Apex Legends crashes afer it loads the entry logo for Respawn and EA and just before it tried to enter the main menu. so basically 10-20 seconds after launch
It used to work fine and then after the previous , not the update we got a few days ago but the manjaro update before that , it crashes Apex Legends, No Man Sky and Elite Dangerous, more game may also crash. Before that update everything worked fine and I have not experienced any major issue apart from Apex not working a few months ago because Proton did not support EAC.
I tried to redownload the game, delete EAC and binary files then verify and redownload them, launch it from steam-native, steam-runtime even steam flatpak the crash still happens
this is the command line log, crash takes place at line 133
I also tried diffirent Proton version like Proton 7 and experimental
Its not the only game that crashes on launch No Man Sky and Elite Dangerou have the same issue although the crash is a bit diffirent but they also take place at the start of launching the game. Again I had no issues with those games previously and it was that update that broke them. Especially No Man Sky had been really stable.
At first I though it was the known EAC bug causes by an update to glibc so I reported also at proton github however seems that most people they get an EAC error which I dont so it may not be related to that issue.
I am on the latest Manjaro XFCE fully updated to the latest update, I have changed or modified anything, its a standard install.
[kilon@kilon-eph Desktop]$ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.12.18 false PCI
[kilon@kilon-eph Desktop]$ inxi --admin --verbosity=7 --filter --width
Kernel: 5.10.136-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=0956dd14-44b7-446c-bf3f-4796bde7e95d rw quiet apparmor=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK (MS-7C91) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: A.10
date: 07/01/2020
RAM: total: 31.34 GiB used: 5.64 GiB (18.0%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x71 (113)
stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2308 high: 4015
min/max: 2200/6079:5938:5796:5655:5514:5232:5373:5091:4950:4813:4672
boost: enabled scaling: driver: acpi-cpufreq governor: schedutil cores:
1: 2688 2: 2189 3: 1867 4: 2204 5: 2200 6: 2199 7: 2053 8: 4015 9: 2122
10: 2168 11: 1866 12: 2238 13: 2798 14: 1905 15: 2159 16: 2200 17: 2200
18: 2200 19: 2057 20: 3597 21: 2058 22: 2008 23: 1907 24: 2517
bogomips: 182477
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 2b:00.0 chip-ID: 10de:1e84
class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-1:2 chip-ID: 046d:085c
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x572mm (40.00x22.52")
s-diag: 1166mm (45.9")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 163
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 2070 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Device-1: NVIDIA TU104 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 1-2.4:4 pcie: chip-ID: b58e:9e84 class-ID: 0300 gen: 3
speed: 8 GT/s serial: <filter> lanes: 16 bus-ID: 2b:00.1
chip-ID: 10de:10f8 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Blue Microphones Yeti Stereo Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-4: BEHRINGER GmbH UMC1820 type: USB driver: snd-usb-audio
bus-ID: 1-3:3 chip-ID: 1397:0503 class-ID: fe01 serial: <filter>
Device-5: Logitech C922 Pro Stream Webcam type: USB
Sound Server-1: ALSA v: k5.10.136-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 16.1 running: yes
Sound Server-5: PipeWire v: 0.3.56 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 28:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp40s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 2a:00.0
IF: enp42s0 state: down mac: <filter>
Device-3: TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS] type: USB
driver: r8188eu bus-ID: 5-3:3 chip-ID: 2357:010c class-ID: 0000
serial: <filter>
IF: wlp45s0f3u3 state: up mac: <filter>
Local Storage: total: 931.51 GiB used: 493.97 GiB (53.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
lanes: 4 type: SSD serial: <filter> rev: S5Z42105 temp: 41.9 C scheme: GPT
ID-1: / raw-size: 586.29 GiB size: 576.02 GiB (98.25%) used: 493.95 GiB
(85.8%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 0956dd14-44b7-446c-bf3f-4796bde7e95d
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 25.2 MiB
(26.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 988A-084B
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 344.62 GiB fs: ntfs label: N/A
uuid: 04428F48428F3E04
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 498 MiB fs: ntfs label: N/A
uuid: 2A8045CA80459D67
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-2.4:4 info: Blue Microphones Yeti Stereo Microphone
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: b58e:9e84 class-ID: 0300
serial: <filter>
Device-2: 1-3:3 info: BEHRINGER GmbH UMC1820 type: Audio
driver: snd-usb-audio interfaces: 6 rev: 2.0 speed: 480 Mb/s
Device-3: 1-5:5 info: Corsair Gaming M65 Pro RGB Mouse type: Mouse,HID
power: 300mA chip-ID: 1b1c:1b2e class-ID: 0300 serial: <filter>
Device-4: 1-6:6 info: Corsair Gaming K55 RGB Keyboard type: Keyboard,HID
power: 500mA chip-ID: 1b1c:1b3d class-ID: 0300 serial: <filter>
Device-5: 1-8:7 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7c91 class-ID: 0300 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: Logitech C922 Pro Stream Webcam type: Video,Audio
power: 500mA chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Device-2: 5-3:3 info: TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS]
type: Network driver: r8188eu interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 2357:010c class-ID: 0000 serial: <filter>
Hub-7: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 68.9 C mobo: N/A gpu: nvidia temp: 59 C
Processes: 445 Uptime: 2h 58m wakeups: 0 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 alt: 10/11
clang: 14.0.6 Packages: 1920 pacman: 1908 lib: 541 flatpak: 8 snap: 4
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.20
