17.1.1-rc2 Xfce 32-bit installer image
preview
manjaro32
#22
[meurglys@ma3a ~]$ inxi -Fxms
Resuming in non X mode: xrandr not found. For package install advice run: inxi --recommends
System:    Host: ma3a Kernel: 4.14.10-1-MANJARO i686 bits: 32 gcc: 7.2.1
           Desktop: N/A Distro: Manjaro Linux
Machine:   Device: laptop System: LENOVO. product: 27463XU v: ThinkPad SL500 serial: N/A
           Mobo: LENOVO model: BOXSTER v: LENOVO 6AET41WW serial: N/A
           BIOS: LENOVO v: 6AET41WW date: 07/10/2008
Battery    BAT0: charge: 42.0 Wh 99.9% condition: 42.0/51.8 Wh (81%)
           model: ASUSTEK IBM-42T5233 status: Full
CPU:       Dual core Intel Core2 Duo T5670 (-MCP-)
           arch: Conroe rev.13 cache: 2048 KB
           flags: (lm nx pae sse sse2 sse3 ssse3) bmips: 7185
           clock speeds: max: 1801 MHz 1: 800 MHz 2: 800 MHz
Memory:    Using dmidecode: root required for dmidecode
Graphics:  Card: Intel Mobile 4 Series Integrated Graphics Controller
           bus-ID: 00:02.0
           Display Server: N/A drivers: intel (unloaded: modesetting)
           tty size: 80x24
Audio:     Card Intel 82801I (ICH9 Family) HD Audio Controller
           driver: snd_hda_intel bus-ID: 00:1b.0
           Sound: Advanced Linux Sound Architecture v: k4.14.10-1-MANJARO
Network:   Card-1: Intel PRO/Wireless 5100 AGN [Shiloh] Network Connection
           driver: iwlwifi bus-ID: 02:00.0
           IF: wlp2s0 state: up mac: 00:16:ea:ba:ca:9e
           Card-2: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
           driver: r8168 v: 8.044.02-NAPI port: e800 bus-ID: 0c:00.0
           IF: enp12s0 state: down mac: 00:22:15:61:c8:12
Drives:    HDD Total Size: 250.1GB (53.0% used)
           ID-1: /dev/sda model: FUJITSU_MHZ2250B size: 250.1GB
Partition: ID-1: / size: 225G used: 120G (57%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 4.58GB used: 0.00GB (0%)
           fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 64.0C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 140 Uptime: 11:02 Memory: 687.8/1983.3MB
           Init: systemd Gcc sys: 7.2.1
           Client: Shell (bash 4.4.121) inxi: 2.3.53
[meurglys@ma3a ~]$
#23
It looks like the “black screen” issues are down to the Xorg/MESA rebuilds. Hopefully newer packages fix the issue, so it should just be a case of rebuilding the installer images with the newer packages.
For the i686 images I’d wait until the current x32-unstable set makes its way to x32-stable as there are a lot of updated packages there.
Until then, if you get a black screen, switch to a console (CTRL-ALT-F2), log in, and:
sudo ln -s /usr/lib/xorg/modules/dri /usr/lib/dri
sudo systemctl restart lightdm
or whichever DM you’re using (gdm, sddm, …)
With Xfce, I’ve also found that if/when the screen locks (e.g. switch to a text console and back), logging in again resets the current session, so any in-progress installer is killed. That ain’t useful.
First boot with a fresh 17.1 install in Virtualbox leads to a black screen. Switching to a text console, switching branch to x32-unstable, then updating and rebooting, and everything works.
I might need to fast-track this update set and get another installer image built.
#24
no hope for me…
I’m getting same behavior with Free
first start stacks at 'Starting DBUS… ’ hard shutdown and restarting then works
calamares crashes
install with M-A finishes with 'Failed to Install basepkg (255) (selected XFCE Minimal)
#25
@philm has once again kindly spun an installer image for Xfce:
https://sourceforge.net/projects/manjarodev/files/review/manjaro-32/17.1.1-rc1/xfce/
Be aware, 17.1.1-rc1 is built against the x32-testing branch.
This should fix a number of issues the 17.1.0 image had.
