Hey All,
I recently updated my driver to be the NVIDIA proprietary so I could record on OBS using the NVIDIA GPU and since then I now have no output on my external HDMI connector.
I am running stable with gnome
dGPU is RTX 4070
Any help would be very much appreciated.
Kr
Matt
Kernel: 6.12.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=9ba43569-b10b-4c41-a90f-051f14fa9a46 rw quiet splash apparmor=1
security=apparmor resume=UUID=30363541-2e41-4e91-9ef4-c19162d85345
udev.log_priority=3
Desktop: GNOME v: 47.5 tk: GTK v: 3.24.49 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: Razer product: Blade 14 - RZ09-0482 v: 9.04
Mobo: N/A model: PI490 v: 4 serial: <superuser required>
part-nu: RZ09-0482XWH3 uuid: <superuser required> UEFI: Razer v: 2.02
date: 12/12/2023
ID-1: BAT0 charge: 27.7 Wh (42.5%) condition: 65.2/68.1 Wh (95.8%)
volts: 15.5 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
status: charging cycles: 43
System RAM: total: 16 GiB available: 14.84 GiB used: 4.89 GiB (32.9%)
Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 5600 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Hynix
part-no: HMCG66AGBSA092N serial: <filter>
Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 9 7940HS w/ Radeon 780M Graphics bits: 64
type: MT MCP arch: Zen 4 gen: 4 level: v4 note: check built: 2022+
process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x74 (116) stepping: 1
microcode: 0xA704107
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1097 min/max: 400/5263 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1097 2: 1097 3: 1097
4: 1097 5: 1097 6: 1097 7: 1097 8: 1097 9: 1097 10: 1097 11: 1097 12: 1097
13: 1097 14: 1097 15: 1097 16: 1097 bogomips: 127798
apic arat avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero
cmov cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local
cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fxsr
fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean
vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves xtopology
conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
BHI: Not affected
Device-1: NVIDIA AD106M [GeForce RTX 4070 Max-Q / Mobile] vendor: Razer USA
driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
non-free: 550/565.xx+ status: current (as of 2025-01) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 10de:2820 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: Razer USA
driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2
off: eDP-1 empty: DP-1, DP-3, DP-4, DP-5, DP-6, Writeback-1
bus-ID: 65:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 41.0 C
Device-3: IMC Networks Integrated RGB Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 13d3:5279
Display: x11 server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
dri: radeonsi gpu: amdgpu display-ID: :1 note: <missing: xdpyinfo/xrandr>
Monitor-1: DP-2 model: Huawei ZQE-CBA serial: <filter> built: 2022
res: 3440x1440 dpi: 110 gamma: 1.2 chroma: red: x: 0.675 y: 0.314 green:
x: 0.278 y: 0.643 blue: x: 0.149 y: 0.067 white: x: 0.314 y: 0.329
size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: 3440x1440,
2560x1440, 2580x1080, 2560x1080, 1920x1200, 1920x1080, 1600x1200,
1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800, 1152x864, 1280x720,
1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 90
Monitor-2: eDP-1 model: TL140ADXP04-0 built: 2022 res: 2560x1600 dpi: 216
gamma: 1.2 chroma: red: x: 0.682 y: 0.322 green: x: 0.263 y: 0.690 blue:
x: 0.149 y: 0.059 white: x: 0.314 y: 0.329 size: 301x188mm (11.85x7.4")
diag: 355mm (14") ratio: 16:10 modes: 2560x1600, 1920x1200, 1920x1080,
1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768,
800x600, 640x480
EDID-Warnings: 1: parse_edid: unknown flag 16 2: parse_edid: unknown tag
112
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: radeonsi
inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M (radeonsi
gfx1103_r1 LLVM 19.1.7 DRM 3.61 6.12.19-1-MANJARO) device-ID: 1002:15bf
memory: 500 MiB unified: no
Info: Tools: api: eglinfo,glxinfo de: kscreen-doctor
gpu: nvidia-settings,nvidia-smi x11: xprop
Device-1: NVIDIA AD106M High Definition Audio vendor: Razer USA
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
bus-ID: 01:00.1 chip-ID: 10de:22bd class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
Definition Audio vendor: Razer USA driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 65:00.1 chip-ID: 1002:1640
class-ID: 0403
Device-3: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Razer USA driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 65:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
vendor: Razer USA driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 65:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-5: KTMicro KT_USB_AUDIO driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-1.1.1:5
chip-ID: 31b2:0011 class-ID: 0300 serial: <filter>
API: ALSA v: k6.12.19-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
Device-1: Qualcomm QCNFA765 Wireless Network Adapter vendor: Lite-On
driver: ath11k_pci v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 link-max:
gen: 3 speed: 8 GT/s bus-ID: 03:00.0 chip-ID: 17cb:1103 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 8-1.2:4
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp103s0f4u1u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: zt6ntkuyt2 state: unknown speed: 10000 Mbps duplex: full
mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
Device-1: Lite-On driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 04ca:3a24 class-ID: e001
Local Storage: total: 1.82 TiB used: 29.63 GiB (1.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 33.9 C
scheme: GPT
ID-1: / raw-size: 1.8 TiB size: 1.77 TiB (98.37%) used: 29.63 GiB (1.6%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 9ba43569-b10b-4c41-a90f-051f14fa9a46
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: A3E0-861E
ID-1: swap-1 type: partition size: 16.33 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 30363541-2e41-4e91-9ef4-c19162d85345
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
Device-1: 1-4:2 info: Razer USA Blade type: keyboard,mouse
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:029d class-ID: 0300
Device-2: 1-5:3 info: Lite-On type: bluetooth driver: btusb interfaces: 2
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 3-1:2 info: IMC Networks Integrated RGB Camera type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:5279 class-ID: 0e02
serial: <filter>
Hub-4: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-8: 7-1:2 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
Hub-9: 7-1.1:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 7-1.1.1:5 info: KTMicro KT_USB_AUDIO type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
Hub-10: 7-1.1.4:6 info: Realtek RTS5411 Hub ports: 5 rev: 2.1
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 7-1.1.4.1:7 info: SONIX USB DEVICE type: keyboard,mouse
lanes: 1 mode: 1.1 power: 400mA chip-ID: 320f:5064 class-ID: 0301
Device-2: 7-1.1.4.2:8 info: SINOWEALTH Wired Gaming Mouse
type: mouse,keyboard driver: glorious,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 480mA
chip-ID: 258a:0033 class-ID: 0301
Device-3: 7-1.5:4 info: Anker Innovations USB C Hub HN type: billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 100mA chip-ID: 291a:8385 class-ID: 1100 serial: <filter>
Hub-11: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-12: 8-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
Hub-13: 8-1.1:3 info: Realtek Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 96mA
chip-ID: 0bda:0411 class-ID: 0900
