Hi
I have installed Manjaro alongside an existing Mint system. Now whenever I boot I get 2 boot menus (not sure if that’s the best way to phase it):
- The first is text-only and seems to be installed by Mint, it has an option for Manjaro but it does not boot (but fallback to initramfs does)
- Then if I press “esc” from there, and type exit in the grub command prompt I get the 2nd graphic boot menu (seems to belong to Manjaro) and from there Manjaro boots fine.
Is there any way to have just one menu? Ideally I’d like to boot straight to Manjaro but also have an option to boot into Mint as well.
I went through the steps described on the wiki page Restore_the_GRUB_Bootloader (not allowed to post links) but it didn’t help.
Appreciate any advice.
parted -l
Model: ATA ST2000DM008-2FR1 (scsi)
Disk /dev/sda: 2000GB
Sector size (logical/physical): 512B/4096B
Partition Table: loop
Disk Flags:
Number Start End Size File system Flags
1 0.00B 2000GB 2000GB ext4
Model: CT1000P1SSD8 (nvme)
Disk /dev/nvme0n1: 1000GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 538MB 537MB fat32 EFI System Partition boot, esp
2 538MB 500GB 500GB ext4
3 500GB 1000GB 500GB ext4
findmnt
TARGET SOURCE FSTYPE OPTIONS
/ /dev/nvme0n1p3 ext4 rw,noatime
├─/proc proc proc rw,nosuid,nodev,noexec,relatime
│ └─/proc/sys/fs/binfmt_misc systemd-1 autofs rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=14588
│ └─/proc/sys/fs/binfmt_misc binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
├─/sys sys sysfs rw,nosuid,nodev,noexec,relatime
│ ├─/sys/firmware/efi/efivars efivarfs efivarfs rw,nosuid,nodev,noexec,relatime
│ ├─/sys/kernel/security securityfs securityfs rw,nosuid,nodev,noexec,relatime
│ ├─/sys/fs/cgroup cgroup2 cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
│ ├─/sys/fs/pstore pstore pstore rw,nosuid,nodev,noexec,relatime
│ ├─/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode=700
│ ├─/sys/kernel/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime
│ ├─/sys/kernel/debug debugfs debugfs rw,nosuid,nodev,noexec,relatime
│ ├─/sys/kernel/config configfs configfs rw,nosuid,nodev,noexec,relatime
│ └─/sys/fs/fuse/connections fusectl fusectl rw,nosuid,nodev,noexec,relatime
├─/dev dev devtmpfs rw,nosuid,relatime,size=8148608k,nr_inodes=2037152,mode=755,inode64
│ ├─/dev/shm tmpfs tmpfs rw,nosuid,nodev,inode64
│ ├─/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
│ ├─/dev/hugepages hugetlbfs hugetlbfs rw,relatime,pagesize=2M
│ └─/dev/mqueue mqueue mqueue rw,nosuid,nodev,noexec,relatime
├─/run run tmpfs rw,nosuid,nodev,relatime,mode=755,inode64
│ └─/run/user/1000 tmpfs tmpfs rw,nosuid,nodev,relatime,size=1637820k,nr_inodes=409455,mode=700,uid=1000,gid=1000,inode64
│ └─/run/user/1000/gvfs gvfsd-fuse fuse.gvfsd-fus rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
├─/tmp tmpfs tmpfs rw,nosuid,nodev,nr_inodes=409600,inode64
└─/boot/efi /dev/nvme0n1p1 vfat rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remo
