TV built: 2015 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 69 gamma: 1.2 chroma: red:
    x: 0.643 y: 0.329 green: x: 0.282 y: 0.604 blue: x: 0.145 y: 0.059 white:
    x: 0.290 y: 0.298 size: 708x398mm (27.87x15.67") diag: 810mm (31.9")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1360x768,
    1280x800, 1280x768, 1280x720, 1024x768, 800x600, 720x576, 720x480,
    640x480
  Monitor-2: DP-3 pos: top-center model: HISENSE serial: <filter>
    built: 2023 res: mode: 3840x2160 hz: 60 scale: 165% (1.65) to: 2327x1309
    dpi: 85 gamma: 1.2 chroma: red: x: 0.639 y: 0.341 green: x: 0.298 y: 0.690
    blue: x: 0.137 y: 0.035 white: x: 0.282 y: 0.298
    size: 1095x616mm (43.11x24.25") diag: 1321mm (52") ratio: 16:9
    modes: 3840x2160, 4096x2160, 1920x1080, 1280x1024, 1280x960, 1280x720,
    1024x768, 800x600, 720x576, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 94 3: parse_edid: unhandled CEA mode 95 4: parse_edid:
    unhandled CEA mode 96 5: parse_edid: unhandled CEA mode 93 6: parse_edid:
    unhandled CEA mode 106 7: parse_edid: unhandled CEA mode 107 8: parse_edid:
    unhandled CEA mode 101 9: parse_edid: unhandled CEA mode 102
    10: parse_edid: unhandled CEA mode 98 11: parse_edid: unhandled CEA mode
    99 12: parse_edid: unhandled CEA mode 100
  Monitor-3: HDMI-A-1 pos: middle-l model: Samsung SyncMaster
    serial: <filter> built: 2007 res: mode: 1680x1050 hz: 60 scale: 100% (1)
    dpi: 86 gamma: 1.2 chroma: red: x: 0.639 y: 0.333 green: x: 0.290 y: 0.596
    blue: x: 0.153 y: 0.082 white: x: 0.314 y: 0.329
    size: 494x320mm (19.45x12.6") diag: 589mm (23.2") ratio: 3:2
    modes: 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800, 1152x864,
    1280x720, 1024x768, 832x624, 800x600, 640x480, 720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23
    LLVM 19.1.7 DRM 3.61 6.12.25-1-MANJARO) device-ID: 1002:73ff
    memory: 7.81 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.309 layers: 6 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 25.0.4-arch1.1
    device-ID: 1002:73ff surfaces: xcb,xlib,wayland
    de: kscreen-console,kscreen-doctor gpu: corectrl wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 07:00.1 chip-ID: 1002:ab28 class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
  Device-4: Logitech Logitech USB Microphone driver: snd-usb-audio type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:7 chip-ID: 046d:0a03
    class-ID: 0102
  API: ALSA v: k6.12.25-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.2 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
  Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
  IF-ID-1: enp9s0f3u2 state: unknown speed: -1 duplex: half mac: <filter>
  Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6.3:8 chip-ID: 2357:0604
  Device-2: Broadcom BCM20702A0 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6.4:10
    chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
  Report: ID: hci1 rfk-id: 1 state: up address: N/A
  Device-3: OPPO OnePlus 8T driver: rndis_host v: kernel type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:5 chip-ID: 22d9:276a
    class-ID: 0a00 serial: <filter>
  Local Storage: total: 1.64 TiB used: 1.05 TiB (63.9%)
    model: WDS100T1X0E-00AFY0 size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 614900WD temp: 40.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: B1H5 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD5000AZRX-00A8LB0 size: 465.76 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1A01
    scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Transcend model: JetFlash 64GB
    size: 58.84 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
    fw-rev: 1100 scheme: MBR
  ID-1: / raw-size: 223.27 GiB size: 218.71 GiB (97.96%)
    used: 175.6 GiB (80.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: f10c80c3-7da1-4392-94e8-e7d116d6fa84
  ID-2: /bup raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
    used: 316.25 GiB (69.1%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
    uuid: 502bbdd6-926c-4252-9279-a96fd9c30d08
  ID-3: /efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 292 KiB (0.1%)
    fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A uuid: 1CE8-FAE8
  ID-4: /gms raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
    used: 582.14 GiB (63.6%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: d6e0de73-c9d8-4ac0-96ea-482f53507c91
  ID-1: /dev/sdc1 maj-min: 8:33 size: 2.74 GiB fs: iso9660
  ID-2: /dev/sdc2 maj-min: 8:34 size: 4.3 MiB fs: vfat label: N/A
    uuid: 9AAE-944A
  ID-3: /dev/sdc3 maj-min: 8:35 size: 56.1 GiB fs: ext4 label: writable
    uuid: 27661ad4-24e2-42d3-b6ee-754cb460bb10
  Hub-2: 1-6:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-6.1:4 info: SiGma Micro Keyboard TRACER Gamma Ivory
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 1c4f:0002 class-ID: 0300
  Device-2: 1-6.2:6 info: Logitech Webcam C270 type: video,audio
  Device-3: 1-6.3:8 info: TP-Link UB500 Adapter type: bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 2357:0604 class-ID: e001 serial: <filter>
  Device-4: 1-6.4:10 info: Broadcom BCM20702A0 Bluetooth 4.0 type: Bluetooth
    driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
  Device-5: 1-7:3 info: Integrated Express RGB LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-6: 1-8:5 info: Pixart Imaging Optical Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 093a:2521 class-ID: 0301
  Device-7: 1-9:7 info: Logitech Logitech USB Microphone type: audio
    driver: snd-usb-audio interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 60mA chip-ID: 046d:0a03 class-ID: 0102
  Hub-3: 1-10:9 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Device-1: 2-4:4 info: Transcend Information JetFlash type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 304mA chip-ID: 8564:1000 class-ID: 0806
    serial: <filter>
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-2:5 info: OPPO OnePlus 8T type: bluetooth,CDC-data
    driver: rndis_host interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 22d9:276a class-ID: 0a00
    serial: <filter>
  Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 47.2 C mobo: N/A gpu: amdgpu temp: 54.0 C
    mem: 60.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: 1578 pm: pacman pkgs: 1504 libs: 420 tools: pamac pm: flatpak
    pkgs: 74
    1: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    2: https://mirror.init7.net/manjaro/stable/$repo/$arch
    3: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    6: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    7: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 325
  1: cpu: 7.2% command: librewolf pid: 2365 mem: 590.5 MiB (3.7%)
  2: cpu: 6.5% command: librewolf pid: 2731 mem: 528.8 MiB (3.3%)
  3: cpu: 5.2% command: konsole pid: 3703 mem: 205.5 MiB (1.2%)
  4: cpu: 4.3% command: librewolf pid: 2892 mem: 447.3 MiB (2.8%)
  5: cpu: 3.8% command: pulseaudio pid: 1340 mem: 43.5 MiB (0.2%)
  Memory top: 5 of 325
  1: mem: 593.1 MiB (3.7%) command: plasmashell pid: 1453 cpu: 1.8%
  2: mem: 590.5 MiB (3.7%) command: librewolf pid: 2365 cpu: 7.2%
  3: mem: 528.8 MiB (3.3%) command: librewolf pid: 2731 cpu: 6.5%
  4: mem: 447.3 MiB (2.8%) command: librewolf pid: 2892 cpu: 4.3%
  5: mem: 304.1 MiB (1.9%) command: kwin_wayland pid: 1196 cpu: 1.4%
  Processes: 325 Power: uptime: 7m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.38