Device-1: 8-1.2:4 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 184mA
Device-2: 8-1.3:5 info: Genesys Logic SD Card Reader and Writer
type: mass storage driver: usb-storage interfaces: 1 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
chip-ID: 05e3:0749 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 42.9 C mobo: 41.8 C gpu: amdgpu temp: 41.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1556 libs: 391 tools: gnome-software,pamac
pm: flatpak pkgs: 0
1: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
3: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
4: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
6: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
7: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
8: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
9: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
10: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
11: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
12: https://mirror.koddos.net/manjaro/stable/$repo/$arch
13: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
14: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
15: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
16: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
17: https://mirror.init7.net/manjaro/stable/$repo/$arch
18: https://mirror.easyname.at/manjaro/stable/$repo/$arch
19: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
20: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
21: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
22: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
23: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
24: https://linorg.usp.br/manjaro/stable/$repo/$arch
25: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
26: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
27: http://mirror.fcix.net/manjaro/stable/$repo/$arch
28: https://mirrors2.manjaro.org/stable/$repo/$arch
29: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
30: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
31: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
32: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
33: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
34: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
35: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
36: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
37: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
38: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
39: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
40: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
41: https://mirror.23m.com/manjaro/stable/$repo/$arch
42: https://muug.ca/mirror/manjaro/stable/$repo/$arch
43: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
44: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
45: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
46: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
47: https://mirrors.manjaro.org/repo/stable/$repo/$arch
48: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
49: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
50: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
51: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
52: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
53: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
54: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
55: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
56: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
57: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
58: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
59: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
60: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
61: https://manjaro.ynh.ovh/stable/$repo/$arch
62: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
63: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
64: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
65: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
66: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
67: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
68: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
69: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
70: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
71: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
72: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
73: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
74: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
75: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
76: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
77: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
78: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
79: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
80: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
81: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
82: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
83: https://mirror.dc.uz/manjaro/stable/$repo/$arch
84: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
85: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
86: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
87: https://mirror.zetup.net/manjaro/stable/$repo/$arch
88: https://manjaro.kurdy.org/stable/$repo/$arch
89: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
90: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
91: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
92: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
93: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
94: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
95: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
96: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
97: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
98: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
99: http://manjaro.grena.ge/stable/$repo/$arch
100: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
101: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
102: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
103: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
104: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
105: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
106: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
107: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
108: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 409
1: cpu: 12.4% command: firefox pid: 5910 mem: 730.4 MiB (4.8%)
2: cpu: 5.6% command: firefox pid: 6484 mem: 312.1 MiB (2.0%)
3: cpu: 5.1% command: gnome-shell pid: 3979 mem: 360.1 MiB (2.3%)
4: cpu: 3.4% command: Xorg pid: 3859 mem: 262.2 MiB (1.7%)
5: cpu: 0.6% command: thunderbird pid: 6639 mem: 565.1 MiB (3.7%)
Memory top: 5 of 409
1: mem: 730.4 MiB (4.8%) command: firefox pid: 5910 cpu: 12.4%
2: mem: 565.1 MiB (3.7%) command: thunderbird pid: 6639 cpu: 0.6%
3: mem: 360.1 MiB (2.3%) command: gnome-shell pid: 3979 cpu: 5.1%
4: mem: 312.1 MiB (2.0%) command: firefox pid: 6484 cpu: 5.6%
5: mem: 290.6 MiB (1.9%) command: xdg-desktop-portal-gnome pid: 4519
cpu: 0.4%
Processes: 409 Power: uptime: 31m states: freeze,mem,disk suspend: s2idle
wakeups: 1 hibernate: platform avail: shutdown, reboot, suspend, test_resume
image: 5.9 GiB services: gsd-power, power-profiles-daemon, upowerd
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
running-in: gnome-terminal inxi: 3.3.37
Currently running: 6.12.19-1-MANJARO (linux612)
* linux612
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2024.05.06 true PCI
video-hybrid-amd-nvidia-prime 2023.03.23 false PCI