I’ll get my head around iso creation again soon. :slight_smile:
#26
Can’t download:
/media/DataHDD/ISO >>> aria2c 'https://sourceforge.net/projects/manjarodev/files/review/manjaro-32/17.1.1-rc1/xfce/manjaro-xfce-17.1.1-rc1-testing-i686.iso/download'                     [3]
01/07 18:35:51 [NOTICE] Downloading 1 item(s)
[#2d2682 0B/0B CN:1 DL:0B]
01/07 18:35:52 [ERROR] CUID#7 - Download aborted. URI=https://sourceforge.net/projects/manjarodev/files/review/manjaro-32/17.1.1-rc1/xfce/manjaro-xfce-17.1.1-rc1-testing-i686.iso/download
Exception: [AbstractCommand.cc:351] errorCode=3 URI=https://sourceforge.net/projects/manjarodev/files/review/manjaro-32/17.1.1-rc1/xfce/manjaro-xfce-17.1.1-rc1-testing-i686.iso/download
  -> [HttpSkipResponseCommand.cc:219] errorCode=3 Resource not found
01/07 18:35:52 [NOTICE] Download GID#2d2682e8c310f766 not complete:
Download Results:
gid   |stat|avg speed  |path/URI
2d2682|ERR |       0B/s|https://sourceforge.net/projects/manjarodev/files/review/manjaro-32/17.1.1-rc1/xfce/manjaro-xfce-17.1.1-rc1-testing-i686.iso/download
Status Legend:
(ERR):error occurred.
aria2 will resume download if the transfer is restarted.
If there are any errors, then see the log file. See '-l' option in help/man page for details.
/media/DataHDD/ISO >>> wget 'https://sourceforge.net/projects/manjarodev/files/review/manjaro-32/17.1.1-rc1/xfce/manjaro-xfce-17.1.1-rc1-testing-i686.iso'
--2018-01-07 18:38:47--  https://sourceforge.net/projects/manjarodev/files/review/manjaro-32/17.1.1-rc1/xfce/manjaro-xfce-17.1.1-rc1-testing-i686.iso
Loaded CA certificate '/etc/ssl/certs/ca-certificates.crt'
Resolving sourceforge.net... 216.34.181.60
Connecting to sourceforge.net|216.34.181.60|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://sourceforge.net/projects/manjarodev/files/review/manjaro-32/17.1.1-rc1/xfce/manjaro-xfce-17.1.1-rc1-testing-i686.iso/download [following]
--2018-01-07 18:38:49--  https://sourceforge.net/projects/manjarodev/files/review/manjaro-32/17.1.1-rc1/xfce/manjaro-xfce-17.1.1-rc1-testing-i686.iso/download
HTTP request sent, awaiting response... 404 Not Found
2018-01-07 18:38:50 ERROR 404: Not Found.
#27
I jumped the gun and posted the link before it had finished uploading. :slightly_frowning_face:
#28
I missed the boat! I just got bluetooth running by (re-)installing bluez-utils. The last liveUSB/ISO didn’t have it installed.
Edit: I also needed to add a systemd service to launch btattach. Without it the broadcom blob (.hcd) wouldn’t load and the bluetooth OEM keydock wouldn’t connect.
#29
It is now uploaded fully.
#30
On the installed system LO fails to open. No relevant output when started from the terminal. The opening animation completes, but no window opens, the command in the terminal just ends, no soffice.bin process in htop.
Otherwise the installation was sucessful and applications I tested work, qt5 ones, too.
#31
I think this is the Java issue… if you disable Java (Tools, Options, Advanced, Use a Java runtime environment) then Writer will run, with Java enabled it won’t.
I need to find a way to disable this by default for new profiles…
#32
Yes, that worked. I needed to run
libreoffice --safe-mode
then Tools->Options->Advanced
#33
Just tested the new ISO on my test rigs and found no issue with installation or the final system. I haven’t tested the live environment all that much yet. All I found was the same as @eugen-b so far, in live mode.
The previous issue I mentioned regarding package databases persists so I assume the fix hasn’t filtered down yet, no big deal.
All kernels work as expected so far on real hardware. Kernel 4.14 still doesnt want to play nice in my VM as previously mentioned, yet on real hardware it is still working fine.
#34
I have actually noticed something else that isnt set by default and i cant honestly remember if it is something i’ve set on my own system years ago or if it is something missing/wrong…
On my main XFCE system the icons in “Manjaro Settings Manager” are activated via a single click, which is in keeping with the rest of the settings panel. Yet on the x32 version they require a double click.
I believe this is due to a setting in qt5ct…
As i said, i dont remember if i set this myself and forgot, or if its not set by default for some reason in x32…
Either way it might be something worth enabling by default as it fits better with the “flow” of all the other settings in XFCE.
