3.5mm input headphone microphone are not working
This problem has been happening on my notebook for a few months, I believe it may be an error with the kernel, as recently I went to do a new installation of the manjaro and in its live version before the installation the microphone of my headset worked perfectly. The problem is not in the audio stage or in the entrance I believe, because when I use windows everything works correctly.
I don’t know how to apply patch patches in the kernel because I’m still a beginner, and I don’t even know if that’s the problem.
Anyway, if anyone can help me I appreciate it very much.
inxi -Fxxxz
System:    Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A Desktop: KDE Plasma 5.19.5
           tk: Qt 5.15.1 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: Acer product: Aspire E5-573G v: V3.72 serial: <filter>
           Mobo: Acer model: ZORO_BH v: Type2 - A01 Board Version serial: <filter>
           UEFI [Legacy]: Insyde v: 1.37 date: 02/16/2016
Battery:   ID-1: BAT1 charge: 20.5 Wh condition: 20.5/37.0 Wh (55%) volts: 17.1/14.8
           model: SANYO AL15A32 type: Li-ion serial: <filter> status: Full
CPU:       Topology: Dual Core model: Intel Core i7-5500U bits: 64 type: MT MCP
           arch: Broadwell rev: 4 L2 cache: 4096 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19204
           Speed: 2515 MHz min/max: 500/3000 MHz Core speeds (MHz): 1: 2436 2: 2597 3: 2638
           4: 2531
Graphics:  Device-1: Intel HD Graphics 5500 vendor: Acer Incorporated ALI driver: i915
           v: kernel bus ID: 00:02.0 chip ID: 8086:1616
           Device-2: NVIDIA GK208BM [GeForce 920M] vendor: Acer Incorporated ALI
           driver: nouveau v: kernel bus ID: 04:00.0 chip ID: 10de:1299
           Device-3: Sunplus Innovation HD WebCam type: USB driver: uvcvideo bus ID: 2-7:5
           chip ID: 1bcf:2c81
           Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: intel,nouveau
           unloaded: modesetting alternate: fbdev,nv,vesa resolution: 1: 1366x768~60Hz
           2: 1600x900~60Hz s-dpi: 96
           OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 20.1.8
           direct render: Yes
Audio:     Device-1: Intel Broadwell-U Audio vendor: Acer Incorporated ALI
           driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:160c
           Device-2: Intel Wildcat Point-LP High Definition Audio
           vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus ID: 00:1b.0
           chip ID: 8086:9ca0
           Device-3: NVIDIA GK208 HDMI/DP Audio vendor: Acer Incorporated ALI
           driver: snd_hda_intel v: kernel bus ID: 04:00.1 chip ID: 10de:0e0f
           Sound Server: ALSA v: k5.8.16-2-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
           vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 4000 bus ID: 02:00.0
           chip ID: 10ec:8168
           Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
           vendor: Lite-On driver: ath9k v: kernel port: 4000 bus ID: 03:00.0
           chip ID: 168c:0036
           IF-ID-1: br-175970ab46d9 state: down mac: <filter>
           IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
           IF-ID-3: veth369a484 state: up speed: 10000 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 476.95 GiB used: 253.38 GiB (53.1%)
           ID-1: /dev/sda vendor: Lexar model: 256GB SSD size: 238.47 GiB speed: 6.0 Gb/s
           serial: <filter> rev: 117H scheme: MBR
           ID-2: /dev/sdb vendor: Lexar model: 256GB SSD size: 238.47 GiB speed: 6.0 Gb/s
           serial: <filter> rev: 117H scheme: GPT
Partition: ID-1: / size: 49.25 GiB used: 17.81 GiB (36.2%) fs: ext4 dev: /dev/sdb1
           ID-2: /home size: 184.22 GiB used: 27.09 GiB (14.7%) fs: ext4 dev: /dev/sdb2
Swap:      Alert: No Swap data was found.
