hello guys I am facing 2 problems in tlp,
1.) I ran command “sudo tlp bat” and now even when I am on AC it is running in battery(manual mode)
problem-> I want to know how to exit manual mode.
2.) Following a youtube video I ran command “sudo vim /etc/default/tlp” to access the tlp config file but my file is empty.
why is the file empty?
please help me
Thank You
In tlp 1.3 the file path has changed from /etc/default/tlp
to /etc/tlp.conf
You should follow the new documentation:
https://linrunner.de/tlp/index.html
And gave us the output of
inxi --full --admin --verbosity=7 --filter --no-host
There is also a GUI for it - in the AUR:
That way you would not need to edit the config file directly.
thank you for replying and I know but I really want to get into the habit of using the terminal more. but surely I will try the application
actually I restarted the service and it is now “not in battery(manual) mode” Thank you for you help.
Better to give “thank you” to the documentation
It’s in the Manjaro community repo as well.
Thanks! Good to know.
The little differences between Arch and Manjaro again …