Might also be worth turning on by default in the x64 XFCE edition too if not on by default… Maybe, @philm?
EDIT: Also noticed that the pacman-mirrors.conf file is missing the options for protocol selection and sslverification… Is this intentional?
#35
No, those should be present. Not sure why there would be any difference between x86_64 and i686 packages there, as far as I know they’re built from the same packaging file source.
Won’t it affect all other Qt5 applications too?
#36
I guess it potentially could, but my main system has had this set since I can remember and I’ve not noticed anything acting strange… Maybe I just don’t use many QT programs?
It does certainly make the flow of the settings feel seemless though. Maybe worth a thought or a bit of testing with people who use XFCE and a lot of QT programs?
As for the pacman-mirrors.conf my freshly installed x32 version from 17.1.1 RC1 is quite different from my x64 version. I’ll check some more tomorrow as it’s close to midnight here.
#37
well, this image boots fine, immediately, on my machine
but Calamares always crash when starting installation, after confirm of all settings
M-A deed the same as before
#38
Ok @jonathon
I’ve doubled checked the pacman-mirrors.conf on a freshly installed x32 system (17.1.1 RC1) and this is what it gives…
Which is not correct as you can see it is missing the x32 tag on branch, while also appearing to be a quite old version of the configuration file.
The live environment runs with the below configuration, which has the correct branching for 17.1.1-RC1 but again appears to be an older version of the config file.
I’ve done this now 3 times and each time gives me the same incorrect version of pacman-mirrors.conf. I can fix it by deleting the config file and then reinstalling pacman-mirrors, at which point the correct config file is then in place and used.
This is the same for on my test rig and in my VM. Hope this gives you enough information to work on :slight_smile:
Incorrect pacman-mirrors.conf on fresh install 17.1.2
#39
start Calamares in terminal with sudo -E calamares -d
m-a writes a log in /var/log/m-a.log
#40
[manjaro@manjaro ~]$ sudo -E calamares -d
QStandardPaths: wrong ownership on runtime directory /run/user/1000, 1000 instead of 0
qt5ct: using qt5ct plugin
17:25:28 [1]: Calamares version: 3.1.11-10
Translation: Calamares: Using system locale: "en_US"
17:25:29 [1]: Default font =====
Pixel size:    -1
Point size:    10
Point sizeF:   10
Font family:   "Cantarell"
Metric height: 17
17:25:29 [1]: Font height: 17
17:25:29 [1]: Available languages: ("ar", "ast", "bg", "ca", "cs_CZ", "da", "de", "el", "en", "en_GB", "es_MX", "es", "eu", "fr", "he", "hr", "hu", "id", "is", "it_IT", "ja", "lt", "nl", "pl", "pt_BR", "pt_PT", "ro", "ru", "sk", "sv", "th", "tr_TR", "zh_CN", "zh_TW")
17:25:29 [1]: CalamaresApplication thread: 0xa536c0
17:25:29 [1]: Using log file: "/home/manjaro/.cache/Calamares/Calamares/Calamares.log"
17:25:29 [1]: Using Calamares settings file at "/etc/calamares/settings.conf"
17:25:29 [1]: Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
17:25:29 [1]: WARNING: the selected branding component does not ship translations.
17:25:29 [1]: Loaded branding component "manjaro"
17:25:29 [1]: STARTUP: initQmlPath, initSettings, initBranding done
17:25:29 [1]: STARTUP: initModuleManager: module init started
17:25:29 [1]: STARTUP: initModuleManager: all modules init done
17:25:29 [1]: STARTUP: initJobQueue done
17:25:29 [1]: Available size QSize(1024, 740)
17:25:29 [1]:   Proposed window size: 1024 612
17:25:31 [1]: STARTUP: CalamaresWindow created; loadModules started
17:25:31 [1]: Initial locale  "en_US"
17:25:31 [8]: Translation: Calamares: Using system locale: "en_US"
17:25:31 [1]: Welcome string false "Manjaro Linux 17.1 \"Hakoila\""
17:25:32 [1]: ViewModule "welcome@welcome" loading complete.
17:25:32 [1]: WARNING: guessLocaleConfiguration can't guess from an empty list.
17:25:32 [1]: ViewModule "locale@locale" loading complete.
17:25:39 [1]: ViewModule "keyboard@keyboard" loading complete.
17:25:43 [8]: Loaded backend plugin:  "pmlibpartedbackendplugin"
17:25:43 [1]: ViewModule "partition@partition" loading complete.