Sensors:   System Temperatures: cpu: 82.0 C mobo: N/A gpu: nouveau temp: 77 C
Info:      Processes: 285 Uptime: 10h 57m Memory: 15.56 GiB used: 6.08 GiB (39.1%)
           Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1332 pacman: 1327 snap: 5
           Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
pacmd list-cards
2 card(s) available.
    index: 0
        driver: <module-alsa-card.c>
        owner module: 6
        properties:
                alsa.card = "0"
                alsa.card_name = "HDA Intel HDMI"
                alsa.long_card_name = "HDA Intel HDMI at 0xc4310000 irq 52"
                device.bus_path = "pci-0000:00:03.0"
                sysfs.path = "/devices/pci0000:00/0000:00:03.0/sound/card0"
                device.bus = "pci"
                device.vendor.id = "8086"
                device.product.id = "160c"
                device.product.name = "Broadwell-U Audio Controller"
                device.string = "0"
                device.description = "Áudio interno"
                module-udev-detect.discovered = "1"
                device.icon_name = "audio-card-pci"
        profiles:
                output:hdmi-stereo: Saída de Digital Stereo (HDMI) (priority 5900, available: no)
                output:hdmi-surround: Saída de Digital Surround 5.1 (HDMI) (priority 800, available: no)
                output:hdmi-surround71: Saída de Digital Surround 7.1 (HDMI) (priority 800, available: no)
                output:hdmi-stereo-extra1: Saída de Digital Stereo (HDMI 2) (priority 5700, available: no)
                output:hdmi-surround-extra1: Saída de Digital Surround 5.1 (HDMI 2) (priority 600, available: no)
                output:hdmi-surround71-extra1: Saída de Digital Surround 7.1 (HDMI 2) (priority 600, available: no)
                output:hdmi-stereo-extra2: Saída de Digital Stereo (HDMI 3) (priority 5700, available: no)
                output:hdmi-surround-extra2: Saída de Digital Surround 5.1 (HDMI 3) (priority 600, available: no)
                output:hdmi-surround71-extra2: Saída de Digital Surround 7.1 (HDMI 3) (priority 600, available: no)
                output:hdmi-stereo-extra3: Saída de Digital Stereo (HDMI 4) (priority 5700, available: no)
                output:hdmi-surround-extra3: Saída de Digital Surround 5.1 (HDMI 4) (priority 600, available: no)
                output:hdmi-surround71-extra3: Saída de Digital Surround 7.1 (HDMI 4) (priority 600, available: no)
                output:hdmi-stereo-extra4: Saída de Digital Stereo (HDMI 5) (priority 5700, available: no)
                output:hdmi-surround-extra4: Saída de Digital Surround 5.1 (HDMI 5) (priority 600, available: no)
                output:hdmi-surround71-extra4: Saída de Digital Surround 7.1 (HDMI 5) (priority 600, available: no)
                off: Desligado (priority 0, available: unknown)
        active profile: <off>
        ports:
                hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
                        properties:
                hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
                        properties:
                hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
                        properties:
                hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
                        properties:
                hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
                        properties:
    index: 1
        owner module: 7
        properties:
                alsa.card = "1"
                alsa.long_card_name = "HDA Intel PCH at 0xc4314000 irq 50"
                device.bus_path = "pci-0000:00:1b.0"
                sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card1"
                device.bus = "pci"
                device.product.id = "9ca0"
                device.product.name = "Wildcat Point-LP High Definition Audio Controller"
                device.string = "1"
        profiles:
                input:analog-stereo: Entrada de Estéreo analógico (priority 65, available: unknown)
                output:analog-stereo: Saída de Estéreo analógico (priority 6500, available: unknown)
                output:analog-stereo+input:analog-stereo: Duplex estéreo analógico (priority 6565, available: unknown)
        active profile: <output:analog-stereo+input:analog-stereo>
        sinks:
                alsa_output.pci-0000_00_1b.0.analog-stereo/#0: Áudio interno Estéreo analógico
        sources:
                alsa_output.pci-0000_00_1b.0.analog-stereo.monitor/#0: Monitor of Áudio interno Estéreo analógico
                alsa_input.pci-0000_00_1b.0.analog-stereo/#1: Áudio interno Estéreo analógico
        ports:
                analog-input-mic: Microfone (priority 8700, latency offset 0 usec, available: unknown)
                        properties:
                analog-output-speaker: Alto-falantes (priority 10000, latency offset 0 usec, available: no)
                        properties:
                analog-output-headphones: Fones de ouvido (priority 9900, latency offset 0 usec, available: yes)
                        properties:
