Hi, I have been a Manjaro user for years on my 2013 Macbook Air. I have done multiple installs and generally love Manjaro more than any other OS I’ve used. However through it all, I’ve always had issues with resume from sleep/suspend. I’ve tried multiple things through the years based on forum posts on this forum and others, but to no avail! Recently life has become busy and I’ve needed to go back to mac OS for that easy resume (in recent months I often had to reboot to get back to the desktop), but I miss Manjaro deeply and would like to go back. And then I realized I’d never posted the query on this forum! Does anyone else have the same computer? Have you gotten past that issue? Could someone help me solve it? I’m sure I’m missing something obvious! I’d love to get a few more years of good life out of this laptop before upgrading! Thanks in advance!
Welcome to Manjaro!
- Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
- Please press the three dots … below your post and then press the
- If you give us information about your system, we can see what we’re talking about and make better suggestions.
- You can do this by using
inxi
in a terminal or in console.
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Thank you! Had to do a reinstall to get back to run inxi because I was on Mac OS. May have found that the mba6x-bl package on aur solved it and it was actually a backlight driver! I’m testing it out through today and will post my output if the issue isn’t actually solved!
Thanks!
Alright, that didn’t work! Here is my output!
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: ro root=UUID=771eb0b4-40c4-4e3b-8e17-7c8548b1ab38
initrd=boot\initramfs-5.15-x86_64.img
Desktop: GNOME v: 41.4 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
Type: Laptop System: Apple product: MacBookAir6,2 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-7DF21CB3ED6977E5
Mobo: Apple model: Mac-7DF21CB3ED6977E5 v: MacBookAir6,2
serial: <superuser required> UEFI: Apple v: 432.60.3.0.0 date: 10/27/2021
ID-1: BAT0 charge: 11.4 Wh (32.9%) condition: 34.6/53.3 Wh (64.9%)
volts: 7.3 min: 7.4 model: SCD A1405 type: Li-ion serial: N/A
status: discharging cycles: 1287
RAM: total: 7.71 GiB used: 1.53 GiB (19.8%)
RAM Report:
Info: model: Intel Core i7-4650U bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3096 high: 3296 min/max: 800/3300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2900 2: 3287 3: 2901
4: 3296 bogomips: 18406
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Apple driver: i915
v: kernel ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:0a26 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: Apple Color LCD built: 2012 res: 1440x900 dpi: 126
gamma: 1.2 size: 30x179mm (1.18x7.05") diag: 341mm (13.4")
ratio: 16:10, 15:9 modes: 1440x900
OpenGL: renderer: Mesa DRI Intel HD Graphics 5000 (HSW GT3)
v: 4.5 Mesa 21.3.7 compat-v: 3.0 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Apple driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Device-3: Broadcom 720p FaceTime HD Camera driver: N/A pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:1570 class-ID: 0480
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: no
Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple
driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14e4:43a0 class-ID: 0280
Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8
bus-ID: 1-3.3:6 chip-ID: 05ac:828f class-ID: fe01
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 233.76 GiB used: 8.4 GiB (3.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0256G
size: 233.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: SA0Q scheme: GPT
ID-1: / raw-size: 93.23 GiB size: 91.2 GiB (97.83%) used: 8.39 GiB (9.2%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 771eb0b4-40c4-4e3b-8e17-7c8548b1ab38
ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.45%)
used: 19.3 MiB (9.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: EFI
uuid: 67E3-17ED
ID-1: /dev/sda2 maj-min: 8:2 size: 140.34 GiB fs: apfs label: N/A
uuid: d49a5079-9a8b-462f-8983-e33391c5febd
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
Hub-2: 1-3:2
info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth) ports: 3
rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
Device-1: 1-3.3:6 info: Apple Bluetooth USB Host Controller
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
Device-2: 1-5:3 info: Apple Apple Internal Keyboard / Trackpad
type: HID,Keyboard,Mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 05ac:0291 class-ID: 0301
serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 2-3:2 info: Apple Internal Memory Card Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 05ac:8406 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 64.0 C mobo: N/A
Processes: 212 Uptime: 2m wakeups: 2 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 891 lib: 262
Shell: Zsh v: 5.8.1 running-in: gnome-terminal inxi: 3.3.14
It seems the driver actually did solve it! After several days it is reliably waking up! Weird, but solved!
