My monitors no longer go to sleep after a timeout. It used to work fine, but stopped randomly a couple months ago with an update. I’m not quite sure which.
I have tried using both xfce Power Manager and XScreensaver to configure the setting. (I have tried them individually and both together.)
The monitors do not sleep and then wake up; they never sleep.
I can manually put them to sleep with
sleep 2;xset dpms force standby
And they sleep just fine and remain asleep, but I cannot get them to turn off automatically.
I have no idea where to even begin looking to troubleshoot this.
Kernel: 5.19.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=6155e3c2-b70c-4c4b-8093-9b1888b9368a ro quiet apparmor=1
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: X570 Taichi serial: <superuser required>
UEFI: American Megatrends v: P4.00 date: 01/19/2021
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: full
RAM: total: 62.72 GiB used: 7.24 GiB (11.5%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2373 high: 3794 min/max: 2200/5083 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3597 2: 2200
3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 3400
12: 2200 13: 2200 14: 2200 15: 2200 16: 2200 17: 2200 18: 2200 19: 2880
20: 2200 21: 2200 22: 2200 23: 2200 24: 2200 25: 2200 26: 2200 27: 3794
28: 2200 29: 2200 30: 2200 31: 2875 32: 2200 bogomips: 217718
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Conexant Systems CX23887/8 PCIe Broadcast Audio and Video Decoder
with 3D Comb vendor: Hauppauge works WinTV-quadHD driver: cx23885 v: 0.0.4
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 0d:00.0 chip-ID: 14f1:8880
class-ID: 0400
Device-2: Conexant Systems CX23887/8 PCIe Broadcast Audio and Video
Decoder with 3D Comb vendor: Hauppauge works driver: cx23885 v: 0.0.4
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 0e:00.0 chip-ID: 14f1:8880
class-ID: 0400
Device-3: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Sapphire
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,DP-2,HDMI-A-1 empty: DP-3 bus-ID: 14:00.0 chip-ID: 1002:73bf
class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 7040x1440 s-dpi: 96 s-size: 1863x381mm (73.35x15.00")
s-diag: 1902mm (74.86")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,top-center
model: Dell U2520DR serial: <filter> built: 2020 res: 2560x1440 hz: 60
dpi: 118 gamma: 1.2 size: 553x311mm (21.77x12.24") diag: 634mm (25")
ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-2: DP-2 mapped: DisplayPort-1 pos: top-right model: Dell U2520DR
serial: <filter> built: 2021 res: 2560x1440 hz: 60 dpi: 118 gamma: 1.2
size: 553x311mm (21.77x12.24") diag: 634mm (25") ratio: 16:9 modes:
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: bottom-l model: Dell U2410
serial: <filter> built: 2012 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 720x400
OpenGL: renderer: AMD Radeon RX 6800 (sienna_cichlid LLVM 14.0.6 DRM 3.47
5.19.7-1-MANJARO) v: 4.6 Mesa 22.1.7 direct render: Yes
class-ID: 0400
class-ID: 0400
Device-3: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 14:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-4: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 16:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.19.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 09:00.0
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1
all]
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-2:2
Local Storage: total: 2.73 TiB used: 1.74 TiB (63.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
temp: 47.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 960 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B7QCXE7 temp: 45.9 C scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 1.1 TiB (61.2%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:4 label: N/A
uuid: 6155e3c2-b70c-4c4b-8093-9b1888b9368a
ID-2: /Storage raw-size: 931.51 GiB size: 915.82 GiB (98.31%) used: 658.51
GiB (71.9%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:2 label: Storage
uuid: 7790f4c2-7e10-4b79-8411-8644affaca29
ID-3: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3 label: N/A
uuid: B4C3-27D5
ID-4: /media/Bunnyfiles raw-size: N/A size: 31.42 TiB used: 23.11 TiB
(73.6%) fs: cifs dev: /dev/Bunnyfiles
ID-5: /media/Ebooks raw-size: N/A size: 31.42 TiB used: 23.11 TiB (73.6%)
fs: cifs dev: /dev/Ebooks
ID-6: /media/Games raw-size: N/A size: 31.42 TiB used: 23.11 TiB (73.6%)
fs: cifs dev: /dev/games
ID-7: /media/Synology raw-size: N/A size: 31.42 TiB used: 23.11 TiB
(73.6%) fs: nfs4 remote: 192.168.0.21:/volume1/Synology
ID-8: /media/music raw-size: N/A size: 31.42 TiB used: 23.11 TiB (73.6%)
fs: cifs dev: /dev/music
ID-9: /media/video raw-size: N/A size: 31.42 TiB used: 23.11 TiB (73.6%)
fs: nfs4 remote: 192.168.0.21:/volume1/video
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 1-1:2 info: Kensington Expert Mouse Trackball type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 047d:1020 class-ID: 0301
Hub-2: 1-2:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-2.1:5 info: Genesys Logic All-in-One Cardreader
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1
speed: 480 Mb/s power: 500mA chip-ID: 05e3:0732 class-ID: 0806
serial: <filter>
Device-2: 1-3:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-3: 1-5:6 info: ROCCAT Tyon White Mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1e7d:2e4b class-ID: 0300 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-1:4 info: MediaTek Cyrus CS 24 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA
chip-ID: 0e8d:2008 class-ID: 0000 serial: <filter>
Device-2: 3-2:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-3: 3-4:3 info: Razer USA Tartarus V2 type: Keyboard,Mouse
driver: razerkbd,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 1532:022b class-ID: 0300
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-7: 5-3:2 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0801 class-ID: 0900
Device-1: 5-3.1:3 info: HAILUCK USB KEYBOARD type: Keyboard,HID
power: 100mA chip-ID: 258a:000c class-ID: 0300
Hub-8: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 41.1 C mobo: N/A gpu: amdgpu temp: 47.0 C
mem: 48.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 554 Uptime: 1d 1h 5m wakeups: 2 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1911 pm: pacman pkgs: 1903 libs: 539 tools: pacaur,pamac,pikaur
pm: flatpak pkgs: 6 pm: snap pkgs: 2 Shell: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.21
Screen 0: minimum 320 x 200, current 7040 x 1440, maximum 16384 x 16384
DisplayPort-0 connected primary 2560x1440+1920+0 (normal left inverted right x axis y axis) 553mm x 311mm
2560x1440 59.95*+
1920x1200 59.88
2048x1080 60.00 24.00
1920x1080 60.00 50.00 59.94 24.00 23.98
1600x1200 60.00
1680x1050 59.95
1600x900 60.00
1280x1024 75.02 60.02
1440x900 59.95
1280x800 59.95
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 75.00 60.00 59.94
720x400 70.08
DisplayPort-1 connected 2560x1440+4480+0 (normal left inverted right x axis y axis) 553mm x 311mm
2560x1440 59.95*+
1920x1200 59.88
1600x1200 60.00
1680x1050 59.95
1600x900 60.00
1440x900 59.95
1280x800 59.95
1152x864 75.00
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
720x400 70.08
DisplayPort-2 disconnected (normal left inverted right x axis y axis)
HDMI-A-0 connected 1920x1200+0+240 (normal left inverted right x axis y axis) 518mm x 324mm
1920x1200 59.95*+
1600x1200 60.00
1680x1050 59.95
1440x900 59.95
1280x800 59.95
1152x864 75.00
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
720x400 70.08
There doesn’t appear to be anything even close to relevant in dmesg or journalctl.
