My laptop (Lenovo ideapad pro 14ACN6) is a lot hotter to the touch, than in windows during the same medium load (browsing, media consumption in a dual-monitor setup), even though the sensor temps are basically the same, when I run manjaro it hurts to touch the chassis and in windows it’s just mildly warm. I already tried thermald for example, but it didn’t make a difference.
Any help is appreciated.
sudo inxi -Fza
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=7098fdc5-760c-4862-91b7-5abd93de2d49 rw quiet apparmor=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 82L7 v: IdeaPad 5 Pro 14ACN6
serial: <filter> Chassis: type: 10 v: IdeaPad 5 Pro 14ACN6 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <filter> UEFI: LENOVO
v: GECN31WW(V1.15) date: 06/24/2022
ID-1: BAT1 charge: 31.5 Wh (55.1%) condition: 57.2/56.5 Wh (101.2%)
volts: 11.7 min: 11.5 model: 0x53 0x75 0x6E 0x77 0x6F 0x64 0x 0x4C 0x32
0x30 0x44 0x33 0x50 0x5650 type: Li-ion serial: <filter> status: N/A
cycles: 7
Info: model: AMD Ryzen 5 5600U with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 3 gen: 4 built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA50000D
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1891 high: 2300 min/max: 1600/4288 boost: enabled
base/boost: 2300/4250 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1600 2: 1600 3: 1600 4: 1600
5: 1600 6: 2300 7: 2300 8: 1600 9: 2300 10: 2300 11: 1600 12: 2300
bogomips: 55125
prctl and seccomp
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5.1
code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: HDMI-A-1,eDP-1 empty: DP-1,DP-2 bus-ID: 04:00.0
chip-ID: 1002:1638 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 04f2:b6be class-ID: fe01 serial: <filter>
Display: x11 server: X. Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver:
X: loaded: amdgpu gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 6720x2160 s-dpi: 96 s-size: 1778x572mm (70.00x22.52")
s-diag: 1868mm (73.53")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: top-right model: VG245
serial: <filter> built: 2016 res: 3840x2160 hz: 60 dpi: 184 gamma: 1.2
size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: primary,bottom-l model-id: CSO 0x1402
built: 2020 res: 2880x1800 hz: 90 dpi: 242 gamma: 1.2
size: 302x188mm (11.89x7.4") diag: 356mm (14") ratio: 16:10 modes:
max: 2880x1800 min: 640x480
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,snd_pci_acp5x
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:003e class-ID: 0280
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 3-4:3 chip-ID: 0cf3:e300 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 953.87 GiB used: 62.56 GiB (6.6%)
model: MZVLB1T0HBLR-000L2 size: 953.87 GiB block-size: physical: 512 B
rev: 3L1QEXF7 temp: 49.9 C scheme: GPT
SMART: yes health: PASSED on: 4d 7h cycles: 738 read-units: 3,332,213
[1.70 TB] written-units: 2,829,890 [1.44 TB]
ID-1: / raw-size: 125 GiB size: 122.48 GiB (97.98%) used: 62.53 GiB (51.1%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 27.6 MiB
(28.7%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 77.5 C mobo: N/A gpu: amdgpu temp: 74.0 C
Processes: 322 Uptime: 6h 31m wakeups: 11153 Memory: 13.51 GiB used: 4.77
GiB (35.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 alt: 11 clang: 14.0.6 Packages: pacman: 1183
lib: 332 flatpak: 0 Shell: Bash (sudo) v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.20
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
