Pamac says that all package links return 404. I’ve tested with a direct access and the url page is the same 404.
What happened?
What happened?
please try this first, open a console and run this 3 commands also check in pamac, there is a option to update the database, do this also
sudo pacman -Scc
sudo pacman-mirrors -f5
sudo pacman -Syyu