17:25:43 [1]: ViewModule "users@users" loading complete.
17:25:43 [1]: ViewModule "summary@summary" loading complete.
17:25:43 [1]: Module "partition@partition" already loaded.
17:25:44 [1]: QML import paths: ("/usr/share/calamares/qml", "/usr/bin", "qrc:/qt-project.org/imports", "/usr/lib/qt/qml")
17:25:44 [1]: Module "locale@locale" already loaded.
17:25:44 [1]: Module "keyboard@keyboard" already loaded.
17:25:44 [1]: Module "users@users" already loaded.
17:25:44 [1]: FinishedPage()
17:25:44 [1]: ViewModule "finished@finished" loading complete.
17:25:44 [1]: STARTUP: loadModules for all modules done
17:25:45 [1]: STARTUP: Window now visible and ProgressTreeView populated
17:25:45 [1]: Need at least storage bytes: 8482560409
17:25:46 [1]: Need at least ram bytes: 1073741824
17:25:46 [1]: A battery exists, checking for mains power.
17:25:50 [1]: enoughStorage, enoughRam, hasPower, hasInternet, isRoot:  true true false true true
17:25:50 [1]: xkbmap selection changed to:  "it" - ""
17:25:51 [1]: Selected locale "ro_RO"
17:25:51 [8]: Translation: Calamares: Using system locale: "ro_RO"
17:25:51 [1]: WARNING: guessLocaleConfiguration can't guess from an empty list.
17:25:51 [1]: GeoIP reporting "Europe/Rome"
17:25:53 [1]: WARNING: guessLocaleConfiguration can't guess from an empty list.
17:25:57 [1]: Selected locale "it_IT"
17:25:57 [8]: Translation: Calamares: Using system locale: "it_IT"
17:26:03 [1]: Removing unsuitable devices: 1 candidates.
17:26:03 [1]: LIST OF DETECTED DEVICES:
17:26:03 [1]: node	capacity	name	prettyName
17:26:03 [1]: "/dev/sda" 80023749120 "ATA Hitachi HTS54128" "ATA Hitachi HTS54128 – 74,53 GiB (/dev/sda)"
17:26:03 [1]: .. 1 devices detected.
17:26:18 [1]: checking if "/dev/sda1" can be resized.
17:26:18 [1]: "/dev/sda1" seems like a good path
17:26:18 [1]: found Partition* for "/dev/sda1"
17:26:18 [1]: Required  storage B: 11166914969 "(10.4GB)"
17:26:18 [1]: Available storage B: 67787382784 "(63GB)" for "/dev/sda1"    length: 149737472    sectorsUsed: 17340240    fsType: "ext4"
17:26:18 [1]: Partition "/dev/sda1" authorized for resize + autopartition install.
17:26:18 [1]: "Osprober lines, clean:\n/dev/sda1:Manjaro Linux (17.1.0):ManjaroLinux:linux"
17:26:18 [1]: Updating partitioning state widgets.
17:26:18 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
17:26:18 [1]: Required  storage B: 9019431321 "(8GB)"
17:26:18 [1]: Storage capacity  B: 76665585664 "(71GB)" for "/dev/sda1"    length: 149737472
17:26:18 [1]: Partition "/dev/sda1" authorized for replace install.
17:26:18 [1]: Available storage B: 3359637504 "(3GB)" for "/dev/sda2"    length: 6561792    sectorsUsed: 0    fsType: "linuxswap"
17:26:18 [1]: Storage capacity  B: 3359637504 "(3GB)" for "/dev/sda2"    length: 6561792
17:26:18 [1]: Updating partitioning preview widgets.
17:26:19 [1]: Got locale language "it_IT.UTF-8"
17:26:19 [1]:  .. extracted country "Italy" :: ("it", "IT")
17:26:19 [1]:    .. looking for locale part "IT"
17:26:19 [1]:    .. matched "it"
17:26:23 [1]: Updating partitioning preview widgets.
17:26:25 [1]: Choice applied:  4
17:26:37 [1]: old boundaries: 2048 149739519 149737472
17:26:37 [1]: new boundaries: 2048 149739519
17:26:37 [1]: dirty status: false
17:26:37 [8]: PartitionPage::updateBootLoaderInstallPath "/dev/sda"
17:26:37 [1]: PCM::setBootLoaderInstallPath "/dev/sda"
17:26:45 [1]: old boundaries: 149739520 156301311 6561792
17:26:45 [1]: new boundaries: 149739520 156301311
17:26:45 [1]: dirty status: false
17:26:45 [8]: PartitionPage::updateBootLoaderInstallPath "/dev/sda"
17:26:45 [1]: PCM::setBootLoaderInstallPath "/dev/sda"
17:27:16 [0]: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
17:27:16 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
17:27:16 [1]: Creating FillGlobalStorageJob with bootLoader path "/dev/sda"
17:27:16 [1]: PartitionCodeModule has been asked for jobs. About to return:
17:27:16 [1]:   .. "Rimuovere tutti i punti di mount temporanei."
17:27:16 [1]:   .. "Rimuovere i punti di mount per operazioni di partizionamento su /dev/sda"
17:27:16 [1]:   .. "Formattare la partizione /dev/sda1 (file system: ext4, dimensioni: 73114 MB) su ATA Hitachi HTS54128"
17:27:16 [1]:   .. "Formattare la partizione /dev/sda2 (file system: linuxswap, dimensioni: 3204 MB) su ATA Hitachi HTS54128"
17:27:16 [1]:   .. "Impostare informazioni partizione"
17:27:16 [1]: Gathering UUIDs for partitions that exist now.
17:27:17 [1]: QHash(("/dev/sda1", "1d388c95-2bc2-43a4-b6e4-ef84d3ea2cf2")("/dev/sda2", "9de7f94c-86bf-460d-b7a9-6a7a77d0e367"))
17:27:17 [1]: Writing to GlobalStorage["partitions"]
17:27:17 [1]: "/dev/sda1" mtpoint: "/" fs: QVariant(QString, "ext4") ( QVariant(QString, "ext4") ) "1d388c95-2bc2-43a4-b6e4-ef84d3ea2cf2"
17:27:17 [1]: "/dev/sda2" mtpoint: "" fs: QVariant(QString, "linuxswap") ( QVariant(QString, "linuxswap") ) "9de7f94c-86bf-460d-b7a9-6a7a77d0e367"
17:27:17 [8]: QVariant(QString, "1d388c95-2bc2-43a4-b6e4-ef84d3ea2cf2") "/dev/sda1" "/" "ext4"
17:27:17 [8]: QVariant(QString, "9de7f94c-86bf-460d-b7a9-6a7a77d0e367") "/dev/sda2" "" "linuxswap"
17:27:17 [1]: Gathering UUIDs for partitions that exist now.
17:27:17 [1]: Summary widget is larger than viewport, enlarge by 15 to QSize(816, 574)
17:27:22 [8]: QOpenGLFramebufferObject: Framebuffer incomplete attachment.
17:27:22 [8]: QOpenGLFramebufferObject: Framebuffer incomplete, missing draw buffer.
17:27:22 [8]: QOpenGLFramebufferObject: Framebuffer incomplete, missing attachment.
17:27:23 [1]: Creating FillGlobalStorageJob with bootLoader path "/dev/sda"
17:27:23 [1]: PartitionCodeModule has been asked for jobs. About to return:
17:27:23 [1]:   .. "Rimuovere tutti i punti di mount temporanei."
17:27:23 [1]:   .. "Rimuovere i punti di mount per operazioni di partizionamento su /dev/sda"
17:27:23 [1]:   .. "Formattare la partizione /dev/sda1 (file system: ext4, dimensioni: 73114 MB) su ATA Hitachi HTS54128"
17:27:23 [1]:   .. "Formattare la partizione /dev/sda2 (file system: linuxswap, dimensioni: 3204 MB) su ATA Hitachi HTS54128"
17:27:23 [1]:   .. "Impostare informazioni partizione"
17:27:23 [0]: Starting job "Rimuovere tutti i punti di mount temporanei."
17:27:23 [1]: Opened mtab. Lines:
17:27:23 [1]: "proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0"
17:27:23 [1]: "sys /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0"
17:27:23 [1]: "dev /dev devtmpfs rw,nosuid,relatime,size=623392k,nr_inodes=155848,mode=755 0 0"
17:27:23 [1]: "run /run tmpfs rw,nosuid,nodev,relatime,mode=755 0 0"
17:27:23 [1]: "/dev/sr0 /run/miso/bootmnt iso9660 ro,relatime 0 0"
17:27:23 [1]: "cowspace /run/miso/cowspace tmpfs rw,relatime,size=262144k,mode=755 0 0"
17:27:23 [1]: "overlay_root /run/miso/overlay_root tmpfs rw,relatime,size=958972k,mode=755 0 0"
17:27:23 [1]: "/dev/loop0 /run/miso/sfs/livefs squashfs ro,relatime 0 0"
17:27:23 [1]: "/dev/loop1 /run/miso/sfs/mhwdfs squashfs ro,relatime 0 0"
17:27:23 [1]: "/dev/loop2 /run/miso/sfs/desktopfs squashfs ro,relatime 0 0"
17:27:23 [1]: "/dev/loop3 /run/miso/sfs/rootfs squashfs ro,relatime 0 0"
17:27:23 [1]: "overlay / overlay rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work 0 0"
17:27:23 [1]: "securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0"
17:27:23 [1]: "tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0"
17:27:23 [1]: "devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0"
17:27:23 [1]: "tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,mode=755 0 0"
17:27:23 [1]: "cgroup /sys/fs/cgroup/unified cgroup2 rw,nosuid,nodev,noexec,relatime 0 0"
17:27:23 [1]: "cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,name=systemd 0 0"
17:27:23 [1]: "pstore /sys/fs/pstore pstore rw,nosuid,nodev,noexec,relatime 0 0"
17:27:23 [1]: "cgroup /sys/fs/cgroup/net_cls,net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio 0 0"
17:27:23 [1]: "cgroup /sys/fs/cgroup/perf_event cgroup rw,nosuid,nodev,noexec,relatime,perf_event 0 0"
17:27:23 [1]: "cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0"
17:27:23 [1]: "cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0"
17:27:23 [1]: "cgroup /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0"
17:27:23 [1]: "cgroup /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0"
17:27:23 [1]: "cgroup /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0"
17:27:23 [1]: "cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0"
17:27:23 [1]: "cgroup /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0"
17:27:23 [1]: "systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=25,pgrp=1,timeout=0,minproto=5,maxproto=5,direct 0 0"
17:27:23 [1]: "tmpfs /tmp tmpfs rw,nosuid,nodev 0 0"
17:27:23 [1]: "hugetlbfs /dev/hugepages hugetlbfs rw,relatime 0 0"
17:27:23 [1]: "debugfs /sys/kernel/debug debugfs rw,relatime 0 0"
17:27:23 [1]: "mqueue /dev/mqueue mqueue rw,relatime 0 0"
17:27:23 [1]: "configfs /sys/kernel/config configfs rw,relatime 0 0"
17:27:23 [1]: "tmpfs /etc/pacman.d/gnupg tmpfs rw,relatime,mode=755 0 0"
17:27:23 [1]: "tmpfs /run/user/1000 tmpfs rw,nosuid,nodev,relatime,size=127860k,mode=700,uid=1000,gid=1000 0 0"
17:27:23 [1]: "fusectl /sys/fs/fuse/connections fusectl rw,relatime 0 0"
17:27:23 [1]: "gvfsd-fuse /run/user/1000/gvfs fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 0 0"
17:27:23 [1]: ClearTempMountsJob finished. Here's what was done:
17:27:23 [0]: Starting job "Rimuovere i punti di mount per operazioni di partizionamento su /dev/sda"
17:27:24 [0]: QOpenGLShader: could not create shader
17:27:24 [8]: QOpenGLFramebufferObject: Framebuffer incomplete attachment.
17:27:24 [8]: QOpenGLFramebufferObject: Framebuffer incomplete, missing draw buffer.
17:27:24 [8]: QOpenGLFramebufferObject: Framebuffer incomplete, missing attachment.
Segmentation fault
#41
System:    Host: ma3a Kernel: 4.14.12-3.2-MANJARO i686 bits: 32 gcc: 7.2.1
Battery    BAT0: charge: 40.9 Wh 97.4% condition: 42.0/51.8 Wh (81%)
           model: ASUSTEK IBM-42T5233 status: N/A
           clock speeds: max: 1801 MHz 1: 1626 MHz 2: 1171 MHz
           bus-ID: 00:02.0
           tty size: 80x24
           Sound: Advanced Linux Sound Architecture v: k4.14.12-3.2-MANJARO
Drives:    HDD Total Size: 282.1GB (25.4% used)
           ID-2: USB /dev/sdb model: USB_Flash_Drive size: 32.0GB
Partition: ID-1: / size: 225G used: 34G (16%) fs: ext4 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 75.0C mobo: N/A
Info:      Processes: 142 Uptime: 13 min Memory: 590.0/1983.1MB
[meurglys@ma3a ~]$
